Intake Hood clearance - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Aug 21st, 15, 12:34 PM   #1 (permalink)
Hello, As the title says. I was wondering if my intake on the engine I have recently finished building would clear a stock 71 Camaro hood!. I have finished building my 496 and It has a holley strip dominator on it right now coupled with a quick fuel 850 double pumper. I was wondering if this would clear under a factory stock 71 Camaro hood. The car is an original ls3 402 bbd car if that changes anything. If anyone has had any personal experience with this intake please let me now if you made it fit. If not what are some suggestions of intakes that would clear? Thank you for everyones help.
71SS is offline   Reply With Quote Quick reply to this message
Old Aug 21st, 15, 01:08 PM   #2 (permalink)
Re: Intake Hood clearance
Chevy used a low-rise intake on the 402 as well as the lowering motor mounts.
To add a hi-rise intake you'll need a 2" cowl hood.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline   Reply With Quote Quick reply to this message
Old Aug 24th, 15, 05:01 PM   #3 (permalink)
Dang so basically i wouldnt be able to run any kinda of hi rise single plane? Do you know if the edlbrock rpm air gap would fit ?
Old Aug 26th, 15, 01:56 PM   #4 (permalink)
Air Gap wont fit
Eldebrock Torker II 2-O and Street Master are the only 2 intakes,that I know of,that will fit under the stock hood with a BBC
Bigblock73 is offline   Reply With Quote Quick reply to this message
Old Aug 26th, 15, 06:31 PM   #5 (permalink)
Originally Posted by Bigblock73 View Post
Air Gap wont fit
dang i guess i am going to have to downgrade because i know people love the air gap and single planes for performance :/
Old Sep 1st, 15, 03:31 AM   #6 (permalink)
Both I mentioned are single plane.
Old Sep 1st, 15, 05:16 AM   #7 (permalink)
The Street Master is the "offspring" of the original Torker, came out around 1974 in it's original version. Sounds like you have the 2nd design, the first design Street master looked just like an old Torker but with smaller plenum and runners, the redesign followed a couple years later. The first design was taller and wouldn't fit under the stock hood of many of the vehicles it was intended for. They can give decent performance and fuel economy if you're willing to play with it a little, they were designed to be an RV/Mileage manifold and while it's true they are outdated if you pick one up cheap they are still serviceable. They work pretty decent to about 4500, add a plenum divider and/or play around with different thickness 4 hole spacers on them and you can extend their RPM range to 5500 and still maintain decent low end. There was a test in Car Craft where they tested all of the big block Chevy Edelbrock intakes...again..IIRC..the Torker was the worst and RPM Air Gap did the best. Another example I found was an engine with 10.1 comp, 468 Cid with a 238 duration @.050 hyd roller, if I remember right it made 608 HP and I think it hit in the 590's for TQ, the Torker II made 20 hp and 20 tq. less than the RPM air gap.
Cdminter55 is offline   Reply With Quote Quick reply to this message
Old Sep 2nd, 15, 01:48 PM   #8 (permalink)
There ain't no hood clearance if you use an Edlebrock Hi-Rise manifold with a Drop Breather plate over your Holley. 2" at the most where as the Camaro Hood is designed to accept it with a simple LT1 Scoop and cut your hood.
GM designed it that way - Just look at the Hood Bracing.
This was my 70 1/2 Z28
Z15CAM is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Off topic forum
Today 04:05 AM
by dhutton
Last post by slazisme
Today 08:17 PM
33 Replies, 525 Views
Looking for Some...
Today 12:21 PM
Last post by jimsl78
Today 07:58 PM
3 Replies, 123 Views
67 RS Headlights Doors...
Today 07:37 PM
Last post by 1967CamaroRSSS
Today 07:37 PM
0 Replies, 45 Views
5 years of work to get...
May 27th, 20 01:39 PM
Last post by 97 CAIVIAROSS
Today 06:57 PM
8 Replies, 384 Views
Flushing Coolant...
Today 08:30 AM
Last post by DjD
Today 06:57 PM
5 Replies, 138 Views
Installing roof rail...
Today 12:06 PM
Last post by Sauron67MM
Today 06:36 PM
3 Replies, 125 Views
Kick Panel Speakers and...
Yesterday 07:28 PM
Last post by Nantooch
Today 05:17 PM
5 Replies, 164 Views
tire valve stem lenght...
Yesterday 07:56 AM
Today 05:09 PM
1 Replies, 172 Views
Idling issue
Today 02:29 PM
by GCS
Today 05:00 PM
1 Replies, 107 Views
Insurance Agreed Value
Yesterday 08:22 PM
Today 04:39 PM
10 Replies, 242 Views
