71 rear shock length - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old May 15th, 16, 07:45 AM   #1 (permalink)
trying to change rear shocks, I bought of a set of Monroe 5831's which are called out on the computer. The length of them are 20 1/2 inches. The removed shocks manufacture unknown are 22 1/2 inches with a 3 inch extension on them, with car setting in a normal attitude the new Monroe's at their extended length fit between the mounts with no means of further travel. What should I do?
Rich
podunk is offline   Reply With Quote Quick reply to this message
Old May 15th, 16, 09:20 PM   #2 (permalink)
Re: 71 rear shock length
Get a pair of air shocks.. You can decide what you want especially if it is an on board air compressor. I had a girl friend that had a Mustang with an in cabin adjustable air shock system. My old 78 Z28 had manual type. had to keep up with A/P or tires would rub out back.
budro6968 is offline   Reply With Quote Quick reply to this message
Old May 16th, 16, 09:25 AM   #3 (permalink)
You can buy a shock extension for the lower mounts. I used these when I bought rear shocks for my 80 Z28 that had springs on the shocks so the threaded mount could reach the lower mount hole.
COPO is offline   Reply With Quote Quick reply to this message
Old May 17th, 16, 08:46 AM   #4 (permalink)
you may want to try a longer shock Gabriel ultra are 21.7 extended , you might still need shock extensions as mentioned by COPO i had a set of Koni rear shocks that needed them even though the car had 2in lowering blocks .you definitely do not want a shock to bottom or in your case top out and slam the piston into one end or the other of the shock .Other then destroying the shock it could be dangerous and cause you to lose control
djgriff is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Speedtech front install...
Today 07:11 AM
by jimsl78
Last post by jimsl78
Today 07:17 AM
1 Replies, 8 Views
New Member Intro - 1968...
Yesterday 08:36 PM
by Persi
Last post by crazyshopmonkey
Today 07:16 AM
2 Replies, 107 Views
17" or 18" on...
May 17th, 20 10:49 AM
by dcaver
Last post by ilikeike
Today 07:11 AM
40 Replies, 1,622 Views
Master gage holes...
May 21st, 20 07:01 AM
Last post by tp_smith
Today 07:09 AM
6 Replies, 325 Views
1969 Camaro suspension...
Jun 2nd, 20 08:24 PM
Today 07:08 AM
16 Replies, 323 Views
Installing o2 sensor
Today 06:31 AM
Last post by 130fe
Today 07:05 AM
1 Replies, 13 Views
Need Gas Pedal and Cable...
Yesterday 08:41 PM
Last post by slazisme
Today 06:57 AM
2 Replies, 94 Views
Orig 2 brl intake and...
Today 06:55 AM
by dads67z
Last post by dads67z
Today 06:55 AM
0 Replies, 17 Views
Insurance Agreed Value
May 30th, 20 08:22 PM
Today 06:52 AM
14 Replies, 723 Views
console gauge oil...
Yesterday 04:53 AM
Last post by Everett#2390
Today 06:34 AM
14 Replies, 225 Views
