1970 Camaro want to modernize - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Oct 13th, 14, 05:20 PM   #1 (permalink)
Arrow 1970 Camaro want to modernize
[IMG]http://*1916122_166467318230_3385321_n.jpeg[/IMG]
I would like to put all new led lights on the car along with hid headlights
So im just looking for advice from others that may have modernized thier camaro as well.
I'm looking for a steel cowl hood and who has best pricing for sheet metal as I need
New quarters for this car and a grill..
If you have pics please share
Thank you
I Never Said I Was The Fastest I Just Said Your Not Getting In Front Of Me
blonby is offline   Reply With Quote Quick reply to this message
Old Oct 14th, 14, 11:33 AM   #2 (permalink)
Re: 1970 Camaro want to modernize
Has anyone put any led parking lights or tail lights on their 70 Camaro??
If so please post pic and info thank you
Old Oct 14th, 14, 12:07 PM   #3 (permalink)
Vintage 68's Avatar
Wink Re: 1970 Camaro want to modernize
Helped a buddy's son do this on his 1972 last summer.
He looked at several system, including the fancy sequential units, and then bought the Dakota Digital units from Summit (under $200 IIRC with the LED type flasher also ordered).
As noted above, you'll need a 'digital' LED type flasher driver for these conversions - you're standard 'load' type flashers will not work ...
The side markers are an easy plug in conversion using an LED 194 type replacement bulb.
These can be found at lots of local chain type auto parts stores or ordered from Summit and others on line.
Be SURE to check specifications to be sure they will fit and put out the required amount of light needed - some are pretty lame
Same goes for dash and other interior lamps in many cases, you can find replacement LED bulbs for many of the locations.
The indicators, door lighting. glove box(es) and others come to mind.
1968 Convertible
Some trucks
Vintage 68 is offline   Reply With Quote Quick reply to this message
Old Oct 14th, 14, 12:35 PM   #4 (permalink)
Whatever you do please don't turn it into a FAKE RS! I've seen so many standard front end cars with the bumpers cut short. Looks weird.
If you make it into an RS at least do it right...
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
PowerWindows is offline   Reply With Quote Quick reply to this message
Old Oct 17th, 14, 06:23 AM   #5 (permalink)
there was a guy on NASTYZ28 that was doing some cool LED tail lights but I think he slipped in to darkness and quit making them. Made a really nice product though. I bit the big one and bought a Dakota Digital VHX series dash recently and will start the install on it this weekend(just finishing a motor swap too) I'll try to post some shots of it when I get done. I want to do LED's in my markers and backup lights at least but I found that the LED's I have to replace my 194 lights are really VERY dim when I put them in to the sockets on my 70. They seem to work fine in everything else I have so I don't understand where it's acting dumb. I even measured the voltage at the socket and am getting a good solid 12-13 volts depending on whether the motor is running or not. LED barkes and taillights would be great but my car seems to carry pretty good lighting just using a 3157 bulb instead of an 1157. I agree on not making a clone RS out of it too. I LOVE my full bumper car and I REFUSE to do a cowl hood. I've got plenty of motor under the stock hood. Just use a performer RPM or a performer air gap(same carb height) and a good drop-base air cleaner. Then again, some folks really like a cowl hood......... good luck with it. Always like seeing another 2nd genner out there!!
70 Camaro, tree-80-tree/700r4
69 Dart GTS 340/727
66 Buck Special the lost pro-touring project
bygblok is offline   Reply With Quote Quick reply to this message
Old Oct 17th, 14, 06:58 AM   #6 (permalink)
Andrew69's Avatar
Call the technical support at http://www.superbrightleds.com/ They will help you select the best LED's for your stock housings.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline   Reply With Quote Quick reply to this message
Old Oct 20th, 14, 02:39 PM   #7 (permalink)
You'll need a relay to make the Cruise Control work when using the silly LED brake liights.
Considering the cost of Incandescent 1156 and 1157 bulbs and their rather long life span,,,LEDs are silly!
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline   Reply With Quote Quick reply to this message
Old Nov 21st, 14, 02:33 PM   #8 (permalink)
How is the wiring on your car doing OP? I have a 70 and its wiring is quite crusty in some places. If you haven't looked into new wiring, you might wanna do that first.
kimosabi is offline   Reply With Quote Quick reply to this message
Old Nov 28th, 14, 04:23 AM   #9 (permalink)
I think you need to prioritize what to do with your car. I would think LED would be last on the list. . . .especially if you need body panel replacement. Think about suspension, steering, fuel injection and the mechanics. Good luck in what ever you do.
The Camaro Guy is offline   Reply With Quote Quick reply to this message
Old Nov 28th, 14, 07:25 AM   #10 (permalink)
69-Pace's Avatar
HID's are illegal in the states unless mounted with self levelers. Finding a wrecked Lexus that will donate the entire package would be expensive and time consuming. Why not go with sliverstar or super bright LED or halogen headlights that would be legal.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Off topic forum
Today 04:05 AM
by dhutton
Last post by slazisme
Today 08:17 PM
33 Replies, 516 Views
Looking for Some...
Today 12:21 PM
Last post by jimsl78
Today 07:58 PM
3 Replies, 123 Views
67 RS Headlights Doors...
Today 07:37 PM
Last post by 1967CamaroRSSS
Today 07:37 PM
0 Replies, 43 Views
5 years of work to get...
May 27th, 20 01:39 PM
Last post by 97 CAIVIAROSS
Today 06:57 PM
8 Replies, 384 Views
Flushing Coolant...
Today 08:30 AM
Last post by DjD
Today 06:57 PM
5 Replies, 138 Views
Installing roof rail...
Today 12:06 PM
Last post by Sauron67MM
Today 06:36 PM
3 Replies, 125 Views
Kick Panel Speakers and...
Yesterday 07:28 PM
Last post by Nantooch
Today 05:17 PM
5 Replies, 164 Views
tire valve stem lenght...
Yesterday 07:56 AM
Today 05:09 PM
1 Replies, 172 Views
Idling issue
Today 02:29 PM
by GCS
Today 05:00 PM
1 Replies, 107 Views
Insurance Agreed Value
Yesterday 08:22 PM
Today 04:39 PM
10 Replies, 242 Views
