1967 Coupe Steering pump mount - Team Camaro Tech
Restoration Corner Where originality comes first
post #1 of 2 (permalink) Old Jan 17th, 20, 08:13 PM Thread Starter
Probationer
Question 1967 Coupe Steering pump mount
Replaced the original exhaust manifolds with short tube headers on my 1967 2dr Coupe. Its a 327 and I am now having difficulty getting the rear power steering bracket installed. I believe it is supposed to anchor on top of the driver side motor mount. The top hole lines up but the motor mount has a flange that prevents the lower rear bracket hole from being installed. Has anyone modified their motor mounts to fix this or do I need to buy a different set of motor mounts?
Tony1967 is offline
post #2 of 2 (permalink) Old Jan 17th, 20, 10:34 PM
Re: 1967 Coupe Steering pump mount
The pump mounting bracket is designed to work with the original non-interlocking
style motor mounts. The interlocking design interferes with the original bracket.
You can use the 68 style pump brackets to fix your problem. They are a few threads
on it here somewhere. I'll see if I can find them. Or use the original style non-interlocking
motor mounts.
Added: This thread should help
https://www.camaros.net/forums/16-br...ump-mount.html
my 67' build thread:
allanjs is offline
