Help with large exhaust please - Team Camaro Tech
Pro Touring Todays performance with classic style
post #1 of 8 (permalink) Old Apr 12th, 11, 09:40 AM Thread Starter
Hugh
I am building an LS3 68. The car dynos 560 at the motor. i am looking at boosting that number to 700-750, so 600 at the wheels.
I was told that 3" exhaust wont go over the axle without a severe crimp?
I was also told that the exhaust has to go over the axle to pass inspection, as it has to clear the cabin? Also, is it correct thet starting out at 3 inches and narrowing to 2.5 over the axle is the same as 2.5 all the way?
Any ideas on what I can do will be much appreciated!!!
Blevinator is offline
post #2 of 8 (permalink) Old Apr 12th, 11, 09:58 AM
DjD
DjD's Avatar
Re: Help with large exhaust please
Air condenses as it cools, the further from the heads the exhaust gets the cooler it gets. By the time it gets through the mufflers it's a lot cooler than say at the header. I don't have all the math to support this but the 2.5" out and over the axle should not restrict the 3" into the muffler. So no 3" to 2.5" is not the same as running 2.5" the entire way.
If you really want the 3" all the way I bet you will find guys are doing it with mandrel bent tubing which would have no crimping at all.
...Dennis
DjD is offline
post #3 of 8 (permalink) Old Apr 12th, 11, 10:35 AM
mark
please check with someone in TX but the way I read it the exhaust just needs to clear the passenger compartment. I belive dumping at the rear axle would clear the passenger compartment. or you could have it exit the side before the axle. I also agree that going down to 2.5 would not kill a measurable amount of horsepower. mark
stroud6 is offline
post #4 of 8 (permalink) Old Apr 12th, 11, 01:14 PM
Flowmaster makes a 3" kit.... I hear it tight but works
Another option may be to go over the axle with oval pipe ?
68 Camaro~LSx ~all motor
post #5 of 8 (permalink) Old Apr 12th, 11, 02:58 PM
Steiner
Dynatech makes a set of 1-7/8" coated headers and 3" full stainless exhaust for LSx in a first gen. Tailpipes dump past the rear wheel between the fender and leaf. Mouse over "LSx" on the left side of the page.
http://www.dynatechheaders.com/m_camaro_67_69.html
I have their regular SBC large headers and 3" kit.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 8 (permalink) Old Apr 12th, 11, 04:10 PM
Chris
Dumping it at the axle is illegal in Texas it must exit the body in front of rear tires or go over or under the axle and exit just past the rear tires or out the back to be legal just FYI,I found out the hard way a few years back lol
CMQuickcoupe is offline
post #7 of 8 (permalink) Old Apr 12th, 11, 05:44 PM
Russ
3" will clear up over the axle just fine. He's mine and this is a convertible which has even less space than a coupe plus I have an extra set of collectors installed too.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #8 of 8 (permalink) Old Apr 12th, 11, 06:08 PM
Bill
Send a message via MSN to Orange68SS Send a message via Yahoo to Orange68SS
Magnaflow makes a stainless system that clears the real axle fine.
[IMG][/IMG]
68 SS Camaro - 468 BB, Tremec 5 Speed, Wilwood Brakes, Curry 9 inch (370 gear)
Orange68SS is offline
