Winter storage - Team Camaro Tech
 5thgen.jpg - 4890 Bytes
Fifth Generation Discussion forum for the newest Camaro 2010Ėpresent
LinkBack Thread Tools
Old Aug 26th, 15, 03:16 AM   #1 (permalink)
Winter storage
I have a 2015 2 ss 1LE, Just wondering the best way to store it for the winter, It wont fit in the heated garage, I have things to do to my 67 this winter. Should I fill the tank, or leave it low with some stable in it? Should I disconnect the battery or leave it on a battery tender all winter? Worried about electronics in the car with no power over the winter such as the computers. Tires< leave on the concrete or some roller stands with the concave bottoms so the tires are not sitting on flat ground in the cold. Any ideas or suggestions would be great thanks MIke
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
mike's blue67 is offline   Reply With Quote Quick reply to this message
Old Aug 26th, 15, 03:43 AM   #2 (permalink)
Re: Winter storage
full tank of fuel with sea foam. I have never been a fan of stabil. I would also leave the battery in the car and use a tender. anything under the tires will help keep them from settling with the freeze and thaw of the soil
this is just my opinion only
flat tire is offline   Reply With Quote Quick reply to this message
Old Aug 26th, 15, 04:54 AM   #3 (permalink)
Re: Winter storage
X2 on the sea foam and tender. Better for the car to winter it in FL at my house. I'll take good care of it.
And this too shall pass.
69 X11 SS, Glacier Blue, LS3 480, T56 Mag, Lots of stuff done to it, all by yours truly
Build thread:
workng247 is offline   Reply With Quote Quick reply to this message
Old Aug 26th, 15, 06:54 AM   #4 (permalink)
Re: Winter storage
Thanks for the advise guys
Old Sep 1st, 15, 05:54 PM   #5 (permalink)
Re: Winter storage
Park the car on thick cardboard, this will absorb the moisture raising up from the ground.
Place rodent traps under the car or the mice will attack it. I would also place 1lb bags of desiccant under the hood in the cabin and in the trunk to absorb moisture. Wax the exterior but do not remove the wax. Spray all the rubber with silicone spray lubricant.
You will have some spring cleaning to do but the car will be in good shape.
67 RS/SS 350, M21, 3:70 POSI, Hooker side mount headers, blue dot tail lights. owner since 1974.
327fuelinjected is offline   Reply With Quote Quick reply to this message
Old Sep 1st, 15, 06:45 PM   #6 (permalink)
scblucam's Avatar
Re: Winter storage
Winter? What's that?
68 302 M20 - 85 IROC Z
scblucam is offline   Reply With Quote Quick reply to this message
Old Sep 2nd, 15, 07:33 AM   #7 (permalink)
Re: Winter storage
Thanks Guy's, I plan to store it off the ground on some casters so the tires are off the ground and in a round pocket. The moisture control is a good idea. I have a good cover for it . I will have plenty of mouse poison around the barn. Mike
Old Sep 4th, 15, 04:54 AM   #8 (permalink)
Re: Winter storage
Jeez, how long is the winter! I know I used to live in Minnesota. Sound like a lot of trouble for a new car that will be able to handle the weather by it self. I would just drive it every few weeks on a nice winter day and would be cautious of a cover that could hold moisture and cause more issues than not. Give it a good wax and don't leave it on and wash every so often.(Used to have a detail shop and leaving it on for long periods is a no-no. Put some bounce pads in the interior and under the hood to keep the critters away. I have 05 Vett that lives outside and that is what I do and the car is happy after 10 years. Granted we don't get that cold but the car doesn't care. My 99 Z vert sits outside as well and did in Iowa. My 5 69's however all live inside.
The Camaro Guy is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
My 67 Resto Mod Build
Jul 29th, 18 05:58 PM
by Sosh67
Last post by Sosh67
Today 08:21 PM
292 Replies, 25,778 Views
Power steering hoses
Today 07:23 PM
by mpeters
Last post by Riverbud
Today 08:03 PM
1 Replies, 20 Views
clutch pushrod bushings
Mar 30th, 20 09:04 PM
Last post by Luwi67
Today 07:28 PM
1 Replies, 69 Views
1968 Gauge Cluster...
Mar 30th, 20 10:47 AM
Last post by jcabuilder
Today 07:24 PM
12 Replies, 297 Views
1969 Console rear ashtray
Today 01:52 PM
by TonyS
Last post by TonyS
Today 07:12 PM
3 Replies, 73 Views
Rear Wiring Harness...
Today 07:00 PM
by JugBolt
Last post by JugBolt
Today 07:00 PM
0 Replies, 14 Views
Getting the correct bell...
Mar 30th, 20 06:59 PM
Last post by dyno jonn
Today 06:33 PM
3 Replies, 140 Views
Humpday Humor, 4/1 ......
Today 03:53 AM
Last post by 69Z28
Today 06:23 PM
7 Replies, 135 Views
Tailight hardware...
Today 02:45 PM
Last post by stamatisg1977
Today 05:58 PM
3 Replies, 65 Views
How Bad Is It?
Mar 30th, 20 11:07 PM
Last post by Sauron67MM
Today 05:37 PM
35 Replies, 1,183 Views
