12 bolt vs 10 bolt - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Apr 26th, 16, 08:22 PM   #1 (permalink)
12 bolt vs 10 bolt
I have just gotten and 75 Camaro and I'm working on a lot of little projects but one that is comeing up is rear end I started looking for a 12 bolt (8-1/2) and alittle harder to find than I thought but what I wanted to know is a 10 bolt 8-1/2 just as good. what are pro and con
thanks again Cenobitya
cenobitya is offline   Reply With Quote Quick reply to this message
Old Apr 26th, 16, 09:09 PM   #2 (permalink)
larryh56's Avatar
Re: 12 bolt vs 10 bolt
I believe the 12-bolt was only available in 1970. After that GM went to the 8.5" 10-bolt which is not quite as strong as the 12-bolt from what I have read but unless you are putting out serious HP you should be fine. Many people (including me) have put 8.5" 10-bolts in their first gens because they are easier to find and cheaper.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline   Reply With Quote Quick reply to this message
Old Apr 27th, 16, 02:48 AM   #3 (permalink)
It has been said that with a few good parts a 8.5" 10-bolt can be as strong as a 12-bolt.
I have said I don't care what axle you use, even a 2.5T Mil. axle, will break if abused too much.
Build what you have and you'll be fine
68 Camaro~LSx ~all motor
DOUG G is offline   Reply With Quote Quick reply to this message
Old Apr 27th, 16, 05:06 AM   #4 (permalink)
The 12 bolt had an 8-7/8th inch diameter ring gear. The AAW "corporate" ten bolt was introduced in 1972 which made 1971 the last year that the Spicer made 12 bolt and the 8.2" 10 bolt were offered (they had been introduced in 1965).
The 8.5 inch ring and pinion isn't as strong as the 8-7/8th inch ring gear as bigger is better. That isn't totally true as the 8.5 inch AAW made rear end uses the same size pinion as is used in the 12 bolt Spicer (same bearing size). But when it was first put under a Camaro it used the ten bolt 28 spline axles out of the earlier 8.2" ten bolt. Power levels where dropping like a stone and the muscle car era was over in 1972 with all engines being made ready to burn unleaded fuel (which didn't hit the market until 1978). Things went from bad to worse as the big block went away in all cars except the Corvette in 1973 (1974 had the last BBC powered 'vette), and engine power continued to fall. In 1994 GM authorized the use of the 12 bolt 30 spline axle in the AAW 8.5 inch rear end. So you can rebuild an 8.5 using everything except the larger ring gear out of the earlier 12 bolt. But you have to put it together, there was no bolt in Camaro rear end made that way from the factory.
Personally I use a 35 spline axle Dana 60 with Ford Torino bearings to get rid of the C-clips. that I buy from Moser to give me peace of mind. The added bonus is the inspection cover has ten bolts so it is still a ten bolt rear sort of as far as originality goes.
Big Dave
Larger Dave is online now   Reply With Quote Quick reply to this message
Old Apr 27th, 16, 07:03 PM   #5 (permalink)
thanks guys this helps me a lot
Ceno
Location
Location
First Name
» Recent Discussions
1969 right hand drive...
Feb 16th, 20 08:44 PM
Last post by Legacy 69
Today 11:05 AM
2 Replies, 243 Views
72 Rust Free start
Today 10:37 AM
by vstol
Last post by vstol
Today 10:37 AM
0 Replies, 36 Views
17" or 18" on...
May 17th, 20 10:49 AM
by dcaver
Last post by Just 1 More
Today 09:43 AM
32 Replies, 1,207 Views
Billet pedal pads
Yesterday 08:45 PM
by Bry68
Today 09:41 AM
1 Replies, 95 Views
Shock recommendations...
Yesterday 11:07 AM
Last post by EVL SS
Today 09:31 AM
7 Replies, 203 Views
New paint care
Yesterday 07:57 AM
Last post by The Camaro Guy
Today 09:09 AM
17 Replies, 327 Views
69 X33 Shell
Yesterday 02:49 PM
by 427fan
Last post by yellow69RS
Today 08:48 AM
4 Replies, 206 Views
68 Inoperative Temp Gauge
Today 05:43 AM
Last post by Everett#2390
Today 08:00 AM
3 Replies, 88 Views
tire valve stem lenght...
Today 07:56 AM
Last post by camarostrong
Today 07:56 AM
0 Replies, 71 Views
Option number 832!! :-)...
Apr 30th, 20 01:39 PM
Last post by SoCal805
Today 07:21 AM
36 Replies, 1,870 Views
