75 Camaro wiring issue - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Jan 18th, 15, 08:24 PM   #1 (permalink)
Hey everyone I have an issue with the buzzer in the car. Whenever I hook the battery up the buzzer inside the car comes on and stays on. I noticed it one day when I was outside next to the garage, not sure how long it was on or what caused it.
https://www.youtube.com/watch?v=DOMKc1X3hGM
Any tips or ideas are appreciated.
CSballer89 is offline   Reply With Quote Quick reply to this message
Old Jan 19th, 15, 05:23 PM   #2 (permalink)
yellow69RS's Avatar
Re: 75 Camaro wiring issue
My first guess is the switch that activates the buzzer in the steering column is damaged. Second choice is the wires are shorted someplace between the column and the buzzer.
The wires in the column are pink with black tracer and a black wire at the end of the T/S connector. If the black wire has continuity to ground with the door shut that is likely the problem. The pink with black comes from the buzzer to the switch in the column the Black wires goes to the door jamb switch on the drivers door (to ground when door is opened).
Jeff
yellow69RS is offline   Reply With Quote Quick reply to this message
Old Jan 19th, 15, 08:17 PM   #3 (permalink)
Just changed out the switch last month. Assuming you're meaning the ignition switch. I'll follow the wires and see if it's shorted out anywhere. Thanks.
Old Jan 20th, 15, 10:30 AM   #4 (permalink)
yellow69RS's Avatar
There is a key buzzer switch in the column. It may have been damaged at the time of the switch replacement or when the steering wheel was changed if the T/S switch was remov ed. The key buzzer switch is somewhat fragile.
http://www.ebay.com/itm/like/3711161...lpid=82&chn=ps
This says Corvette but I believe they are all the same... check into it if you have to purchase one.
Jeff
Location
Location
First Name
» Recent Discussions
Newbie seeking wisdom
Today 09:29 PM
by Cc0599
Last post by Garfields Maro
Today 10:38 PM
2 Replies, 52 Views
New emerging...
Mar 1st, 19 07:00 AM
by Gbauer
Last post by 69Z28
Today 10:35 PM
11 Replies, 106 Views
Idling issue
Today 02:29 PM
by GCS
Last post by oldschoolchevy
Today 10:22 PM
2 Replies, 118 Views
Question about valve...
Yesterday 04:54 PM
Last post by gearhead18436572
Today 10:20 PM
4 Replies, 175 Views
67 RS Headlights Doors...
Today 07:37 PM
Last post by Mike Cohen
Today 10:06 PM
1 Replies, 59 Views
Off topic forum
Today 04:05 AM
by dhutton
Last post by slazisme
Today 08:17 PM
33 Replies, 536 Views
Looking for Some...
Today 12:21 PM
Last post by jimsl78
Today 07:58 PM
3 Replies, 127 Views
5 years of work to get...
May 27th, 20 01:39 PM
Last post by 97 CAIVIAROSS
Today 06:57 PM
8 Replies, 391 Views
Flushing Coolant...
Today 08:30 AM
Last post by DjD
Today 06:57 PM
5 Replies, 145 Views
Installing roof rail...
Today 12:06 PM
Last post by Sauron67MM
Today 06:36 PM
3 Replies, 128 Views
