78 trunk - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Oct 30th, 16, 09:59 AM   #1 (permalink)
78 trunk
I put the key in turned it to unlock, key turned but didn't unlock. Now key won't turn back and trunk won't open. Any suggestions?
geno78 is offline   Reply With Quote Quick reply to this message
Old Nov 12th, 16, 05:28 AM   #2 (permalink)
Re: 78 trunk
May try to shoot some PB Blaster in the slot. Use the little straw from a carb cleaner.. Then get a heat gun and heat the key up to see if it will turn loose. If that doesn't work. You may have to pull the rear seat out and try to unlock from in side the trunk. I have had to do that several times through the years on different cars. A really long straight slot screw driver was the tool I used to get into the lock from the back side. I don't remember if camaro's have an open slot in the back of the lock but it probably does. At least you might have some luck with the PB blaster and since the key is turned to the unlock position the lock may pop with a little nudge from inside the trunk. Good luck...
budro6968 is offline   Reply With Quote Quick reply to this message
Old Nov 12th, 16, 09:32 AM   #3 (permalink)
Might try pressing down on lid while turning key.
There is a slot in the latch, but it has the link from the lock in it. So use a 3/16 flat blade after crawling in and removing the lock holder, push out the lock, then turn latch.
Location
Location
First Name
» Recent Discussions
Irs $$$$
May 26th, 20 07:03 PM
by DOUG G
Last post by adjudimo
Today 04:17 AM
14 Replies, 461 Views
just a picture
May 26th, 20 09:01 AM
Today 04:09 AM
13 Replies, 403 Views
memorial day
May 23rd, 20 04:49 AM
Today 04:01 AM
18 Replies, 500 Views
383 refresh
Yesterday 07:55 AM
Last post by limpsilver
Today 02:42 AM
7 Replies, 195 Views
69 X33 Shell
Yesterday 02:49 PM
by 427fan
Last post by ZLP955
Today 02:28 AM
3 Replies, 159 Views
Loony Libs & Dim Dems in...
Jan 24th, 19 01:40 PM
Last post by parkbrau
Today 12:45 AM
1 Replies, 11,397 Views
Hello and Help Please!
May 28th, 20 08:42 PM
by PDavid
Last post by PDavid
Yesterday 08:54 PM
6 Replies, 214 Views
Interior redo in only 21...
Yesterday 08:49 PM
by patman2
Last post by patman2
Yesterday 08:49 PM
0 Replies, 74 Views
Billet pedal pads
Yesterday 08:45 PM
by Bry68
Last post by Bry68
Yesterday 08:45 PM
0 Replies, 69 Views
Shock recommendations...
Yesterday 11:07 AM
Last post by Mipakaco
Yesterday 08:08 PM
3 Replies, 155 Views
