Squealing noise when I start my car. - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Mar 1st, 15, 09:33 AM   #1 (permalink)
Exclamation Squealing noise when I start my car.
I have a 72 Camaro. I put a 383 stroker motor in it. I just recently changed my alternator, water pump, and power steering pump along with all the pullys. I started the motor up the other day and it ran good. Then I hit up to about 3500 rpm and it started squealing. Sounded just like a belt squeal. So after looking I found it isn't a belt squeal. I took all the belts off and it steal squeals bad. Somebody said I might have spun a bearing. I took the oil filter off and checked it for metal shavings and it was clean very clean. So that ruled that out thank god. Then somebody said the starter sounds like its not disengaging but I checked that and it is. Then somebody said maybe the Transmission is low on fluid so I put some in it and its still making the same noise. It sounds just like a belt squeal but 10 times louder. If anybody has had this problem or knows how to pin point I would sure appreciate it.
Thank You, Dustin
Dustin1972Z28 is offline   Reply With Quote Quick reply to this message
Old Mar 1st, 15, 10:17 AM   #2 (permalink)
Re: Squealing noise when I start my car.
Have you checked for a vacuum leak ?
Had this before and found the carb gasket was the culprit.
68 Camaro~LSx ~all motor
DOUG G is offline   Reply With Quote Quick reply to this message
Old Mar 1st, 15, 10:21 AM   #3 (permalink)
Does it have roller lifters?
rp930 is offline   Reply With Quote Quick reply to this message
Old Mar 1st, 15, 10:28 AM   #4 (permalink)
69&76's Avatar
Have isolated the area where it is squealing from, engine, rear end, wheels, etc? Does it do it only when car is moving or at idle as well?
69&76 is offline   Reply With Quote Quick reply to this message
Old Mar 1st, 15, 12:52 PM   #5 (permalink)
Send a message via ICQ to Steptoe
invest in a elcheapo mechanics stethoscope and have a play...
Covers all the posts above.
u would have found it without having to even remove a belt...
And instead of removing a belt... wipe a little candle wax on each , one at time... or simpler still, pour a little water on each.. see when the sound disappears.
Steptoe is offline   Reply With Quote Quick reply to this message
Old Mar 9th, 15, 08:05 AM   #6 (permalink)
water pump??
Justin Novick
Sales/Support
Entropy Radiator - The Sexiest Radiators For The Sexiest Hot Rods
(773) 303-8251 -
JustinEntropyRad is offline   Reply With Quote Quick reply to this message
Old Mar 9th, 15, 01:06 PM   #7 (permalink)
Find it yet ?
» Recent Discussions
Coolant overflow dumping...
Jun 2nd, 20 08:43 PM
Last post by Lonnie P
Today 02:14 PM
17 Replies, 418 Views
Insurance Agreed Value
May 30th, 20 08:22 PM
Last post by SoCal805
Today 01:59 PM
26 Replies, 1,017 Views
picture link test
Yesterday 05:46 PM
by jimsl78
Last post by Garfields Maro
Today 01:57 PM
11 Replies, 182 Views
i have a points...
Yesterday 10:45 AM
Today 01:40 PM
7 Replies, 193 Views
Attention 1st gen Big...
Today 01:39 PM
by LYK2ROC
Last post by LYK2ROC
Today 01:39 PM
0 Replies, 27 Views
First time Camaro owner
Today 08:40 AM
by ForFun
Last post by Everett#2390
Today 01:10 PM
4 Replies, 80 Views
Affordable options to...
May 2nd, 20 09:40 AM
Last post by crazyshopmonkey
Today 12:21 PM
8 Replies, 348 Views
YA coded N66 SS style...
Jun 2nd, 20 11:30 AM
Last post by RSSSfanatic
Today 11:59 AM
7 Replies, 228 Views
Gap between door and...
Jun 2nd, 20 07:44 AM
by bthomas
Today 10:38 AM
7 Replies, 283 Views
Partial drag on...
Jun 3rd, 20 07:42 AM
by wrekki
Today 10:21 AM
20 Replies, 372 Views
