Engine chip HP question good or bad - Team Camaro Tech
 5thgen.jpg - 4890 Bytes
Fifth Generation Discussion forum for the newest Camaro 2010Ėpresent
LinkBack Thread Tools
Old Mar 5th, 15, 06:59 AM   #1 (permalink)
I have a 2010 Camaro SS. There are a number of companies selling performance
chips for these cars and others, GForce, PCN, US Musclemods and others.
They claim anywhere from30 to 80 HP increase and a increase in gas mileage.
On the net some people say they do what they are advertised to do and some
say they do not. Just looking for the truth.
67 383 stroker 460hp RS SS clone 4sp blk on blk m21 Chevelle 12 bolt rear end
Hys67Camaro is offline   Reply With Quote Quick reply to this message
Old Mar 5th, 15, 08:52 AM   #2 (permalink)
Re: Engine chip HP question good or bad
IIRC the 2010 (as well as all Camaros from 96 forward) utilize a EEPROM (Electrically Erasable Programmable Read Only Memory) which allows one to change settings with a laptop and the appropriate software (i.e., HPTuners). This is how you alter the timing, knock retard, fuel injector pulse width, fuel shutoff (rev limiter) etc.
Most of the items you mentioned do nothing more than lean out the fuel to air ratio. I don't believe there is a "chip" for these cars.
If it was my car I'd take it to someone with a chassis dyno and adjust it according to what the readout says needs to be adjusted (F/A ratio, knock retard, turn off various sensors if not required, i.e., the sensor beyond the cats if you've installed headers and deleted the cats, etc.). This is what I did with my 02 Z28 when I was racing it.
As always, just my $.02 worth...
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
PowerWindows is offline   Reply With Quote Quick reply to this message
Old Mar 10th, 15, 10:58 AM   #3 (permalink)
Let me tell you a little secret before you go out and buy a chip. If you have an auto car, and ever, and i mean ever, ran 87-89-91 ethanol fuel through that engine, the computer has adjusted for it, and you lost 30-40 hp permanently. It only takes once. Well until you unplug the fuses to the computer. It resets the fuel map, and won't adjust back unless you do the fuse pull. Here, is a little writeup on it, most peoples cars are slow off the lot, due to dealerships putting junk fuel in them. Oops.
http://www.camaro5.com/forums/showthread.php?t=38964
1967 RS/SS Camaro 383 5 speed tremec 3.70
1967 RS/SS Camaro 383 5 speed tremec 4.10
1967 RS Camaro Convertible 327 4 speed 3.73
1969 SS Camaro 6.0 LS Twin Turbo 5 Speed 3.50
2013 ZL1 Camaro roto-fab airbox pulley swap Rest In Pieces March 27 2014
FTF Automotive is offline   Reply With Quote Quick reply to this message
Old Mar 10th, 15, 01:38 PM   #4 (permalink)
That thread is a complete train wreck!
5 years, 100 pages: silver bullet, testimonials, doubters, GM issues TSB (bullet is not silver and fuses need to be pulled but not those ones), previous believer becomes doubter - posts video, others say stopwatch doesn't lie, famous tuners quoted anonymously, identities demanded, bickering ensues, and on it goes...
tonight I'm going to pull the dome light fuse from my convertible and see if it improves MPG or ET!
1969 Camaro Convertible
thebat is offline   Reply With Quote Quick reply to this message
Old Mar 10th, 15, 01:58 PM   #5 (permalink)
Thanks for your replys
Old Mar 10th, 15, 02:00 PM   #6 (permalink)
thecamaroguy's Avatar
I did the fuse pull on my manual...
I also, bought a handheld programmer and had Torq down in Florida put a tune on it.
Lots of Camaro5 members use http://jannettyracing.com/ to remote tunes, I would probably if I didn't already have Torq's.
Ron
Camaros I've owned/own:
1982 Camaro (Sold)
1984 Camaro Z28 (Sold)
1986 Camaro Z28 (Sold)
1989 Camaro IROC Z (Sold)
1994 Camaro Z28 (Sold)
1967 Camaro 406 SBC/200R4 (Rebuilding)
2010 Camaro RS/SS (Daily Driver)
thecamaroguy is offline   Reply With Quote Quick reply to this message
Old Mar 10th, 15, 02:01 PM   #7 (permalink)
It is a train wreck, agreed, as most forum discussions are on anything. However, it does work. I just posted it because you could see which two to pull. Easier than me trying to explain it. My brothers dynoed 345 at the tires, then 379 after we reset it. His is an auto car though, which if you believe what people say, can make a difference between the LS3 and L99. It was a noticeable difference for his car.
Old Mar 10th, 15, 02:44 PM   #8 (permalink)
go to someone who knows how to tune, do some dyno pulls, done.
"Chips" do not exist.
Unless you drive a 12 valve "cummings"
I'll take some chips for my salsa though.
Does the fuse pull really work, or is that a troll post?
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline   Reply With Quote Quick reply to this message
Old Mar 10th, 15, 02:56 PM   #9 (permalink)
Yes I think it does/did. The original source for the Fuse Pull was told by GM to do that, because his car would not even spin the tires. So, he was told to do that from GM directly.
He then posted it and many have had success stories.
Ron
1982 Camaro (Sold)
Old Apr 11th, 15, 07:30 PM   #10 (permalink)
ME4NSTRK69's Avatar
A dyno tune is the best way to go with these cars.
1969 Camaro 350 EFI 200r4 342 Posi
1987 WE4 Turbo Regal E85
2003 Sierra Stepside RCSB Belltech dropped
MY BUILD THREAD:
ME4NSTRK69 is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
How Bad Is It?
Yesterday 11:07 PM
Last post by Vega$69
Today 05:41 AM
7 Replies, 108 Views
new
Today 02:15 AM
by yassin3
Last post by carcrazy615
Today 05:38 AM
2 Replies, 32 Views
CPAP machine into a...
May 10th, 10 01:40 PM
by mes5278
Last post by X-77 keith
Today 05:12 AM
12 Replies, 5,952 Views
What's in the rear end?
Mar 21st, 20 08:03 AM
by Willem
Last post by Willem
Today 04:55 AM
37 Replies, 685 Views
Humpday Humor, 3/11 ......
Mar 10th, 20 04:15 PM
Last post by adjudimo
Today 04:31 AM
7 Replies, 249 Views
I think I got lucky
Yesterday 04:42 PM
by RDW
Last post by RDW
Today 04:30 AM
5 Replies, 127 Views
Just Bought a 69
Mar 28th, 20 07:25 PM
Last post by Hendo624
Today 03:47 AM
21 Replies, 338 Views
Custom Sequential Turn...
Feb 1st, 14 10:02 AM
by tmax68
Last post by yassin3
Today 02:58 AM
108 Replies, 38,149 Views
Spark plugs
Mar 26th, 20 05:01 PM
Last post by nashcar
Today 02:53 AM
8 Replies, 273 Views
New Member Intro
Mar 10th, 20 08:17 PM
by KDW68
Today 02:49 AM
5 Replies, 140 Views
