69 front suspension - Team Camaro Tech
Pro Touring Todays performance with classic style
post #1 of 5 (permalink) Old May 13th, 11, 08:04 AM Thread Starter
bob
69 front suspension
hello, I have a 69 with a dse front end with coilovers and two inch drop springs.I would like to raise it up 1 inch. I would appreciate any suggestions. thank you, Bob
pudge is offline
post #2 of 5 (permalink) Old May 13th, 11, 09:42 AM
Re: 69 front suspension
If you have coilovers then you are limited to what you can do since you want the shock to have roughly 50% travel in each direction at ride height.
dhutton is offline
post #3 of 5 (permalink) Old May 13th, 11, 10:12 AM Thread Starter
bob
Then trying to raise it an inch by adjusting the coilovers would not work .
pudge is offline
post #4 of 5 (permalink) Old May 13th, 11, 10:31 AM
Assuming they are centered now then you would have to increase the shock length by roughly 1/2 inch with the adjuster nut to get the ride height 1 inch higher. If you have a shock with 4 or 5 inches of travel you should be OK. At least that is my opinion.
dhutton is offline
post #5 of 5 (permalink) Old May 13th, 11, 11:43 AM Thread Starter
bob
thanks Don.
pudge is offline
