GForce T5 vs TKO 600 - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Jul 25th, 14, 08:04 AM   #1 (permalink)
70 Camaro...
So after putting about 500 miles on my car and a track day at road Atlanta I am very unhappy with my TKO 600. The transmission almost always grinds and misses 3rd gear at track day events. Turns out this is a common complaint online. Do a search. Also, The 1st gear ratio is simply to tall for a 3.73 rear end ( 2.87 ratio).
So... I am doing research on another transmission. As a side note, I have an auto gear M22 with super case with road race gear rations in another car. Now that is an outstanding transmission, however, it only has 4 gears and that is very limiting on top speed with a 3.73 rear. RPM will max out at road Atlanta or other road courses when on a straight away. 5th gear is needed for the straights. The auto gear M22 road race gear ratio is 2.19 first. This is excellent with Pontiac high torque engines.
Here is the M22 Road Race Gear ration, which is outstanding with a 3.42 rear end and 26 or 27 inch tires.
2.19
1.5
1.17
1
Here is the TKO 600 ratios, not nearly as good as the M22 ratios when doing track day events on a road course. There is actually no comparison in performance.
2.87
1.89
1.28
1.00
.64 (Overdrive)
After doing some research I found the GForce 5 Speed. The ratios look great. Does anyone have experience with this transmission and the install in a 2nd Gen Camaro?
2.42
1.53
1.23
1.00
.75 (Over Drive)
jtwoods4 is offline   Reply With Quote Quick reply to this message
Old Jul 25th, 14, 08:11 AM   #2 (permalink)
Re: GForce T5 vs TKO 600
FTIW: I don't think you have enough miles on the TKO to really get a grindless shift. I have used both Tko 500 and 600. I don't have anything but a stock shifter body. I think you need more miles on this gear set and make sure your clutch is releasing properly.
Just my 2 cents.
If you need pointers on the subject, I believe David Pozzi may have some suggestions. He can be found on this site.
Also if my memory serves correct, there is a road race TKO 600.
The TKO 500 has a very low first gear, 3.27:1 . Sounds like a dump truck at times in first with a 3.73 gear.
TC # 349
zdld17 is offline   Reply With Quote Quick reply to this message
Old Jul 25th, 14, 08:27 AM   #3 (permalink)
OK I can believe that. however the gear ratio is just not right for my car and what I'm doing so still tryin to find people who have experience with the G Force T5 5 speed.
Old Jul 25th, 14, 08:57 AM   #4 (permalink)
There's probably no one on here that has experience with the G Force. However, if you google it there is a ton of info from the Mustang guys.
I know it's not what you asked, but another less expensive option is to talk to Liberty Gear and see what they can do on the TKO. I know they offer a pro-shift or face-plate service, upgrade the linkage, and can most likely swap in the RR 0.82 fifth. No idea on how to fix first gear though.
'69 Camaro
500hp/538lbft
Steiner is offline   Reply With Quote Quick reply to this message
Old Jul 25th, 14, 08:59 AM   #5 (permalink)
OK thank you Steiner.
Old Jul 25th, 14, 05:20 PM   #6 (permalink)
Tom P's Avatar
The TKO does take some getting used to - especially for an "old" 4-speed guy like me.
Oversimplified for TV, but American Powertrain decribes the TKO shift pattern on the RideTech 48 hour build. scroll to about the 5 minute mark if you don't want to watch the whole thing
https://www.youtube.com/watch?featur...&v=8oR4Y_M8C8M
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline   Reply With Quote Quick reply to this message
Old Jul 25th, 14, 08:17 PM   #7 (permalink)
yes I'm familiar with the differences and shifting but what they tell you in the video simply is not true when you're on a road course it's almost like the synchros can't keep up with the transmission and it grinds going into 3rd. that's why companies like Liberty gear offer a synchronizer upgrade package to correct the issue.
Old Jul 26th, 14, 06:11 AM   #8 (permalink)
130fe's Avatar
Have you considered the close ration t-56 magnum? 2.66 first, double overdrive, no shifting issues and rated at 700 inch lbs.
Close: 2.66, 1.78, 1.30, 1.0, .80, .63
If you are running that much power and take it on a road course I wouldn't think anything but the close ratio magnum. Plus you could drive it on the street with out any issues.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline   Reply With Quote Quick reply to this message
Old Jul 26th, 14, 06:16 AM   #9 (permalink)
That does sound nice
Old Jul 26th, 14, 07:54 AM   #10 (permalink)
TC member sc68z28 uses a G-Force 5 sp trans for drag racing, don't know if it's the same one you want info on though. You might PM him and ask
BPOS is offline   Reply With Quote Quick reply to this message
Old Jul 26th, 14, 02:46 PM   #11 (permalink)
Tom P's Avatar
That's exactly what going in my '67. My TKO in the '69 has the synchro upgrade, but after driving a few T-56's I'm sold
» Recent Discussions
67 RS Headlights Doors...
May 31st, 20 07:37 PM
Last post by 1967CamaroRSSS
Today 03:11 PM
4 Replies, 182 Views
Attention 1st gen Big...
Today 01:39 PM
by LYK2ROC
Last post by Matt 69
Today 02:56 PM
2 Replies, 47 Views
Coolant overflow dumping...
Jun 2nd, 20 08:43 PM
Last post by Lonnie P
Today 02:14 PM
17 Replies, 427 Views
Insurance Agreed Value
May 30th, 20 08:22 PM
Last post by SoCal805
Today 01:59 PM
26 Replies, 1,025 Views
picture link test
Yesterday 05:46 PM
by jimsl78
Last post by Garfields Maro
Today 01:57 PM
11 Replies, 185 Views
i have a points...
Yesterday 10:45 AM
Today 01:40 PM
7 Replies, 198 Views
First time Camaro owner
Today 08:40 AM
by ForFun
Last post by Everett#2390
Today 01:10 PM
4 Replies, 81 Views
Affordable options to...
May 2nd, 20 09:40 AM
Last post by crazyshopmonkey
Today 12:21 PM
8 Replies, 353 Views
YA coded N66 SS style...
Jun 2nd, 20 11:30 AM
Last post by RSSSfanatic
Today 11:59 AM
7 Replies, 229 Views
Gap between door and...
Jun 2nd, 20 07:44 AM
by bthomas
Today 10:38 AM
7 Replies, 287 Views
