Saginaw 4 speed stuck in gear - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
Like Tree1Likes
  • 1 Post By bertfam
LinkBack Thread Tools
Old Jul 18th, 18, 02:31 PM   #1 (permalink)
Probationer
I have been on a few forums now while trying to fix a reverse issue with my Saginaw 4 speed, currently in a '78 RS. It will eventually break behind the 350 I built for it, but it's all I got to work with for now.
About 1/3 times I put the car in reverse, it gets stuck "between" gears. Really don't know how else to put it. If you let out the clutch, the car doesn't lurch in any direction, it just stalls. It's like the trans is locked up, or possibly in two gears at once(?)
I have adjusted the Hurst shifter on it like 4 times.
I wouldn't mind crawling undereath to put all the shift rods back into the neutral position, except the car is too dang low to reach anything.
I have had a friend try to duplicate the problem while watching from under the car, but we can't get it stuck in gear
without the engine running.
Whenever it's stuck, prying the reverse rod back into nuetral has always fixed it. If you SMACK the shifter out of reverse, it goes into nuetral and works fine. But when I forget to smack it out of reverse, I end up stuck in places like:
My driveway
Various parking lots
Drive ins
The 1/4 mile burnout box
All of which require borrowing a jack to lift the car because I'm too stubborn to get one to keep in the car, and then waiting a half hour for the exhaust to cool off so I dont scald myself on it.
Anyway, what are some possible solutions?
The bushings are shimmed with washers, and have the slightest amount of play.
78transm is offline   Reply With Quote Quick reply to this message
Old Jul 18th, 18, 05:36 PM   #2 (permalink)
Re: Saginaw 4 speed stuck in gear
You are right it is stuck in two gear, reverse and... It is a problem with the shifter adjustment(I know you said you adjusted it) noob guess.
bigblockragtop is offline   Reply With Quote Quick reply to this message
Old Jan 31st, 19, 10:40 AM   #3 (permalink)
RAK
Probationer
It's a shifter adjustment. Change the length of the reverse rod. It's not moving far enough to disengage reverse.
Remove the shifter rod from the transmission reverse arm. Move the trans reverse arm so its as far as it can go out of reverse. Spin/Change the length of the reverse arm so it will push the trans arm positively into the released position.. Replace any worn bushings.
RAK is offline   Reply With Quote Quick reply to this message
Old Jan 31st, 19, 10:53 AM   #4 (permalink)
bertfam's Avatar
I disagree. In this case, it's the shifter itself. Read THIS regarding the symptoms and how to rebuild it. Unfortunately, most of the pictures in the links I posted back then are no longer there, but it's not that difficult to rebuild. Just take pictures of the "before" and use them to put it back together again. Also, the Inline web page is now laid out differently, so the original link is broke, but HERE'S the current one for the INL10199 kit. And even after 8 years, they're still only $22 bucks plus shipping!!
But, to get you started, here are two pictures of the shifter I just rebuilt a few months ago for my 57 Chevy (the new plates/shims are at the bottom in the second picture. The plate that causes this the most is the one that has the bends in it (the far left). After so many years, it has a tendency to flatten out, causing a lot of slop in the shifter, and therefore causing the levers to jam and get stuck when changing gears.
Ed
ID:	224445   Click image for larger version
wireboy355 likes this.
Ed B. (but you can call me Bert!)
CRG -
bertfam is online now   Reply With Quote Quick reply to this message
Old Jan 31st, 19, 11:43 AM   #5 (permalink)
Send a message via AIM to ChuckD Send a message via MSN to ChuckD
This not a Saginaw issue, but a worn out shift mechanism. Had this happen on 2 cars. It can either lock in Reverse and a forward gear, or get stuck in second. Shifter rebuild and careful adjustment is required.
69 Z-28-Glacier Blue, X-77
ChuckD is offline   Reply With Quote Quick reply to this message
» Recent Discussions
Coolant overflow dumping...
Jun 2nd, 20 08:43 PM
Last post by Lonnie P
Today 02:14 PM
17 Replies, 414 Views
Insurance Agreed Value
May 30th, 20 08:22 PM
Last post by SoCal805
Today 01:59 PM
26 Replies, 1,017 Views
picture link test
Yesterday 05:46 PM
by jimsl78
Last post by Garfields Maro
Today 01:57 PM
11 Replies, 182 Views
i have a points...
Yesterday 10:45 AM
Today 01:40 PM
7 Replies, 193 Views
Attention 1st gen Big...
Today 01:39 PM
by LYK2ROC
Last post by LYK2ROC
Today 01:39 PM
0 Replies, 27 Views
First time Camaro owner
Today 08:40 AM
by ForFun
Last post by Everett#2390
Today 01:10 PM
4 Replies, 80 Views
Affordable options to...
May 2nd, 20 09:40 AM
Last post by crazyshopmonkey
Today 12:21 PM
8 Replies, 348 Views
YA coded N66 SS style...
Jun 2nd, 20 11:30 AM
Last post by RSSSfanatic
Today 11:59 AM
7 Replies, 227 Views
Gap between door and...
Jun 2nd, 20 07:44 AM
by bthomas
Today 10:38 AM
7 Replies, 282 Views
Partial drag on...
Jun 3rd, 20 07:42 AM
by wrekki
Today 10:21 AM
20 Replies, 372 Views
