70 Camaro CalTrac Question - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Jan 30th, 19, 08:02 PM   #1 (permalink)
Craig1969's Avatar
Send a message via AIM to Craig1969 Send a message via MSN to Craig1969 Send a message via Yahoo to Craig1969
Will the CalTrac front brackets, slide in the spring sockets with the stock bushings in place or are the solid bushings mandatory for fitment?
Thx
Prepare to be the center of attention when you drive a first generation Camaro. You will be gawked at. Grown men & women will coo like children when you drive past. Children will scream like babies. Dogs & cats will get along. Does it get any better?
Craig1969 is offline   Reply With Quote Quick reply to this message
Old Jan 31st, 19, 08:59 AM   #2 (permalink)
Re: 70 Camaro CalTrac Question
Solid would be nice as less flex when torque is applied.
Old Jan 31st, 19, 10:27 AM   #3 (permalink)
RAK
Probationer
Thx
I would say no. The stock bushings are wider than the springs. The solid bushings leave room for not only the brackets, but also thick aluminum washers that mount outside the brackets. The solid bushings are at least 1/4 narrower EACH side to eave room for brackets and washers - they basically install flush with the spring eye. You are better off with the solid units anyway. I also added them to the rear mounts. (71 RS)
RAK is offline   Reply With Quote Quick reply to this message
Old Jan 31st, 19, 02:25 PM   #4 (permalink)
No, you will need to at a minimum, cut the part that sticks past the spring.
68 Camaro~LSx ~all motor
DOUG G is offline   Reply With Quote Quick reply to this message
Old Jan 31st, 19, 02:58 PM   #5 (permalink)
Craig1969's Avatar
Thanks guys, I sorta figured as much. I was trying to avoid removing the leafs.....the rear end has been shimmed and aligned...was trying not to disturb that but hey, all in a days work. Do the solid mounts add "road noise" ? Side note, I found my header leak on the 427. On the pass side, the dang a arm stud was rubbing against the header and rubbed a hole in the ceramic coated Headmans. Off it comes tomorrow for welding and a sawsall is going to contact that stud...it's 1 1/2" long, going to take a half inch off.
Location
Location
First Name
69 Camaro SB to BB Radiator and shroud question Craig1969 Heating & Cooling 6 Sep 20th, 18 09:36 PM
68 Camaro Rust Question 68 Cowboy Body Shop 0 Jul 23rd, 18 10:13 PM
1969 camaro with ac evaporator box to enter box Hardware question camaro69ss572 Restoration Corner 4 Jun 23rd, 18 08:18 PM
1967 Camaro Radius Rod Question camarodude67 Tag Team 4 Feb 9th, 18 12:05 PM
» Recent Discussions
Front Suspension Parts...
Today 01:00 PM
by DJ1969
Last post by allanjs
Today 05:37 PM
3 Replies, 51 Views
PCV valve
Today 02:00 PM
Last post by Garfields Maro
Today 05:34 PM
7 Replies, 98 Views
Muffler shield/wrap...
Yesterday 04:37 PM
by allanjs
Today 05:29 PM
12 Replies, 150 Views
LS Computer and Fuse Box...
Today 05:00 PM
Last post by pwentz3l
Today 05:00 PM
0 Replies, 11 Views
498 Stroker.... need...
Jul 10th, 19 03:47 PM
Last post by 69X11
Today 04:55 PM
13 Replies, 293 Views
Trouble removing TH350...
Today 12:02 AM
by 69rszee
Last post by SoCal805
Today 04:52 PM
13 Replies, 167 Views
Wanted - 1968 Camaro...
Jul 7th, 19 09:38 PM
by tommy68
Last post by sdphilips
Today 03:56 PM
1 Replies, 198 Views
1969 Camaro RS Z/28 -...
Apr 28th, 15 07:29 AM
Last post by newfzee
Today 03:54 PM
343 Replies, 51,906 Views
Building a street/strip...
Jul 11th, 19 09:50 PM
by YenkoSC
Last post by DOUG G
Today 03:38 PM
3 Replies, 206 Views
HELP!!! Power steering...
Jun 17th, 19 05:08 PM
Last post by Just 1 More
Today 03:16 PM
27 Replies, 639 Views
