RX Oil Catch can's - Team Camaro Tech
 5thgen.jpg - 4890 Bytes
Fifth Generation Discussion forum for the newest Camaro 2010Ėpresent
LinkBack Thread Tools
Old May 1st, 14, 04:02 AM   #1 (permalink)
RX Oil Catch can's
Just a question for the wise on this site. What are the reasons or the need to install an oil catch can on a new camaro. I see some i have looked at say they have installed an RX oil Catch can on some of the more modified ones i have looked at. Just was wondering why? Does it get too much crankcase presure and barf out oil out of somewhere? Let me know what you think and Thank you
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
mike's blue67 is offline   Reply With Quote Quick reply to this message
Old May 1st, 14, 07:30 AM   #2 (permalink)
DjD
DjD's Avatar
Re: RX Oil Catch can's
The catch can goes inline with the PCV and reduces the amount of oil that goes back into the manifold and combustion chamber. In a stock application this is minimal but when compression is boosted by blowers and other power adders there is an increase in crank case pressure and more oil can get into the manifold.
Like everything else sometimes you see modifications like this and it's not necessary. It's an easy install and guys read about others doing it so they do it too. To many it really can seem like a needed item when between oil changes it catches a couple spoonful's that would have otherwise been burned off in the combustion chamber!
...Dennis
DjD is offline   Reply With Quote Quick reply to this message
Old May 1st, 14, 08:19 AM   #3 (permalink)
Thanks for the info Dennis.
Old May 1st, 14, 10:19 AM   #4 (permalink)
Send a message via AIM to PROZ11
From what I've read the V6 5th gens seem to have more of an "issue" than the V8. But as DjD said, under normal conditions it's probably not necessary for either. Some guys swear their cans are filled with oil after a few thousand miles. I have to doubt it.
On a side note, the new 1LE Camaros come with a catch can/ oil separator set up from the factory.
http://sandyblogs.com/techlink/wp-co...chlink_F07.jpg
Pro Street Z11 clone
YOUTUBE VIDEO:
PROZ11 is offline   Reply With Quote Quick reply to this message
Old May 1st, 14, 04:04 PM   #5 (permalink)
If running a power adder, the last thing you want is oil in the combustion chamber
Oil "can" cause detonation in some cases....power adders and/or on the edge of the limits of pump gas.
68 Camaro~LSx ~all motor
DOUG G is offline   Reply With Quote Quick reply to this message
Old May 2nd, 14, 03:59 AM   #6 (permalink)
Yup, I agree about the power adders. I run one on my blown big block. I don't run one on my 5th Gen, at least not yet. Only minor mods on that one for now.
YOUTUBE VIDEO:
Location
Location
First Name
» Recent Discussions
Water Pump Pulley...
Apr 5th, 20 01:00 PM
Last post by GlacierBlue68
Today 09:45 AM
17 Replies, 237 Views
Looking at this 67 this...
Yesterday 08:03 AM
Last post by Niblet
Today 09:35 AM
41 Replies, 617 Views
RS grille molding
Apr 5th, 20 07:49 AM
by bills69
Last post by KevinW
Today 08:51 AM
5 Replies, 153 Views
Muncie M21 speedo delete
Today 08:33 AM
by tbarsch
Last post by any4xx
Today 08:39 AM
1 Replies, 31 Views
How Bad Is It?
Mar 30th, 20 11:07 PM
Last post by fiveforty
Today 08:16 AM
60 Replies, 2,726 Views
Vacuum secondary
Today 03:03 AM
Last post by Larger Dave
Today 07:58 AM
3 Replies, 63 Views
Z Won't Start!
Today 06:55 AM
Last post by R66
Today 07:31 AM
2 Replies, 56 Views
Just joining!
Apr 3rd, 20 06:58 PM
Last post by R66
Today 07:20 AM
12 Replies, 205 Views
A little brake and...
Apr 5th, 20 09:16 PM
Last post by bill3337
Today 06:52 AM
21 Replies, 328 Views
12 bolt pinion seal leaks
Mar 14th, 20 07:07 AM
by vstol
Last post by Vega$69
Today 06:39 AM
12 Replies, 472 Views
