Wiring issue... - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Jul 28th, 14, 09:52 AM   #1 (permalink)
Wiring issue...
So I got my car wired to the diagram on nastyz28's website for a 74 camaro. I have a 75. The diagram is for a points car and I'm running an HEI distributor. The problem lies in what I believe the wiring from the junction block to the inside of the firewall. I can have the key out of the ignition, with it in the OFF position and the buzzer as well as light inside the car will come on with the battery hooked up. The guy who I bought the car from of course hacked all the wiring. He had a push button start switch hooked up if that helps any. Thank for any help in advance.
CSballer89 is offline   Reply With Quote Quick reply to this message
Old Oct 10th, 14, 11:16 AM   #2 (permalink)
Re: Wiring issue...
Point ignitions need a resistor. HEI does not. You don't have a resistor running anywhere in there do you?
rdobbs1977 is offline   Reply With Quote Quick reply to this message
Old Oct 17th, 14, 06:32 AM   #3 (permalink)
Re: Wiring issue...
the buzzer is going off because the little piece in the steering column/lock cylinder is grounding. The box is getting a ground signal from somewhere causing that light to stay on. The dome light always has power, gets a ground through the door switch. I'd say you have a ground problem with both.....just a matter of finding "where" it's hacked. As far as the distributor goes, make sure the HEI is getting a full 12v for power. There's two wires that go to the starter solenoid(other than the battery cable) One sends 12 volts to the solenoid for starting(the one labeled "S") the other will be labeled "R" and is supplies 12v to the old points-type distributors for starting only so you have extra volts at the coil. If you put that wire on the battery cable post of the solenoid instead of the "R" post you will be set for a full 12v(or battery power) at the HEI all the time. All this does is bypass the resistive circuit from the key(if it wasn't hacked) Hope you find the problems. I HATE wire hackers!!!
70 Camaro, tree-80-tree/700r4
69 Dart GTS 340/727
66 Buck Special the lost pro-touring project
bygblok is offline   Reply With Quote Quick reply to this message
» Recent Discussions
Attention 1st gen Big...
Today 01:39 PM
by LYK2ROC
Last post by Larger Dave
Today 02:38 PM
1 Replies, 32 Views
Coolant overflow dumping...
Jun 2nd, 20 08:43 PM
Last post by Lonnie P
Today 02:14 PM
17 Replies, 421 Views
Insurance Agreed Value
May 30th, 20 08:22 PM
Last post by SoCal805
Today 01:59 PM
26 Replies, 1,017 Views
picture link test
Yesterday 05:46 PM
by jimsl78
Last post by Garfields Maro
Today 01:57 PM
11 Replies, 183 Views
i have a points...
Yesterday 10:45 AM
Today 01:40 PM
7 Replies, 194 Views
First time Camaro owner
Today 08:40 AM
by ForFun
Last post by Everett#2390
Today 01:10 PM
4 Replies, 81 Views
Affordable options to...
May 2nd, 20 09:40 AM
Last post by crazyshopmonkey
Today 12:21 PM
8 Replies, 350 Views
YA coded N66 SS style...
Jun 2nd, 20 11:30 AM
Last post by RSSSfanatic
Today 11:59 AM
7 Replies, 228 Views
Gap between door and...
Jun 2nd, 20 07:44 AM
by bthomas
Today 10:38 AM
7 Replies, 284 Views
Partial drag on...
Jun 3rd, 20 07:42 AM
by wrekki
Today 10:21 AM
20 Replies, 374 Views
