70 Touchy Brakes (real touchy) - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
Like Tree1Likes
  • 1 Post By KevinW
LinkBack Thread Tools
Old Jan 18th, 19, 07:44 PM   #1 (permalink)
Craig1969's Avatar
Send a message via AIM to Craig1969 Send a message via MSN to Craig1969 Send a message via Yahoo to Craig1969
I picked up a 70 RS a while back and finally getting around to driving it. First time out I almost bit the steering wheel. This rascal will STOP right now. Anyway to soften the brakes up or ides=as why the brakes are so sensitive?
Prepare to be the center of attention when you drive a first generation Camaro. You will be gawked at. Grown men & women will coo like children when you drive past. Children will scream like babies. Dogs & cats will get along. Does it get any better?
Craig1969 is offline   Reply With Quote Quick reply to this message
Old Jan 19th, 19, 04:23 AM   #2 (permalink)
KevinW's Avatar
Re: 70 Touchy Brakes (real touchy)
I assume you have power brakes. I would take a close look at your master cyl. I had an ELC which had a booster with the 1" (manual) master and the brakes were very touchy like you describe. You need to pair the power master 1 1/8" bore with a booster.
Also there is a repro master set which has a rod that is slightly longer then stock. This mostly causes brake dragging, but could be part of the issue. The cure is to grind the rod shorter by about 1/8".
rp930 likes this.
Kevin
KevinW is offline   Reply With Quote Quick reply to this message
Old Jan 19th, 19, 03:35 PM   #3 (permalink)
Craig1969's Avatar
Thanks Kevin. Yes, power disc on front. I'll pull the MC and see what it really is.
Seems I read about a similar issue on a 69 and the MCinstalled was actually the wrong one, making it very sensitive.
Old Jan 28th, 19, 05:23 AM   #4 (permalink)
You might want to look at the pads also. I had some performance metallic on one of my cars and they would really lock down especially cold. I would "ride the pedal" just to heat them up. Change to regular pads and back to normal.
kelley69 is offline   Reply With Quote Quick reply to this message
Old Jan 28th, 19, 06:25 AM   #5 (permalink)
Before you shorten the push rod, you can get an approximate idea of how much you need to shorten it by shimming out the master from the booster using some washers. In my case, .030-.050" was enough to get the right feel out of it.
Melrose RS is offline   Reply With Quote Quick reply to this message
Old Jan 28th, 19, 09:42 AM   #6 (permalink)
RAK
Probationer
I would say its the MS. If you have the 1" bore, go to the 1 1/8". I have a 71 with the 1 1/8 and the power brakes are awesome - wilwood 14" rotors and w/6 piston calipers. The brakes feel sensitive but awesome once you get familiar. Stops way better than my ' 99 c5. If they were more sensitive, I may be looking for solutions like you. One thing I would like to mention, higher vacuum increases sensitivity. I needed more vac with my cam so I added a can and it worked well. If the vac was greater - they would certainly be more sensitive. I don't think sensitivity would be effected much by push rod length. If you already have a 1 1/8 - try lowering the vacuum with a regulator or pump.
RAK is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
383 refresh
Yesterday 07:55 AM
Last post by DOUG G
Today 04:47 AM
8 Replies, 200 Views
New paint care
Yesterday 07:57 AM
Last post by Sauron67MM
Today 04:41 AM
13 Replies, 244 Views
Should I put a 160...
May 17th, 20 12:09 PM
Last post by 69ss350
Today 04:37 AM
23 Replies, 787 Views
Interior redo in only 21...
Yesterday 08:49 PM
by patman2
Last post by Andrew69
Today 04:37 AM
1 Replies, 79 Views
just a picture
May 26th, 20 09:01 AM
Last post by rgwiz
Today 04:34 AM
15 Replies, 421 Views
Humpday Humor, 5/27 ......
May 27th, 20 03:11 AM
Last post by adjudimo
Today 04:25 AM
2 Replies, 202 Views
Irs $$$$
May 26th, 20 07:03 PM
by DOUG G
Today 04:17 AM
14 Replies, 464 Views
memorial day
May 23rd, 20 04:49 AM
Today 04:01 AM
18 Replies, 506 Views
69 X33 Shell
Yesterday 02:49 PM
by 427fan
Last post by ZLP955
Today 02:28 AM
3 Replies, 162 Views
Loony Libs & Dim Dems in...
Jan 24th, 19 01:40 PM
Last post by parkbrau
Today 12:45 AM
1 Replies, 11,406 Views
