Blue Plug comming from u14 dash WHeres it go? - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Jul 9th, 15, 02:14 PM   #1 (permalink)
Probationer
I am having problems with getting my guages to work On the u14 Stock 1981 camaro dash It had a blue Connector comming out witch looked like the main power source but my turn signals and and lights all work Just no
Speedo
Tach
oil guadge
Temp gadge
The volt meter was the only thing I could get running and it was a Single brown wire running out of the firewall by the washer moter.
I was thinking that was for the tach so i hooked it to the Distributor where it has the TAC / Battery Single Connections.
This car had a engine bay fire (Small) and the previous owner said he just Ripped apart the cords that did catch / fryed and didnt do anything els.
I cut the BLue Connector off and Tryed wireing the Red to Power in the fuse box Grouded the Black one and i was thinking the green went to the tac???
Unsure but im tackling it this week and would love to get sum insight on what people might think... I cant seem to match anything to any wireing diagrams so i think this is one of thows WIRE IT up (who gives a ****) type cases. (The guy who originaly wired it) now im stuck with a Cluister Fukkkk of a wireing disaster...
Name:	Blue connector from dash.jpg
Chinduwho is offline   Reply With Quote Quick reply to this message
Old Jul 10th, 15, 07:10 AM   #2 (permalink)
click's Avatar
Re: Blue Plug comming from u14 dash WHeres it go?
Justin, this is primarily a 1st Gen website, so I moved your question to the 2nd Gen section, as those folks might be more familiar with your issues. Us 1st gen folks have never seen all those different wires under our hoods.
click is offline   Reply With Quote Quick reply to this message
Old Jul 10th, 15, 08:29 AM   #3 (permalink)
DjD
DjD's Avatar
That is a trans speed sensor.
http://www00.mailcar.net/seo_1604202..._(81-80)_sc30/
...Dennis
DjD is offline   Reply With Quote Quick reply to this message
Old Jul 12th, 15, 09:49 PM   #4 (permalink)
Probationer
The transe speed sensor Connected to the ECM correct? The computer was ripped out of the car maybe that's why it was not hooked up
Old Jul 18th, 15, 09:57 PM   #5 (permalink)
Probationer
Well I figured Out the Issue with the Speedo it was the Gear on the Drive Train .
I looked at the gearing on the Speedo gear and the Speedo wire up to the dash it all turned clean on both ends and when it was spun it from the bottom end It moved the Cluster so I kinda figured it was nothing to do with the cluster it self After Takeing the 4 bolt of the drive train cap i was able to see the gear was total off place of had sum nice dings in it.
So I poped the u joint Droped the shaft and pulled it out Put a new one on 12.95 from lordco Lined it up with the Bullets hole And tighted it all back up. I also Suped Glued All the copper tabs on back to the circuit board . they where all floppy and the way you have to put the dash in you cant get a clear view if all the tabs went in cleanly or not.
Unfortuitly My sending unit on my gas tank is shot and the Tach is No functioning
I got the speedo working Atittle Late Already a used cluster of ebay half way here from across the world will get it this weekend :P
Old Jul 18th, 15, 09:59 PM   #6 (permalink)
Probationer
here is the gear way off !
Location
Location
First Name
» Recent Discussions
Shock recommendations...
Yesterday 11:07 AM
Last post by The Camaro Guy
Today 06:07 AM
4 Replies, 165 Views
Interior redo in only 21...
Yesterday 08:49 PM
by patman2
Last post by patman2
Today 06:07 AM
2 Replies, 95 Views
Loony Libs & Dim Dems in...
Jan 24th, 19 01:40 PM
Last post by X-77 keith
Today 05:52 AM
1 Replies, 11,445 Views
hot start issue
May 28th, 20 06:45 AM
by bills69
Last post by bills69
Today 05:51 AM
7 Replies, 222 Views
1969 Camaro RS Z/28 -...
Apr 28th, 15 07:29 AM
Last post by YJ4000
Today 05:45 AM
452 Replies, 81,826 Views
68 Inoperative Temp Gauge
Today 05:43 AM
Last post by StevieBB54
Today 05:43 AM
0 Replies, 10 Views
69 manual window...
May 28th, 20 05:27 AM
Last post by Skates_236
Today 05:26 AM
13 Replies, 213 Views
New paint care
Yesterday 07:57 AM
Last post by dhutton
Today 05:01 AM
14 Replies, 257 Views
383 refresh
Yesterday 07:55 AM
Last post by DOUG G
Today 04:47 AM
8 Replies, 211 Views
Should I put a 160...
May 17th, 20 12:09 PM
Last post by 69ss350
Today 04:37 AM
23 Replies, 794 Views
