Block codes... original? - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Apr 12th, 15, 01:33 PM   #1 (permalink)
We got some of the 72 RS cleaned up today... checking the engine for originality... here is what I found:
3970014
426 73
Engine was rebuilt in 1987, hoping it the oem motor. VIN is 1Q87H2N.
I have discovered that it was originally an automatic, PO put in the 4-speed sourced from a 73 Z28 parts car.
rickwtx is offline   Reply With Quote Quick reply to this message
Old Apr 12th, 15, 02:32 PM   #2 (permalink)
Re: Block codes... original?
You have to look at the pad on the front of the motor behind the alternator. there should be numbers stamped with the last numbers of the vin of the car and a code with bigger letters. The numbers you have listed are the casting number ( I believe 3970014 is a 350) and the other looks like the date code 426 73 would be April 26, 1973. Maybe that motor came with the transmission from the parts car?? Pictures would help
never2manycamaro's is offline   Reply With Quote Quick reply to this message
Old Apr 13th, 15, 07:06 AM   #3 (permalink)
VetteFreak's Avatar
3970014
426 73
3970014 = 350 block for Camaro...70-73
1=Chevrolet
Q=Camaro
87=2dr. spt. coupe
H=350 CID V8
2=1972
N=Norwood Assy. Plant
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline   Reply With Quote Quick reply to this message
Old Apr 14th, 15, 04:06 AM   #4 (permalink)
from what I can see on the block behind the altenator...
R451308 10206CKJ
Old Apr 14th, 15, 04:15 AM   #5 (permalink)
so it looks a 350/4 from a BelAir... darn. PO pulled this engine from a 73 Z28 but I guess it wasnt the original engine in it either.
Old Apr 14th, 15, 04:18 AM   #6 (permalink)
img host
upload an image
upload img
Old Apr 14th, 15, 01:30 PM   #7 (permalink)
Vintage 68's Avatar
Wink Re: Block codes... original?
R451308 10206CKJ
so it looks a 350/4 from a BelAir... .
Suffix's can be tricky ...
And since several things in the 'Partial' (1st set of digits you list) and the Suffix are not quite as they should be there might still be some checking to do here if you are really interested in the engine origin ...
First - the pad should be carefully cleaned and then re-read using a good light source and a viewer if needed to see all the information clearly.
The following should be re-read and noted;
Partial - should have the Division and Year code ahead of the "R" you posted in the sequence.
Suffix - The "1" you posted is most likely a 'T', and is the engine assembly plant - The "CKJ" should be re-read to be sure the "J" is actually a 'J' ... From the "R" in the Partial info osted it most likely would be that.
If it is a "J" ... then this engine came from an Impala/Caprice, not a BelAir.
BelAir's received the RPO-L65 base 350 with a 2-barrel.. The only trans was a TH350, unless the optional RPO-LF6 400 with TH400 was ordered, and not many were.
The Impala/Caprices received a RPO-L48 350 with a 4-barrel, along with a TH400 auto.
Only the L6 base units received a Manual trans that year - and it was the last year any 'B' body received a manual trans ...
Hope some of this helps
1968 Convertible
Some trucks
Vintage 68 is offline   Reply With Quote Quick reply to this message
Old Apr 14th, 15, 03:54 PM   #8 (permalink)
bcm66's Avatar
Do what John says and then post the stamped data again.
It MIGHT, and I say MIGHT, be a 350 from a 1973 Chevelle built at the Arlington TX plant, but we won't know for sure until we have all of the numbers and letters. Post a pic if you can.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline   Reply With Quote Quick reply to this message
Old Apr 14th, 15, 08:32 PM   #9 (permalink)
Vintage 68's Avatar
Red face Re: Block codes... original?
Originally Posted by bcm66 View Post
... It MIGHT, and I say MIGHT, be a 350 from a 1973 Chevelle built at the Arlington TX plant, but we won't know for sure until we have all of the numbers and letters. Post a pic if you can.
Ohhhh - good call
I hadn't thought of the cross-over production at Arlington including the 'A' bodies also ...
Not sure of the numbering sequences of 'B' vs. 'A' during 73, and wouldn't bother to look up unless more was known.
1968 Convertible
Some trucks
Old Apr 15th, 15, 03:42 PM   #10 (permalink)
then partial vin on the motor pad will tell you the plant that the motor was installed . this will help .
twozs is offline   Reply With Quote Quick reply to this message
Old Apr 15th, 15, 03:51 PM   #11 (permalink)
R451308 10206CKJ
R would be Arlington , Texas
Old Apr 18th, 15, 08:12 AM   #12 (permalink)
bcm66's Avatar
Any more details on the engine numbers?
CRG -
Location
Location
First Name
» Recent Discussions
Off topic forum
Today 04:05 AM
by dhutton
Last post by slazisme
Today 08:17 PM
33 Replies, 515 Views
Looking for Some...
Today 12:21 PM
Last post by jimsl78
Today 07:58 PM
3 Replies, 123 Views
67 RS Headlights Doors...
Today 07:37 PM
Last post by 1967CamaroRSSS
Today 07:37 PM
0 Replies, 42 Views
5 years of work to get...
May 27th, 20 01:39 PM
Last post by 97 CAIVIAROSS
Today 06:57 PM
8 Replies, 384 Views
Flushing Coolant...
Today 08:30 AM
Last post by DjD
Today 06:57 PM
5 Replies, 138 Views
Installing roof rail...
Today 12:06 PM
Last post by Sauron67MM
Today 06:36 PM
3 Replies, 124 Views
Kick Panel Speakers and...
Yesterday 07:28 PM
Last post by Nantooch
Today 05:17 PM
5 Replies, 164 Views
tire valve stem lenght...
Yesterday 07:56 AM
Today 05:09 PM
1 Replies, 171 Views
Idling issue
Today 02:29 PM
by GCS
Today 05:00 PM
1 Replies, 106 Views
Insurance Agreed Value
Yesterday 08:22 PM
Today 04:39 PM
10 Replies, 241 Views
