Burning Question on Throttle Response - Team Camaro Tech
 5thgen.jpg - 4890 Bytes
Fifth Generation Discussion forum for the newest Camaro 2010–present
LinkBack Thread Tools
Old Oct 11th, 12, 04:01 PM   #1 (permalink)
Question Burning Question on Throttle Response
Ok, so I was drivin' around in my 10 SS (6spd man) earlier and noticed a slight lag on my throttle response. I got to a stop sign and wanted to beat the traffic and get on my way. I floored it in first and as I was rounding the 90 degree to get on the road, the rpms went down slightly and 'hestitated' before picking back up! I usually don't drive her that way, but it felt odd that she had a slight lag getting on it! I come from a previous backround with a third gen, and that thing would spin tires from here until tomorrow! Is there something wrong with my SS, or is it just the traction control/engine control systems on the SS that's giving this slight hesitation? The only thing I can think of is that this is the first time I've had her tank with mid-grade 89 Octane (I usually put in Super Premium) and she might not like it.... Any ideas?
InsaneCamaroDriver is offline   Reply With Quote Quick reply to this message
Old Oct 11th, 12, 05:19 PM   #2 (permalink)
Re: Burning Question on Throttle Response
JMT's, I would think PCM would take care of lower octane fuel.
If you can, disable Traction Control and repeat WOT again and compare results.
I know it is apples-to-oranges, but, once my '88 Chev truck, OBD I, loses battery power, it relearns with throttle position, idle, and every other engine parameter.
Once I do a couple 'heavy' throttle positions, the lag is gone and engine operates smoother. Maybe repeated WOT's, PCM will relearn?
Old Oct 11th, 12, 05:50 PM   #3 (permalink)
DjD
DjD's Avatar
I'd say traction control kept the tires from spinning but it also sounds like you bounced off the rev limiter as you punched it...
...Dennis
DjD is offline   Reply With Quote Quick reply to this message
Old Oct 11th, 12, 05:53 PM   #4 (permalink)
I'll be sure to try without the traction control.... It's a manual, so I'd be pressed to find a rev limiter on it....
Camaros exist because God HATES Mustangs
Old Oct 11th, 12, 06:00 PM   #5 (permalink)
DjD
DjD's Avatar
I don't understand what you are saying... Your car has a rev limiter (stick or automatic), rev it up to the rev limit and the engine cuts out for a sec to allow the rpm to drop.
...Dennis
Old Oct 11th, 12, 06:20 PM   #6 (permalink)
Sorry, I don't know why I was confusing the rev limiter for a torque converter. I'm an idiot there... Anyhow, I find it odd that it would cut out so early, it's not reaching high at all. In a straight line it doesn't cut out on me like that. That's why it's a bit confusing to me.
Old Oct 11th, 12, 07:17 PM   #7 (permalink)
DjD
DjD's Avatar
If you know for sure the rpm wasn't up at the red line then I'd say it wasn't the rev limiter... You said you floored it around the corner. Being in 1st means it's going to rev up rather fast and since you compared it to your old 3rd gen spinning the tires I just assumed you had the rpms up if you thought the tires should have spun... Traction control at that point is the only reason your tires were not spinning.
Anyway it could have even been your rear end since you were cornering, the posi is wanting both tires to turn at the same rate when power is applied but is going to start doing it's limited slip thing to allow one tire to spin slower than the other. Combine that with the traction control trying to keep the tires from breaking loose and maybe the result felt like the engine hesitated.
...Dennis
Old Oct 12th, 12, 08:43 AM   #8 (permalink)
Vintage 68's Avatar
Wink Re: Burning Question on Throttle Response
May be the ECM reaction to the fuel used
Common for the ECM to go to 'lower' the timing map if it detects issues due to Octane rating ...
Been discussed on here (and most likely 1,000s of times on 5th Gen boards) before - https://www.camaros.net/forums/showth...ghlight=Octane
1968 Convertible
Some trucks
Vintage 68 is offline   Reply With Quote Quick reply to this message
Old Oct 12th, 12, 09:50 AM   #9 (permalink)
I don't have a 5th gen Camaro but I know they have an electronic throttle so it doesn't matter how hard you mash the pedal, the controller is only going to give it the maximum throttle the program will allow.
I had a BMW with electronic throttle, it took a while to get used too. It would reduce throttle based on traction, gear, steering angle. It also had a throttle response switch that had 2 settings, Sport (twitchy) and Komfort (slugish).
Your Camaro is programmed to prevent loss of control and i bet it is reducing throttle response due to steering angle, among other factors.
Here is what can happen if it doesn't
http://www.youtube.com/embed/a0Ve2eNfgPQ
68 Ragtop is offline   Reply With Quote Quick reply to this message
Old Oct 13th, 12, 09:54 PM   #10 (permalink)
There is a slight delay on the throttle to smooth the input, but it is milliseconds. What you more likely hit (if it wasn't traction control or stability control) is gm's torque management that limits the torque in any given gear. You can tune it out but it will void your warranty.
62 Corvette (Stock Restoration)
68 RS/SS Camaro, LS7/T56
68 RS Convertible project LS3/480/4L70
2006 Corvette Z06
2011 Corvette GS Convertible
68sixspeed is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
CV19 & Collector Car...
Apr 3rd, 20 10:01 AM
Last post by dhutton
Today 04:50 AM
22 Replies, 427 Views
New to Team Camaro -...
Yesterday 08:56 AM
Last post by DOUG G
Today 04:49 AM
5 Replies, 84 Views
Update Failing Electric...
May 30th, 17 02:02 PM
by 69-Pace
Last post by adjudimo
Today 03:31 AM
16 Replies, 6,180 Views
Cost for a shop to get...
Mar 31st, 20 08:58 PM
by Keebler
Today 03:14 AM
40 Replies, 710 Views
6L90 & LSX into 68...
Apr 12th, 08 04:09 PM
by RSZ28
Last post by RSZ28
Today 12:32 AM
13 Replies, 12,092 Views
Floor pans patch 68
Yesterday 11:38 PM
Last post by Garfields Maro
Today 12:24 AM
1 Replies, 43 Views
Just joining!
Apr 3rd, 20 06:58 PM
Last post by Ghostbuster
Yesterday 09:27 PM
9 Replies, 128 Views
'68 350 SBC Running Hot?
Mar 31st, 20 01:08 PM
Last post by GlacierBlue68
Yesterday 09:18 PM
57 Replies, 925 Views
Brakes won’t...
Yesterday 04:28 PM
by Tdog
Last post by mlicker
Yesterday 08:52 PM
8 Replies, 104 Views
69 pre purchase...
Yesterday 06:13 AM
Last post by allanjs
Yesterday 08:37 PM
3 Replies, 101 Views
