Help with McLeod Clutch Kit - Team Camaro Tech
Pro Touring Todays performance with classic style
post #1 of 12 (permalink) Old Apr 20th, 20, 12:24 PM Thread Starter
Apprentice
Michael Lockwoo
Hi all,
I've put an LS3 mated to the Tremec T56 magnum (6 speed) into a 69 Camaro that I'm building up. I bought and installed the McLeod Hydraulic Clutch conversion kit (1434002) and I have noticed that there is no hole in the clutch pedal to accomodade the clutch safety switch which is located under the dash. I called McLeod to ask about this and they said they had never been contacted regarding this problem before.
What are people doing to work around this problem????
Mike L is offline
post #2 of 12 (permalink) Old Apr 21st, 20, 12:14 PM
Simon
Re: Help with McLeod Clutch Kit
Michael, I have the same Mcleod kit though I haven't installed it yet but will probably have the same dilemma.
A few possible options are to re-drill the supplied clutch pedal.
If the slave cylinder rod is in the way, how about flipping the neutral switch rod on the other side of the pedal? Or making another rod from a coat hanger or similar material to activate from other side.
Still no good, moving the neutral switch forward more then re-drilling pedal but making sure you get enough arc from depressing the pedal to activate the neutral switch.
I don't know if this will help but keep us posted if you come up with another option to remedy this.
slazisme is offline
post #3 of 12 (permalink) Old Apr 21st, 20, 02:11 PM
Vega$69's Avatar
The pedal rod does go to the slave cylinder. The slave cylinder is inside the bell housing around the input shaft. The slave is connected to the clutch master cylinder located on the firewall. The pedal rod goes into the CMC.
To use a clutch switch you will need to fab and locate the switch to be depressed when the clutch pedal is pushed. May need to attach a tab to the pedal that will work to depress the switch.
Most I assume go without a clutch switch.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 12 (permalink) Old Apr 21st, 20, 05:45 PM
Matt
I just went through this on mine. I took the McLeod pedal and drilled a hole in the same location as the original pedal. I used the centerline of the pedal pin for reference. Works great.
My Build Thread
350sshugger is offline
post #5 of 12 (permalink) Old Apr 21st, 20, 06:33 PM
Lynn
I don't know if modern BMW's have a clutch switch. My 1983 does not. German engineers just figured if you were smart enough and adept enough to drive a stick shift you would be smart enough to put it in nuetral or depress the clutch before starting the car. My 69 Z/28 came with a clutch switch, and I think it is still under there, but it is bypassed. I have driven sticks long enough to know not to start it in gear with the clutch engaged. Your results may vary.
Lynn
bilodeaulynn is offline
post #6 of 12 (permalink) Old Apr 21st, 20, 06:34 PM
Lynn
Just looked at my post. Man, I sound like a grouchy old man. The older I get the more I feel like Statler and Waldorf.
Lynn
post #7 of 12 (permalink) Old Apr 21st, 20, 06:39 PM
Vega$69's Avatar
Milton Berle Vs. Statler & Waldorf - YouTube
Haha. I never put clutch or NSS on T56. Habit ingrained since I first started driving a stick shift at like 14 years old 55 years ago. 1st step on clutch when starting.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #8 of 12 (permalink) Old Apr 23rd, 20, 08:27 PM Thread Starter
Apprentice
Michael Lockwoo
Thanks for the replies. All are helpful ideas. Right now I'm leaning towards taking the easy route and removing and bypassing the switch all together. Like others, I've been driving stick long enough that it's habit to start with the clutch depressed. But, I also like the idea of doing some minor fabricating to get the switch to work. I'll repost when I get something done.
Mike L is offline
post #9 of 12 (permalink) Old Apr 23rd, 20, 08:47 PM
scblucam's Avatar
Those were the days
68 302 M20 3:73 - 85 IROC Z - 82 Honda CB900C
scblucam is offline
post #10 of 12 (permalink) Old Apr 23rd, 20, 09:02 PM
Vega$69's Avatar
We donít need no stinking switches. Lol
Vega$69 is offline
post #11 of 12 (permalink) Old Apr 30th, 20, 09:16 AM
Likely take some form of fabrication to mount a NSS. I did a A4 to T56 swap in a car that never came as a stick (not a camaro) and have a fabricated clutch pedal assembly using the McLeod MC. Just welded on a flat plate drilled & slotted to receive a BDW S9170 switch and a threaded rod with a rubber foot on clutch pedal arm, so it could be adjusted for depth to contact switch, and wired it into starter wires at base of column.
I have driven stick cars all my life but prefer to have a NSS. Even though by habit I always push in clutch pedal to start the car, I like having the NSS. More as a theft deterrent also. I always smile when I have to get some form of work done (tires or smog) where the guy says "your car won't start"..that same guy likely also does not know if car is in or out of gear.
I also wired the reverse lockout to brake pedal switch so you don't "accidently" buzz reverse when shifting into 5th aggressively
NSS
https://shop.advanceautoparts.com/p/...MK3A&gclsrc=ds
Pedal assembly (not for Camaro)
SoCal805 is offline
post #12 of 12 (permalink) Old May 17th, 20, 05:31 PM Thread Starter
Apprentice
Michael Lockwoo
Here is what I ended up doing.
1) Ground down the tab on the NSS switch that accepts the small rod. This was do the tab would not hit the pushrod on the new clutch pedal.
2) Measured from center of pedal pin to hole on original clutch pedal.
3) Measured the same distance on new clutch pedal and drilled a hole to accept the white plastic bushing.
4) Fashioned a new NSS switch rod out of coat hanger. On the pedal, i was able to use the clip that held the old rod in place. On the NSS switch, I did not use the clip. I just bent that end of the rod into a "Z" (not shown in pic) and fit it into the switch tab.
5) The geometry of the new switch rod is much different than the original but it works.
Mike L is offline
