Coolant hose diagram - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Feb 27th, 18, 02:11 PM   #1 (permalink)
Apprentice
I've tried searching for a coolant hose diagram on a G2 Camaro Z28 with a 350. Can anyone help me out?
The heater fan works. But I'm not getting hot air to the cabin. Apparently, the heater core was replaced once upon a time.
I'd like to have a diagram handy before I tear into the engine bay.
Master_P is offline   Reply With Quote Quick reply to this message
Old Feb 27th, 18, 02:31 PM   #2 (permalink)
Re: Coolant hose diagram
Generally, its the small hose, 5/8 inch diameter, from intake next to thermostat housing, to smaller nipple on core.
Then larger hose, 3/4 inch diameter, to water pump nipple being horizontal on pump.
All on engine are pass side.
Feel both hoses for warmth.
If both warm, then temperature door in heater is not working.
Does TEMP lever have resistance when moving?
If not, check lever behind panel is not broken and also check movement at other end of cable on heater.
If all moves, door may have become loose from its axis.
Is there air moving in other positions? DEF, FEET, DASH?
Everett#2390 is online now   Reply With Quote Quick reply to this message
Old Feb 27th, 18, 03:20 PM   #3 (permalink)
Apprentice
The engine temp gauge in the instrument cluster is stuck on high. This is a separate problem that is likely a faulty gauge. The sending unit changes resistance with the engine cold & hot.
I'll need to double-check the other items you listed. Thanks!
1979 Camaro Z28 - Custom purple
Old Feb 27th, 18, 07:21 PM   #4 (permalink)
Good sensor appears to be working.
You might check sensor pigtail and see if any voltage is registering.
No voltage, bad gauge. Let us know what happens.
You could get from the local parts store, a Haynes manual and have some reference material.
» Recent Discussions
Insurance Agreed Value
May 30th, 20 08:22 PM
Last post by SoCal805
Today 01:59 PM
26 Replies, 1,016 Views
picture link test
Yesterday 05:46 PM
by jimsl78
Last post by Garfields Maro
Today 01:57 PM
11 Replies, 182 Views
i have a points...
Yesterday 10:45 AM
Today 01:40 PM
7 Replies, 191 Views
Attention 1st gen Big...
Today 01:39 PM
by LYK2ROC
Last post by LYK2ROC
Today 01:39 PM
0 Replies, 21 Views
First time Camaro owner
Today 08:40 AM
by ForFun
Last post by Everett#2390
Today 01:10 PM
4 Replies, 80 Views
Coolant overflow dumping...
Jun 2nd, 20 08:43 PM
Last post by lonetreecamaro
Today 12:58 PM
16 Replies, 409 Views
Affordable options to...
May 2nd, 20 09:40 AM
Last post by crazyshopmonkey
Today 12:21 PM
8 Replies, 348 Views
YA coded N66 SS style...
Jun 2nd, 20 11:30 AM
Last post by RSSSfanatic
Today 11:59 AM
7 Replies, 227 Views
Gap between door and...
Jun 2nd, 20 07:44 AM
by bthomas
Today 10:38 AM
7 Replies, 281 Views
Partial drag on...
Jun 3rd, 20 07:42 AM
by wrekki
Today 10:21 AM
20 Replies, 367 Views
