power steering squeal - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Jan 24th, 14, 04:31 PM   #1 (permalink)
I changed my power steering pump on my 1970 Camaro and when its on the ground and turned all the way to the right or left the pulley stops. Then the belt squeals. I have a March serpentine system on the car...help!!!!
demps is offline   Reply With Quote Quick reply to this message
Old Jan 24th, 14, 07:22 PM   #2 (permalink)
Re: power steering squeal
Reads like the relief valve is not releasing pressure build-up from the steering box spool valve being turned too far.
There is a stop bolt preventing over turning, ie, inside wheel should max out at 20 angle from straight ahead.
Everett#2390 is online now   Reply With Quote Quick reply to this message
Old Jan 25th, 14, 09:08 AM   #3 (permalink)
Everett thx for your reply....can you tell me where the relief valve is??? Do I change it?? thx Kevin
Old Jan 25th, 14, 09:37 AM   #4 (permalink)
Relief valve is inside pump behind high-pressure hose going out to box, the hose with a fitting.
Usually, relief valve goes with the pump.
Did the previous pump do anything?
Why was the pump changed?
Old Jan 25th, 14, 05:14 PM   #5 (permalink)
Everett,
thx again for reply....the last pump was ok...I changed it because I put in a new water pump and the power steering pump was old...lol...I need to leave things alone...I'm going to send this pump back to Summitt
Old Jan 25th, 14, 06:01 PM   #6 (permalink)
You're welcome. Reads good.
The most you can do is change oil in the old pump.
Turkey baster out the old form the reservoir, add new, disconnect the return hose and aim to the drain pan, have an assistant start and run engine to empty the reservoir, stop engine, fill reservoir, repeat until return oil is clean.
Like my late grandfather said, "If it ain't broke, don't fix it."
Location
Location
First Name
» Recent Discussions
New Member Intro - 1968...
Yesterday 08:36 PM
by Persi
Last post by Everett#2390
Today 06:38 AM
1 Replies, 98 Views
console gauge oil...
Yesterday 04:53 AM
Today 06:34 AM
14 Replies, 218 Views
Installing o2 sensor
Today 06:31 AM
Last post by lonetreecamaro
Today 06:31 AM
0 Replies, 4 Views
LS Swap Header Choice
Apr 23rd, 20 02:01 PM
Last post by Cunning69
Today 06:18 AM
46 Replies, 925 Views
Need Gas Pedal and Cable...
Yesterday 08:41 PM
Last post by Just 1 More
Today 05:16 AM
1 Replies, 90 Views
Insurance Agreed Value
May 30th, 20 08:22 PM
Last post by HawkX66
Today 05:09 AM
13 Replies, 714 Views
17" or 18" on...
May 17th, 20 10:49 AM
by dcaver
Last post by dhutton
Today 03:32 AM
36 Replies, 1,601 Views
Partial drag on...
Yesterday 07:42 AM
by wrekki
Last post by wrekki
Today 03:11 AM
12 Replies, 190 Views
Speed Warning Indicator...
Apr 26th, 20 08:11 PM
Last post by ZLP955
Today 02:29 AM
7 Replies, 270 Views
Dual exhaust...
Yesterday 08:48 PM
Last post by flat tire
Today 02:19 AM
1 Replies, 73 Views
