77 engine swap question - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Mar 5th, 19, 07:15 PM   #1 (permalink)
Probationer
I picked up. up today and bought a 77 camaro with the body in solid shape with the original drivers.
It has a small block , I'm thinking a 305 and found a 454 out of a rollback I can get for around $400 or less.
the guy that owns it says it kept overheating. even after he put head gaskets on it.
I found a set of heads for it on eBay for a great price.
Would it be worth the time and effort to drop the 454 in or go with a freshly built small block? I'm not afraid of the commitment needed to complete it.'m planning on going thru the 454 anyway.
bg38 is offline   Reply With Quote Quick reply to this message
Old Mar 5th, 19, 07:39 PM   #2 (permalink)
Re: 77 engine swap question
There is no comparison between the torque of a SBC and that of a BBC. The BBC will peg your smile meter. Since the BBC was offered in a second gen through 1973 it will bolt up using factory parts.
The BBC may have a lot of scale in the block from the green yellow coolant wars. It probably needs to be bolied to clean it of grease and grime, and then baked over night at about 450 degrees to shed the scale.
Big Dave
Larger Dave is offline   Reply With Quote Quick reply to this message
Old Mar 8th, 19, 10:54 AM   #3 (permalink)
Apprentice
I wouldn't hesitate to do that swap. I'm looking to do the same on my 70. Headers, front coil springs and engine mounts and you should be on your way getting the big block in your car. You may have to put a bigger radiator in to handle the big block as well.
1970 Camaro, 355 sbc, M20 4 speed, 4.56 8.5" rear diff
Overtrained is offline   Reply With Quote Quick reply to this message
Old Mar 8th, 19, 11:05 AM   #4 (permalink)
Originally Posted by Overtrained View Post
... and engine mounts ... You may have to put a bigger radiator in to handle the big block as well.
Standard SBC motor mounts (1973 clam shell style) are unbreakable while still fitting the BBC. There is no offset with a BBC in a 1070-'79 Camaro as the steering gear box is in front of the axle where it belongs. So there is room for BBC to fit between the fenders.
Any time you increase the power level you need to add cooling capacity.
Big Dave
Location
Location
First Name
Another Big Block Swap question,,,,, Niblet Camaro Tech 27 Nov 8th, 18 11:35 AM
69 Front Engine Emblem Question Craig1969 Body Shop 2 Jul 30th, 18 07:42 PM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 09:37 AM
TKO swap driveline question JC69RSZ28 Transmission & Driveline 5 Feb 5th, 18 08:40 AM
» Recent Discussions
383 refresh
Yesterday 07:55 AM
Last post by limpsilver
Today 02:42 AM
7 Replies, 190 Views
69 X33 Shell
Yesterday 02:49 PM
by 427fan
Last post by ZLP955
Today 02:28 AM
3 Replies, 155 Views
Loony Libs & Dim Dems in...
Jan 24th, 19 01:40 PM
Last post by parkbrau
Today 12:45 AM
1 Replies, 11,387 Views
Hello and Help Please!
May 28th, 20 08:42 PM
by PDavid
Last post by PDavid
Yesterday 08:54 PM
6 Replies, 212 Views
Interior redo in only 21...
Yesterday 08:49 PM
by patman2
Last post by patman2
Yesterday 08:49 PM
0 Replies, 69 Views
Billet pedal pads
Yesterday 08:45 PM
by Bry68
Last post by Bry68
Yesterday 08:45 PM
0 Replies, 67 Views
Shock recommendations...
Yesterday 11:07 AM
Last post by Mipakaco
Yesterday 08:08 PM
3 Replies, 154 Views
67 camaro Vin decoder
Yesterday 01:12 PM
by MeierDK
Last post by Garfields Maro
Yesterday 08:06 PM
6 Replies, 176 Views
Berger Chevrolet new and...
May 29th, 13 07:33 AM
by JOE58
Last post by R68gto
Yesterday 07:47 PM
5 Replies, 2,450 Views
Ya, another yellow...
Nov 9th, 10 09:53 AM
by GTM
Last post by phils_crew
Yesterday 07:22 PM
22 Replies, 2,789 Views
