Hot rod 350 2 lean spark plugs - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Aug 23rd, 14, 07:27 PM   #1 (permalink)
Im having a problem with my chevy 350. I put a load of money into this engine. i checked my engine spark plugs today, 2 and 8 are running on border line lean. all other spark plugs are perfectly fine. i checked my compression on each cylinder. they all seem perfectly fine. maybe 3-5 off. if that. Reason why i looked into my spark plugs was because my motor was making a weird blooping sound. I personally think it's my exhaust honestly. I haven't lost any power. it revs up like it should. Im going to buy new spark plug wires and plugs for it soon. i'll start it up and spray ether onto the intake manifold to see if i have any leaks. if i don't have any leaks at all. the only thing could be wrong is my duel plain rpm gap intake isn't distributing the fuel correctly. please post below on what you thing.
engine specs:
350 bored 40 over
msd street fire 8.5mm super conductor spark plugs
2.02 dart alum heads
voodoo cam total lift .560
1.6 rockers
high volume oil pump 60-90+ psi
9.1 cp
670 street avenger carb
forged internals, complete balanced. (manufacturing companies dont balance them on a dime like they should.)
rpm air gap intake
3k stall
th350 tranny
the motor can do 9k rpm with correct camshaft and carburetor. it's set for street use only for now. but can be set up for oval track easily.
daddyhall is offline   Reply With Quote Quick reply to this message
Old Oct 17th, 14, 06:41 AM   #2 (permalink)
Re: Hot rod 350 2 lean spark plugs
no intake out there is going to give you perfect fuel distribution to every cylinder(unless you port inject it) Odd are it's the front two plugs going lean and it's not unusual. Every now and then you'll get a rear that's lean but they tend to be fat under acceleration. Check the lash adjustment for ****s and giggles. Also, that cam is a baseline of probably 510 lift on a 1.5 rocker. Make sure your rockers are centering on the valves right. I had some problems with my Dart Iron Eagles using 1.6's. Had to play around with the guide plates quite a bit to make it all work right with no interference. If all else fails, for those two cylinders go a step or two colder on the plugs for those to holes? I bet it sounds sweet with that cam though!! Oh, and my airgap works just as good as my regular performer rpm on my little stroker motor.
70 Camaro, tree-80-tree/700r4
69 Dart GTS 340/727
66 Buck Special the lost pro-touring project
bygblok is offline   Reply With Quote Quick reply to this message
Old Oct 20th, 14, 02:46 PM   #3 (permalink)
Flat tops and 64cc chambers is 10.25:1 when you have 0.040" quench
If you have flat tops and 76cc chambers you would have 9:1 compression.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline   Reply With Quote Quick reply to this message
Old Oct 21st, 14, 06:41 PM   #4 (permalink)
What are your jet sizes and PV size? What is your altitude ? Better yet , where is Mishawaka?
TC # 349
zdld17 is offline   Reply With Quote Quick reply to this message
Old Oct 21st, 14, 08:22 PM   #5 (permalink)
Mishawaka is in Indiana.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline   Reply With Quote Quick reply to this message
Old Oct 22nd, 14, 08:58 AM   #6 (permalink)
Thanks, He is about 220' above sea level. My guess he needs to have more fuel with that air density.
Then again , may not be the issue. I am jetted for 3500 ft, when I hit the coastal areas at 10', I have to jet richer.
TC # 349
Old Oct 22nd, 14, 09:22 AM   #7 (permalink)
If that 670 is as-built, it's probably too lean. I had one that was right where it was supposed to be at wide open with less engine....355 with 76cc small valve 441 heads, flat tops, and a lot less cam (peak rwhp 263 at 5200 through a four speed). Tuning the idle mix will also have an effect on your part throttle fueling.
Primaries are 65
Secondaries are 68
'69 Camaro
500hp/538lbft
Steiner is offline   Reply With Quote Quick reply to this message
» Recent Discussions
67 RS Headlights Doors...
May 31st, 20 07:37 PM
Last post by 1967CamaroRSSS
Today 03:11 PM
4 Replies, 181 Views
Attention 1st gen Big...
Today 01:39 PM
by LYK2ROC
Last post by Matt 69
Today 02:56 PM
2 Replies, 46 Views
Coolant overflow dumping...
Jun 2nd, 20 08:43 PM
Last post by Lonnie P
Today 02:14 PM
17 Replies, 427 Views
Insurance Agreed Value
May 30th, 20 08:22 PM
Last post by SoCal805
Today 01:59 PM
26 Replies, 1,024 Views
picture link test
Yesterday 05:46 PM
by jimsl78
Last post by Garfields Maro
Today 01:57 PM
11 Replies, 185 Views
i have a points...
Yesterday 10:45 AM
Today 01:40 PM
7 Replies, 198 Views
First time Camaro owner
Today 08:40 AM
by ForFun
Last post by Everett#2390
Today 01:10 PM
4 Replies, 81 Views
Affordable options to...
May 2nd, 20 09:40 AM
Last post by crazyshopmonkey
Today 12:21 PM
8 Replies, 353 Views
YA coded N66 SS style...
Jun 2nd, 20 11:30 AM
Last post by RSSSfanatic
Today 11:59 AM
7 Replies, 229 Views
Gap between door and...
Jun 2nd, 20 07:44 AM
by bthomas
Today 10:38 AM
7 Replies, 287 Views
