predator tuner 2012 Camaro - Team Camaro Tech
 5thgen.jpg - 4890 Bytes
Fifth Generation Discussion forum for the newest Camaro 2010Ėpresent
LinkBack Thread Tools
Old Feb 12th, 12, 06:17 AM   #1 (permalink)
2012 Camaro will the predator tuner show up @ dealship on the ecm as being flashed when took in for warranty work ? after stock tune is reinstalled
donandbeck is offline   Reply With Quote Quick reply to this message
Old Feb 12th, 12, 07:18 AM   #2 (permalink)
Re: predator tuner 2012 Camaro
I know it would show up on a diesel powered vehicle, and I would guess it would on any vehicle. GM has had issues with damage caused by tuners and has used this as grounds to void warranties.
69 Pace Car and 69 Hard top
srode is offline   Reply With Quote Quick reply to this message
Old Mar 23rd, 12, 10:01 PM   #3 (permalink)
Yes, dealers can see if the tune is stock or aftermarket, and can even see how many times the computer has been altered.
#09-06-04-026B: Identifying Non-GM (Aftermarket) Engine and Transmission Calibrations for V8 Gas Engines Using Tech 2 or Global Diagnostic System (GDS) - (Apr 7, 2010)
Subject: Identifying Non-GM (Aftermarket) Engine and Transmission Calibrations for V8 Gas Engines Using Tech 2ģ or Global Diagnostic System (GDS)
Retrieving Calibrations From a Global A Vehicle
This information applies to the 2010 Camaro and is typical of the procedure that will be used on Global A vehicles.
1. Turn OFF the ignition.
2. Connect the MDI to the Data Link Connector (DLC) of the vehicle.
Note: Use the USB port to make the following MDI connection:
3. Connect the MDI to a PC or laptop that has been downloaded with the GDS application from TIS2WEB.
Note: At least one Diagnostic Package must be installed on the PC to perform diagnostics.
4. If GDS was just installed, select: Add New Diagnostic Package and then select: a Diagnostic Package to download. Click: On the GDS icon on the PC.
5. The Login Page will appear.
6. Select: A User.
7. The ID Screen will appear.
8. Select: The serial number of the MDI being used.
9. Select: Connect.
10. Verify that the system status is ready by observing for a flashing PC light icon on the MDI.
11. Select: Make, Model and Model Year, in order to build the vehicle.
12. Click: Upload VIN, to allow the VIN to be reported to the PC.
13. At: The Verification step, turn ON the ignition, with the engine OFF.
14. Select: Next Action.
15. The Home Page will appear.
16. Select: Next.
17. The Diagnostic Screen will appear.
Note: Due to vehicle build, software and RPO variations, GDS may ask for additional information in Step 18.
18. Select: Engine ID, if prompted.
19. Select: Module Diagnostics.
20. Select: ECM.
21. Select: ID Information.
22. The Diagnostics page will appear.
Note: GDS is capable of displaying up to 10 Calibration History events.
23. Select: Calibration History from the drop down menu in order to display the following items on the screen:
• Calibration History Buffer
• Number of Calibration History Events Stored
• Calibration Part Number History
• Calibration Verification Number History
24. Select: Screenshot.
25. Name and save the file in an appropriate folder.
26. Select : Print, and retain a copy of the screenshot with the repair order.
27. E-mail a copy of the screenshot to [email protected]. In the subject line of the e-mail include the phrase "V8 Cal" as well as the complete VIN and Dealer BAC. In the body of the e-mail, include the VIN, mileage, R.O. number and BAC. Include a brief description of the customer concern and cause of the concern.
Note: The dealer will receive an e-mail reply after the calibrations have been validated. The e-mail reply will advise the dealer if the calibrations are OEM.
28. Allow two hours for the PQC to verify the calibrations and set up the case details.
⇒ If the PQC determines that the calibrations ARE aftermarket calibrations, DO NOT contact GM Technical Assistance to discuss warranty concerns on the aftermarket calibrations. ALL questions and concerns about warranty should be directed to the dealers Fixed Operations Manager (FOM), (Warranty Manager (WM) in Canada).
29. You may call the PQC two hours after submitting the e-mail for authorization to replace the assembly. This will provide them time to receive, review and set up a case on the request. Please be prepared to provide all the usual documentation that is normally required when requesting an assembly authorization from the PQC.
Warranty Information
• The Dealership Service Management must be involved in any situation that would justify the use of labor operation Z1111.
• Notify the Fixed Operations Manager (FOM) (Warranty Manager (WM) in Canada) of the situation.
• All claims will have to be routed to the FOM (WM in Canada) for approval.
• Please refer to Corporate Bulletin Number 09-00-89-016, Labor Operation Z1111 - Suspected Tampering or Vehicle Modifications for important information.
2010 2SS LS3 - Lots of mods....
EatinZs is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Muncie M21 speedo delete
Today 08:33 AM
by tbarsch
Last post by tbarsch
Today 08:33 AM
0 Replies, 7 Views
Looking at this 67 this...
Yesterday 08:03 AM
Last post by Old Dad's 67
Today 08:20 AM
37 Replies, 543 Views
How Bad Is It?
Mar 30th, 20 11:07 PM
Last post by fiveforty
Today 08:16 AM
60 Replies, 2,703 Views
Water Pump Pulley...
Apr 5th, 20 01:00 PM
Last post by GlacierBlue68
Today 08:05 AM
15 Replies, 209 Views
Vacuum secondary
Today 03:03 AM
Last post by Larger Dave
Today 07:58 AM
3 Replies, 51 Views
Z Won't Start!
Today 06:55 AM
Last post by R66
Today 07:31 AM
2 Replies, 43 Views
Just joining!
Apr 3rd, 20 06:58 PM
Last post by R66
Today 07:20 AM
12 Replies, 200 Views
RS grille molding
Apr 5th, 20 07:49 AM
by bills69
Last post by bills69
Today 06:54 AM
4 Replies, 139 Views
A little brake and...
Apr 5th, 20 09:16 PM
Last post by bill3337
Today 06:52 AM
21 Replies, 316 Views
12 bolt pinion seal leaks
Mar 14th, 20 07:07 AM
by vstol
Last post by Vega$69
Today 06:39 AM
12 Replies, 462 Views
