81' Camaro Engine Swap - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Dec 17th, 14, 05:17 PM   #1 (permalink)
So I've got an 81' camaro and i want to swap engines. its only got a 229l v6 but i want to put a 454 in there. is it possible? and what all would have to be done. i would end up taking it somewhere to do it as i dont know very much about cars. im trying to figure out how much all of this would cost me taking it to a shop but i dont know what needs to be done
GBudd is offline   Reply With Quote Quick reply to this message
Old Dec 18th, 14, 03:06 AM   #2 (permalink)
Re: 81' Camaro Engine Swap
BBC frame mounts for the engine.
Remember, BBC was installed only in '70.5 & '71, I think,
so aftermarket may be a little slim.
Might consider a front motor plate.
Solid body mounts between the subframe and body.
Manual clutch Z-bar if used.
Everett#2390 is online now   Reply With Quote Quick reply to this message
Old Dec 18th, 14, 04:20 AM   #3 (permalink)
If you haven't already, checkout www.nastyz28.com, it is a forum focused on 2nd gens. Not a big deal putting a big block in a '81. I put one in my 73 which is almost identical (minor subframe differences).
I switched motor mounts and did a tranny crossmember swap (because I switched to a TH400 tranny, which is not a bad idea with a BB). You will also want to consider a smaller brake booster as you will have little to no valve cover clearance, depending upon your valve covers.
All things considered there is not a lot of cost (or difficult work) beyond the cost of the engine itself.
Phil
Full Car Media Blasting:
69TAPoser is offline   Reply With Quote Quick reply to this message
Old Dec 18th, 14, 07:16 AM   #4 (permalink)
So price wise this shouldn't be a big deal besides buying the engine and new transmission? I've got an engine and transmission priced out already. Do you guys know of any shops that do this work? I live in Colorado if that helps
Old Dec 18th, 14, 07:49 AM   #5 (permalink)
How's your rear end? Sorry, too personal lol? Seriously though, you'll want to make sure your rear end is up to the BB torque also.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline   Reply With Quote Quick reply to this message
Old Dec 18th, 14, 09:10 AM   #6 (permalink)
69&76's Avatar
You should not have problems doing that swap. I would be curious what the smog laws are in Colorado with the swap?
69&76 is offline   Reply With Quote Quick reply to this message
Old Dec 18th, 14, 09:24 AM   #7 (permalink)
I'm not sure about the smog laws. I do know a couple people with 454's so I'm sure I can do it. And my camaro has a stock rear end and there's nothing wrong with it's would you recommend upgrading that as well?
Old Dec 18th, 14, 09:32 AM   #8 (permalink)
I doubt Colorado is anything like Cali for smog laws, but you never know. Worth a look before you spend the money and time. Personally, it wouldn't matter to me either way.
For the rear end, it depends on what your plans are. If it's a 6 banger car, you more than likely have a weak single track rear end that you'll break if you hammer on it at all.
Semper Fi!
Old Dec 18th, 14, 10:35 AM   #9 (permalink)
Not critical but worth considering, as mentioned above, is "beefing" up the drive line behind the BB. I ended up going with a TH400, larger driveshaft yoke and I actually kept my 10 bolt rear posi, but welded the axle tubes to the center section (which is the weak point of a 10 bolt). Of course all of this could be overkill, depending upon your driving intent and tire choice.
Phil
Old Dec 18th, 14, 12:31 PM   #10 (permalink)
What kind of rear end should I be looking at? Is there a certain one that you guys have used? Again I am not very knowledgable with all of this.
Old Dec 18th, 14, 12:33 PM   #11 (permalink)
I also do plan on "showing it off" when I do the swap. Also what are the best kind of tires when I decide to do the swap?
Old Dec 18th, 14, 12:46 PM   #12 (permalink)
There's a lot of knowledge on this site, but when it comes to 2nd gen Camaros, you're going to want to do what 69TAPoser suggested. Hit up nastyz28 or one of the other 2nd gen sites. Rear ends aren't brain surgery to replace, but you'll want to grab the right one if you're going to do it. At least a posi 10 bolt of some kind. Again, it depends on your plans and what kind of hp the 454 you're going with has and how you're going to drive it.
Semper Fi!
Old Dec 18th, 14, 01:03 PM   #13 (permalink)
Ok I will go to the website for second gens. Thank you all for the help
Location
Location
First Name
» Recent Discussions
just a picture
May 26th, 20 09:01 AM
Last post by rgwiz
Today 04:29 AM
14 Replies, 410 Views
Humpday Humor, 5/27 ......
May 27th, 20 03:11 AM
Last post by adjudimo
Today 04:25 AM
2 Replies, 202 Views
Irs $$$$
May 26th, 20 07:03 PM
by DOUG G
Today 04:17 AM
14 Replies, 464 Views
memorial day
May 23rd, 20 04:49 AM
Today 04:01 AM
18 Replies, 500 Views
383 refresh
Yesterday 07:55 AM
Last post by limpsilver
Today 02:42 AM
7 Replies, 196 Views
69 X33 Shell
Yesterday 02:49 PM
by 427fan
Last post by ZLP955
Today 02:28 AM
3 Replies, 159 Views
Loony Libs & Dim Dems in...
Jan 24th, 19 01:40 PM
Last post by parkbrau
Today 12:45 AM
1 Replies, 11,399 Views
Hello and Help Please!
May 28th, 20 08:42 PM
by PDavid
Last post by PDavid
Yesterday 08:54 PM
6 Replies, 216 Views
Interior redo in only 21...
Yesterday 08:49 PM
by patman2
Last post by patman2
Yesterday 08:49 PM
0 Replies, 74 Views
Billet pedal pads
Yesterday 08:45 PM
by Bry68
Last post by Bry68
Yesterday 08:45 PM
0 Replies, 69 Views
