Noob question about speedo limit - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Jun 12th, 16, 04:05 PM   #1 (permalink)
the 80's camaro have 85 MPH limit at the speedo
does it means that the 1980 Camaro won't go faster then 85 MPH???
ISCamaro is offline   Reply With Quote Quick reply to this message
Old Jun 12th, 16, 04:13 PM   #2 (permalink)
69-Pace's Avatar
Re: Noob question about speedo limit
No just means the factory speedometer pegs at 85. I believe at the time it was a federal mandate. If you want you can replace the unit with aftermarket gauges, or go hi-tech with a heads up aftermarket device to display all functions on the windshield.
Here is a thread over from nastyz28 dot com: '81 Instrumentation Recommendations - NastyZ28.com
Super Moderator Team Camaro
to send me a private message
69-Pace is offline   Reply With Quote Quick reply to this message
Old Jun 12th, 16, 04:17 PM   #3 (permalink)
I like it to be as close to the origin it can get so i don't want to replace the panel.
I should get my camaro in few weeks (Shipping over seas) but I just wondered if the 85 MPH is only a visual issue or the car is really limited for 85 MPH cause it slow
Old Jun 12th, 16, 05:42 PM   #4 (permalink)
69-Pace's Avatar
Well the federal law only lasted for only a few years, passed in 79, and repealed in 81 and some manufacturers such as Audi/WV/Porsche group offered to retrofit 79,80 and 81 vehicles with 85'ers to 120 plus versions, however some manufacturers continued with the 85'ers until major redesigns of their models and that's why a few GM lines kept the lower units in production.
I think but not sure that Z28's using the same gear driven clusters after 82 had 120 mph versions that in theory would drop in no issues and be as close to factory as you would get out of the box.
There are shops re-calibrating the 85 to 120 using new face plate. So you can stay factory looking with the original mileage intact if that is important..
Old Jun 12th, 16, 05:45 PM   #5 (permalink)
I don't mind the cluster.
I'm just worried that the Camaro has limitation to pass the 85 MPH and it won't go faster
Old Jun 12th, 16, 05:54 PM   #6 (permalink)
69-Pace's Avatar
Nope, drive as fast as you want, but look in the rear-view for the blue and red flashing light every once and a while.
Old Jun 13th, 16, 04:33 AM   #7 (permalink)
As Brian suggests, it was a Federal mandate for OEM's in having 85 MPH speedo's installed.
The Feds felt it would slow people down as this is when 55 MPH speed limit came about and the gasoline crisis.
Feds thinking if speed limit is 55, why indicate higher? Let's make it less ...
Slower MPH = higher MPG = less fuel used, less emissions, blah, blah, blah ...
Everett#2390 is online now   Reply With Quote Quick reply to this message
Old Jun 13th, 16, 05:11 AM   #8 (permalink)
Classic example of why Federal mandates cause consumer's expense.
'68 rs/SS 350 M-21 posi
numbers matching
rgwiz is offline   Reply With Quote Quick reply to this message
Old Jun 13th, 16, 11:32 AM   #9 (permalink)
thanks guys!
Old Jun 23rd, 16, 04:44 PM   #10 (permalink)
Cam
Apprentice
At the time the 85 mph speedometer mandate was implemented, they did not have computer speed limiters or such devices (o.k., heavy gas-powered trucks have used governors on their old carbs). One appalling thing they did have however was the use of crappy tires that would not hold up beyond 85 mph. Tires like the Goodyear Viva & Uniroyal Zeta.
What I find ironic is that the highway speed limits are lower where I live than they were more than 40 years ago, yet tires, brakes and handling for the average car today are so much better than back in the 60s. Combine that with vigorous enforcement and punishing fines and it becomes evident that speed laws are artificially low yet the bureaucratic will to address it doesn't exist. I had heard it said by the Police that "if we raise the speed limits, people will exceed them too!" Nice logic, especially when there is now a deep fostered opinion that speed limits are artificially low and not based in a believable reality.
BTW, my license is clean.
1967 Chevelle Malibu Sport Coupe,
all stock & in family since new,
Oshawa-built
Cam is offline   Reply With Quote Quick reply to this message
Old Jul 30th, 16, 04:09 PM   #11 (permalink)
When you get your car take it to the limit and keep on. I had a 75 chevy suburban that only went to 100, I had a bunch of friends in it a while back and freaked them out when I laid in to it. The 100 mark was about the 4 O'clock position and I had it past that to around the 7 O'clock position. One guy said your going a hundred plus... aaaah good times. It had a 454 headers intake and good big carb. It was fun to drive. Just watch out for the man. or anything else that might get in your way. Drive safe....
budro6968 is offline   Reply With Quote Quick reply to this message
Old Jul 30th, 16, 05:37 PM   #12 (permalink)
69-Pace's Avatar
One note of interest since the Fed regulation for 55 was voluntary, states not accepting federal highway money did not observe it such as Nevada. And of course Canadian marketed vehicles had full functioning MPH speedometers however they reduced their speed limits in the 70's for metropolitan areas to 60 and elsewhere 70 mph - KPH after they switched over from imperial units in 1977. I'm not sure what limit if any the 81 speedos had in Canada. You can most likely have yours rebuilt for full range. Speedometer Repair Service - US Speedo
And here is a good video on swapping out old 80 for new 130 speedo.
Location
Location
First Name
» Recent Discussions
17" or 18" on...
May 17th, 20 10:49 AM
by dcaver
Last post by dcaver
Today 06:51 AM
38 Replies, 1,608 Views
1969 Camaro suspension...
Jun 2nd, 20 08:24 PM
Last post by Bruce1968
Today 06:47 AM
15 Replies, 301 Views
New Member Intro - 1968...
Yesterday 08:36 PM
by Persi
Last post by Everett#2390
Today 06:38 AM
1 Replies, 101 Views
console gauge oil...
Yesterday 04:53 AM
Today 06:34 AM
14 Replies, 219 Views
Installing o2 sensor
Today 06:31 AM
Last post by lonetreecamaro
Today 06:31 AM
0 Replies, 5 Views
LS Swap Header Choice
Apr 23rd, 20 02:01 PM
Last post by Cunning69
Today 06:18 AM
46 Replies, 925 Views
Need Gas Pedal and Cable...
Yesterday 08:41 PM
Last post by Just 1 More
Today 05:16 AM
1 Replies, 90 Views
Insurance Agreed Value
May 30th, 20 08:22 PM
Last post by HawkX66
Today 05:09 AM
13 Replies, 718 Views
Partial drag on...
Yesterday 07:42 AM
by wrekki
Last post by wrekki
Today 03:11 AM
12 Replies, 190 Views
Speed Warning Indicator...
Apr 26th, 20 08:11 PM
Last post by ZLP955
Today 02:29 AM
7 Replies, 270 Views
