1970 speedo issue - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Jan 1st, 19, 10:16 PM   #1 (permalink)
1970 speedo issue
Hello, as a newbie to this forum, Im in a pickle with my newly aquired camaro.. the speedo is not reading correctly, and before i do anything else.. Im wondering why the speedo needle sits at 6 oclock..? way off the 0.mph mark..?? it moves up when driving but the speed is out of wack...!
Does the needle need to be forced moved to 'o'mph..?
I cannot see a needle 'stop' anywhere on this gauge..
has anyone had similar issues..?
thanks den ( from Aus )
denholden is offline   Reply With Quote Quick reply to this message
Old Jan 12th, 19, 07:20 AM   #2 (permalink)
Re: 1970 speedo issue
Yeah, somethings wrong. It should rest naturally at zero. Maybe just the needle came off sometime in the past and it was reinstalled wrong. Pretty sure I read that at 1000 rpm it should read 60MPH that this is a standard for GM speedos. You could use a strobe app and set a drill to this speed to test. Hook up a speedo cable and drive the cable with the drill.
Sent from my iPhone using Tapatalk
1970 Code 48 10 Z28 4 speed with Z87
Got it in 1978..first car i ever bought!
70lt1z28 is offline   Reply With Quote Quick reply to this message
Old Jan 12th, 19, 07:24 AM   #3 (permalink)
I have also heard that it is possible to damage a speedo this way by trying to roll the miles back with a drill. Hope thatís not true in your case
Old Jan 14th, 19, 09:09 PM   #4 (permalink)
yes I did Move needle back to Zero,..( removed dash cluster plastic screen ) seems more accurate ATM, but will test speed when I get car on road...
Old Jan 14th, 19, 09:16 PM   #5 (permalink)
So far on my camaro, I have repaired window washer pump, installed reservoir/tubes.. fixed indicator & high beam lamp, connected reverse lights, fixed passenger window winder mechanism, installed standard front coils, put air shocks on rear, will install new front seat retractable ADR belts, changed front headlights.... All to get Aussie RWC.
Love my USA Camaro.!
Old Mar 6th, 19, 08:42 PM   #6 (permalink)
Probationer
allenbradley is offline   Reply With Quote Quick reply to this message
Old Aug 11th, 19, 03:34 AM   #7 (permalink)
Hello again, Finally have my Camaro registered, speedo/ odometer working fine as can be. All good and happy. One item Im having trouble getting for my 2nd gen.. thats a lockable fuel tank cap.. anyone out there that can assist..?? there must be compatible ones somewhere that are reasonably priced..?? even from different GM models maybe that will fit..?? cheers all.!
Location
Location
First Name
» Recent Discussions
memorial day
May 23rd, 20 04:49 AM
Last post by adjudimo
Today 04:01 AM
18 Replies, 499 Views
383 refresh
Yesterday 07:55 AM
Last post by limpsilver
Today 02:42 AM
7 Replies, 194 Views
69 X33 Shell
Yesterday 02:49 PM
by 427fan
Last post by ZLP955
Today 02:28 AM
3 Replies, 159 Views
Loony Libs & Dim Dems in...
Jan 24th, 19 01:40 PM
Last post by parkbrau
Today 12:45 AM
1 Replies, 11,394 Views
Hello and Help Please!
May 28th, 20 08:42 PM
by PDavid
Last post by PDavid
Yesterday 08:54 PM
6 Replies, 214 Views
Interior redo in only 21...
Yesterday 08:49 PM
by patman2
Last post by patman2
Yesterday 08:49 PM
0 Replies, 73 Views
Billet pedal pads
Yesterday 08:45 PM
by Bry68
Last post by Bry68
Yesterday 08:45 PM
0 Replies, 68 Views
Shock recommendations...
Yesterday 11:07 AM
Last post by Mipakaco
Yesterday 08:08 PM
3 Replies, 155 Views
67 camaro Vin decoder
Yesterday 01:12 PM
by MeierDK
Last post by Garfields Maro
Yesterday 08:06 PM
6 Replies, 179 Views
Berger Chevrolet new and...
May 29th, 13 07:33 AM
by JOE58
Last post by R68gto
Yesterday 07:47 PM
5 Replies, 2,451 Views
