What can make my car go high 12ís - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
Like Tree4Likes
  • 2 Post By Vega
  • 1 Post By Larger Dave
  • 1 Post By DOUG G
LinkBack Thread Tools
Old Feb 14th, 18, 06:39 PM   #1 (permalink)
Probationer
I have a 1979 camaro that has a 350 with a turbo 350 trans... the trans is going out to Gerb rebuilt back to stock with a shift kit I have a converter little higher than stock I have 3.73 gears with a mini spoil... the motor has a edelbrock dual plane intake a 650 holly carb headers and 65cc heads the motors out and I wanna just throw a cam in what is your guys thoughts what should I do trying to have a low budget
Frost is offline   Reply With Quote Quick reply to this message
Old Feb 14th, 18, 07:05 PM   #2 (permalink)
Vega$69's Avatar
Re: What can make my car go high 12ís
Nitrous
dale68z and wireboy355 like this.
Vega$69 is offline   Reply With Quote Quick reply to this message
Old Feb 15th, 18, 02:38 AM   #3 (permalink)
What does it run now ?
68 Camaro~LSx ~all motor
DOUG G is offline   Reply With Quote Quick reply to this message
Old Feb 15th, 18, 08:02 AM   #4 (permalink)
Physics shows f=ma
If you want more a )lower E.T.'s) then either lower your m (weight of car), or increase f (your horsepower).
Simple.
An engineering question is can you get the power you make to the ground to accelerate your car? That means you need traction (bigger stickier tires) and a functional suspension in addition to more power.
Big Dave
Everett#2390 likes this.
Larger Dave is offline   Reply With Quote Quick reply to this message
Old Feb 15th, 18, 08:26 AM   #5 (permalink)
Vega$69's Avatar
Youíll need approximately 400 hp to the rear wheels with some drag radials
Old Feb 15th, 18, 10:09 AM   #6 (permalink)
horse power and speed aint cheap
what's your budget?
what heads do you have now?
do you know the compression?
what cam you going to use?
flat tire is offline   Reply With Quote Quick reply to this message
Old Feb 15th, 18, 12:57 PM   #7 (permalink)
As suggested by Dave, cheap power gain is lost weight.
Every 100 lbs lost is basically 0.1 second gain.
Alum heads, for less weight, heads are horsrepower, less tire contact , read as less friction.
Synthetic fluids have less friction,
The list is endless.
Old Feb 15th, 18, 02:04 PM   #8 (permalink)
ilikeike's Avatar
Traction/suspension would definitely need attention to get to 12 sec I would think.
I have the HP and the weight to get there, I just don't have the tire for anything but a real good smoke show.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline   Reply With Quote Quick reply to this message
Old Feb 15th, 18, 04:04 PM   #9 (permalink)
As stated - NOS. Lots of it.
Suspension will be fine.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
1978 Liíl Red Express
69L48Z27 is offline   Reply With Quote Quick reply to this message
Old Feb 15th, 18, 04:37 PM   #10 (permalink)
Without knowing where you're at ET/MPH right now, very hard to say what you need to do/change.
Steve69SS396 likes this.
Old Feb 15th, 18, 07:42 PM   #11 (permalink)
Steve69SS396's Avatar
Dyno numbers are a terrible way to judge how quick a car is. My car ran 11.20's at 120 in a 3,400 pound car. It only made 347RWHP on a Mustang dyno and 382RWHP on a Dynojet. And it did not leave hard. The best 60 foot was 1.58 on the footbrake.
Steve69SS396 is offline   Reply With Quote Quick reply to this message
Old Feb 15th, 18, 08:51 PM   #12 (permalink)
Vega$69's Avatar
A 1.58 60í is great. And yes many other factors. If you have a 300 hp crank motor youíre not gonna see a 12.xxx
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Old Feb 16th, 18, 02:46 AM   #13 (permalink)
350HP @ 3450# should get you into the 12.8-.9s with all things being perfect. (sea level or lower air, correct stall, correct gears, shifted perfect, ETC)
Dynos, I don't trust....math I do.
11.20's @ 3450# is approx 400 RWHP +/-.
Old Feb 18th, 18, 05:42 AM   #14 (permalink)
Not sure the weight on my 67 but if I had to guess prob around 3000
or so my 355 with dart pro 1 heads and lunati .517 .543 cam with stock crank and flat top pistons did 11.76 @ 116mph with 1.67 60' rear is 3.73 gear with turbo 350 trans. Was hoping to get into 11.50's but that didn't happen
67 RS 355sbc 11.76et @ 116mph 1.67 60' Deluxe Parchment interior
Bad67355 is offline   Reply With Quote Quick reply to this message
Old Feb 18th, 18, 05:20 PM   #15 (permalink)
11.76 @ 116 still has .4 left in it.
My car is all steel except hood and without me is 3200-3250#
So you're approximately 375 RWHP.
Location
Location
First Name
» Recent Discussions
Newbie seeking wisdom
Today 09:29 PM
by Cc0599
Last post by Garfields Maro
Today 10:38 PM
2 Replies, 52 Views
New emerging...
Mar 1st, 19 07:00 AM
by Gbauer
Last post by 69Z28
Today 10:35 PM
11 Replies, 107 Views
Idling issue
Today 02:29 PM
by GCS
Last post by oldschoolchevy
Today 10:22 PM
2 Replies, 118 Views
Question about valve...
Yesterday 04:54 PM
Last post by gearhead18436572
Today 10:20 PM
4 Replies, 176 Views
67 RS Headlights Doors...
Today 07:37 PM
Last post by Mike Cohen
Today 10:06 PM
1 Replies, 60 Views
Off topic forum
Today 04:05 AM
by dhutton
Last post by slazisme
Today 08:17 PM
33 Replies, 538 Views
Looking for Some...
Today 12:21 PM
Last post by jimsl78
Today 07:58 PM
3 Replies, 128 Views
5 years of work to get...
May 27th, 20 01:39 PM
Last post by 97 CAIVIAROSS
Today 06:57 PM
8 Replies, 391 Views
Flushing Coolant...
Today 08:30 AM
Last post by DjD
Today 06:57 PM
5 Replies, 145 Views
Installing roof rail...
Today 12:06 PM
Last post by Sauron67MM
Today 06:36 PM
