What did I do wrong? - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Sep 20th, 13, 08:07 PM   #1 (permalink)
Here's a picture showing what I did. This is a rear-end out of a 70'. I know I have a u-bolt where there should be T-bolts on the inside. I had to use the longer U-bolts to fit in the urethane spring pads. Now, when I torqued the u-bolts to 40 ft/lbs, this is what I got. It looks awful, I can't leave it like this. The spring pads are all squished out, the shock plate is actually bending, and so are the u-bolts. I know my torque wrench is accuarate and I didn't accidentally torque them to 140 ft/lbs. Where did I go wrong?
Z28BUILD is offline   Reply With Quote Quick reply to this message
Old Sep 20th, 13, 08:28 PM   #2 (permalink)
Re: What did I do wrong?
Take out the pads.
Everett#2390 is online now   Reply With Quote Quick reply to this message
Old Sep 20th, 13, 09:31 PM   #3 (permalink)
Did you torque them while the wheels were on the ground; if not try that. The wheels should not be hanging. If I am wrong, I am sure someone will correct me.
1969 Camaro RS Hugger Orange - Work in Progress - You see rust, I see restoration!
rsb0719 is offline   Reply With Quote Quick reply to this message
Old Sep 21st, 13, 03:25 AM   #4 (permalink)
I would guess that since the only options in 1970 were 4 and 5 leaf spring packs, the issue is that 6 spring pack is too big for the perch.
'69 Camaro
500hp/538lbft
Steiner is offline   Reply With Quote Quick reply to this message
Old Sep 21st, 13, 03:51 AM   #5 (permalink)
NHBandit's Avatar
Good catch. I agree. Spacers between the bottom plate & the spring perch will correct that. At least the thickness of 1 leaf if not slightly thicker.
NHBandit is offline   Reply With Quote Quick reply to this message
Old Sep 21st, 13, 05:21 AM   #6 (permalink)
In my opinion that shock plate should not be bent the way it now is, the metal looks rather thin/light for that piece. If it were me, in addition to whichever of the other suggestions you choose to employ, I'd remove the shock plates, press them flat and then fabricate a thicker plate and weld it on the underside of those thin shock plates so the plate will remain rigid under the torque and loads it will encounter. Just my two cents on what I see from your photos.
NH69Z28RS is offline   Reply With Quote Quick reply to this message
Old Sep 21st, 13, 05:24 AM   #7 (permalink)
HwyStarJoe's Avatar
My first thought was how thin that plate looks. 40ft\lbs shouldn't be enough to bend it!
HwyStarJoe is offline   Reply With Quote Quick reply to this message
Old Sep 21st, 13, 05:37 AM   #8 (permalink)
Those are the original shock plates. I also know that there is an extra spring in there, probably put there to stiffen up weak springs before I got the car. This is the exact set-up that was on the car when I got it, except it had the original rubber spring pads. I've looked at pictures of other cars and they all have a gap between the shock plate and the spring perch. I didn't really want to have to order a new set of 4-5 leaf springs, I'd like to get this to work somehow. Thanks for all the suggestions so far, keep 'em coming.
Old Sep 21st, 13, 05:58 AM   #9 (permalink)
Though they are the original spring plates, they are now working in a modified situation (the extra leaf, the urethane spring pads). So with that in mind, if it were me and I was gonna keep the extra leaf, I'd flatten them out and beef them up which would give you perhaps the best compromise solution given the parts you have to work with.
Old Sep 21st, 13, 09:29 AM   #10 (permalink)
You where trying to compress the pad/spring combo with too much gap between the perch and plate....somethings got to give....the plate.
You could loose the pad or a spring to get it closer...or..make a plate to close the gap some.
I think it was DSE ??? that made spacers for same problem using mulit-springs in mono perches ??? Can't recall
68 Camaro~LSx ~all motor
DOUG G is offline   Reply With Quote Quick reply to this message
Old Sep 24th, 13, 06:11 PM   #11 (permalink)
What would happen if I remove one or both of the urethane spring pads? The diff would be mounted solid to the springs then.
Old Sep 25th, 13, 05:46 PM   #12 (permalink)
Could it be that you need to remove a layer of the springs so that the perch and seat are mated?
Here's a picture of the spring and perch from my 71RS when I owned it.
Kunihiro is offline   Reply With Quote Quick reply to this message
Old Sep 26th, 13, 02:50 AM   #13 (permalink)
You need some compression to hold everything. Even the pic above shows a little bow.
Old Sep 26th, 13, 08:15 AM   #14 (permalink)
Original shock plates for what? They look like first generation mono leaf plates. What year is your car?
Springs are thicker than original and urethane pads do not compress as much as original pads, so this is a custom set up. You need a custom spacer if you want to run this setup, and a thicker base plate for multileaf springs.
I don't know where your looking where every car has a gap, but you must not be looking at original or correct cars because there should be no gap.
68 Ragtop is offline   Reply With Quote Quick reply to this message
Old Sep 26th, 13, 04:40 PM   #15 (permalink)
REALLY, there shouldn't be a gap?! It makes sense to me but the car I'm using as a reference and pictures I've seen have a gap. The car is a 69, but the diff came out of a 70. I removed the original 70 spring perches which had been butchered, and welded on a new set of 69 perches. I'm thinking that to fix it properly, I should order a new set of 4-leaf springs, and some original 69 shock plate mounts.
Location
Location
First Name
» Recent Discussions
New paint care
Yesterday 07:57 AM
Last post by dhutton
Today 05:01 AM
14 Replies, 249 Views
Loony Libs & Dim Dems in...
Jan 24th, 19 01:40 PM
Last post by X-77 keith
Today 04:59 AM
1 Replies, 11,408 Views
383 refresh
Yesterday 07:55 AM
Last post by DOUG G
Today 04:47 AM
8 Replies, 203 Views
Should I put a 160...
May 17th, 20 12:09 PM
Last post by 69ss350
Today 04:37 AM
23 Replies, 790 Views
Interior redo in only 21...
Yesterday 08:49 PM
by patman2
Last post by Andrew69
Today 04:37 AM
1 Replies, 79 Views
just a picture
May 26th, 20 09:01 AM
Last post by rgwiz
Today 04:34 AM
15 Replies, 422 Views
Humpday Humor, 5/27 ......
May 27th, 20 03:11 AM
Last post by adjudimo
Today 04:25 AM
2 Replies, 202 Views
Irs $$$$
May 26th, 20 07:03 PM
by DOUG G
Today 04:17 AM
14 Replies, 467 Views
memorial day
May 23rd, 20 04:49 AM
Today 04:01 AM
18 Replies, 506 Views
69 X33 Shell
Yesterday 02:49 PM
by 427fan
Last post by ZLP955
Today 02:28 AM
3 Replies, 164 Views
