67 Camaro 350 SS OEM Survivor air cleaner? - Team Camaro Tech
Restoration Corner Where originality comes first
 3Likes
post #1 of 18 (permalink) Old Oct 15th, 19, 12:14 PM Thread Starter
Tim
i have what I think is an original SS 350 air cleaner
I was wondering if some of you have VERIFIABLE originals could chime in?
my 1 owner has a black one, which I believe got swapped out sometime in its life,,
I realize the bottom is for a NON A.I.R car,,which mine IS, so I cant use the bottom,,but I needed the chrome lid....
ID:	229887   Click image for larger version
ID:	229889   Click image for larger version
ID:	229893   Click image for larger version
ID:	229895   Click image for larger version
1967 RS/SS Coupe, Factory A/C, 2nd owner, original paint -Taho Turquoise 3 Spd on the floor, bench seat, fold down rear seat
1967 RS Convertible Factory A/C, PS, PB PG 327
Niblet is offline
post #2 of 18 (permalink) Old Oct 15th, 19, 02:06 PM
Robert
Re: 67 Camaro 350 SS OEM Survivor air cleaner?
That looks correct to me for a 67 or 68 with manual transmission. The part number seems to decode to a 67 SS350.
Niblet likes this.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #3 of 18 (permalink) Old Oct 15th, 19, 02:08 PM Thread Starter
Tim
I just want to ensure it is NOT a repop!
Niblet is offline
post #4 of 18 (permalink) Old Oct 15th, 19, 03:13 PM
Garth
67 and 68 lids are totally different. Are you saying the lower housing is the same ?
I could be wrong, but presume 67 originally had the silk screen print on the bottom of the lid. No evidence on yours, Tim ?
Garfields Maro is online now
post #5 of 18 (permalink) Old Oct 15th, 19, 03:32 PM
Robert
Yeah, sorry, I meant the base! But I was looking at the sticker (which is just a sticker) for the SS350/295hp motor was for 67 and 68. 69 was 350/300hp. But yes the lids are different.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #6 of 18 (permalink) Old Oct 15th, 19, 06:46 PM
Roger
rogerh's Avatar
Here is a few pictures of my original air cleaner cover. The only difference I seen was those vertical lines on the outside edge. You may check the wing nut hole. Mine has the chrome worn away. On the underside of the hole, it has a ridge around it. The one picture of the dime shows the rubber gasket thickness and outside lip dimension.
The grove around the outside diameter of my original air cleaner had bad pitting and it had small pitting all over. So I chose to replace is with a new after market instead of rechroming the original.
The part number of my replacement was on the plastic I had this old one in. It is AMD W-461. It was a good replacement.
Roger
Name:	Cleaner cover-1.JPG
ID:	229901   Click image for larger version
Name:	Cleaner Cover-2.JPG
ID:	229903   Click image for larger version
Name:	Cleaner Cover-3.JPG
Name:	Cleaner Cover-4.JPG
ID:	229907   Click image for larger version
Name:	Cleaner Cover-5.JPG
ID:	229909   Click image for larger version
Name:	Cleaner Cover-6.JPG
Name:	Cleaner Cover-7.JPG
ID:	229913   Click image for larger version
Name:	Cleaner Cover-8.JPG
ID:	229915   Click image for larger version
Name:	Cleaner Cover-9.JPG
rogerh is offline
post #7 of 18 (permalink) Old Oct 15th, 19, 07:01 PM
Roger
rogerh's Avatar
Garth I don't remember it ever having any silk screen printed on the bottom of the lid. It would have been pretty evident with the smoky haze still on the bottom of mine.
Roger
rogerh is offline
post #8 of 18 (permalink) Old Oct 15th, 19, 07:21 PM
Michael
The silk screening is on the flash chromed open element air cleaner lid.
mahunt is offline
post #9 of 18 (permalink) Old Oct 15th, 19, 07:43 PM Thread Starter
Tim
Thanks Roger just what I was looking for , there a a couple very minor differences in mine, but for what I paid for it I'm not taking any chances
those lines around the edge are a bit sketchy, and next to the rubber piece inside there is an extra " roll" that mine doesn't have,,could be nothing
maybe different manufactures, but for the price,,sorry I need NO questions, it could be an older repop or something,,I have a new repop and its a joke compared to your original not even close
Thanks again!
rogerh likes this.
Niblet is offline
post #10 of 18 (permalink) Old Oct 15th, 19, 07:47 PM Thread Starter
Tim
Anyone else have an original they can snap a pic of the edge? to see about those "ridges"?
Niblet is offline
post #11 of 18 (permalink) Old Oct 15th, 19, 09:05 PM
Garth
Roger
Sorry guys, my mistake. Makes sense that silk screening on the lid would be for open element only as the service info for closed element is included on the sticker applied to the base.
post #12 of 18 (permalink) Old Oct 16th, 19, 08:17 AM
Russ
I'll try to get a picture posted tonight of one I have sitting around. No silk screening on the underside. I think the repops have an off-white seal, and the originals are black? FWIW it took me years to find an original AIR bottom housing with the two tubes.
Petes L48 is offline
post #13 of 18 (permalink) Old Oct 16th, 19, 08:19 AM Thread Starter
Tim
I have a nice AIR bottom, but the PO powdercoated it,,,how do I remove the powdercoating ?
and is it a 30% flat black or whatever?
Looking fwd to the pics,,Thanks!
Niblet is offline
post #14 of 18 (permalink) Old Oct 16th, 19, 09:37 AM
Vega$69's Avatar
Very hard to remove powder coating on stamped steel thin gauge parts. Media blast is about the only way and that may distort the metal.
I would suggest prime and paint over the PC finish.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #15 of 18 (permalink) Old Oct 16th, 19, 09:38 AM Thread Starter
Tim
sounds like a plan,,wonder where I would find what finish is correct...............
Niblet is offline
