Holley Carb question - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
Like Tree3Likes
  • 2 Post By dyno jonn
  • 1 Post By X-77 keith
LinkBack Thread Tools
Old Sep 20th, 19, 07:22 AM   #1 (permalink)
Probationer
I'm new to the forum, and I have a 71 Z28 with a Holley carb 3989021. The smog mess has been removed before I bought the car. I bought it back in July, and I'm just now finding time to go through it. I took it out the other day and found its really bogging down coming out of the hole. Replaced the plugs, added some octane booster and cleaned up the carb. Still, no change. My next step is to replace the plug wires and dist cap, but before that I noticed a wire harness with a white connector on the end of it, laying on the intake. Looking around where it may be plugged into, it fit into the front of the driver's side of the carb.
Question: What's the wire harness for, and why does it plug into the carb? Is it supplying power to the choke?
(sorry for the stupidity on this....just in a learning phase on this '71)
Newt
ID:	229295   Click image for larger version
ID:	229297   Click image for larger version
newtodu06 is offline   Reply With Quote Quick reply to this message
Old Sep 20th, 19, 07:39 AM   #2 (permalink)
Re: Holley Carb question
You might want to check out your initial timing before suspecting a carburetor problem. In fact, advancing the timing a few degrees will do a lot for low end power. Also make sure the advance mechanism in the distributor is working correctly, and I'm not talking about the vacuum advance here.
As for the wire, it has little to do with engine power, only with idle and making the engine shut down without running on after the key is shut off.
Vega$69 and newtodu06 like this.
Jon N
dyno jonn is offline   Reply With Quote Quick reply to this message
Old Sep 20th, 19, 08:14 AM   #3 (permalink)
Vega$69's Avatar
Check timing before changing anything. Booster is a waste made to help stop detonation under load. Wont do anything to help bog.
Auto or manual transmission?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline   Reply With Quote Quick reply to this message
Old Sep 20th, 19, 08:17 AM   #4 (permalink)
Probationer
4 speed. M21
Old Sep 20th, 19, 11:03 AM   #5 (permalink)
X-77 keith's Avatar
Looks like a high idle for air conditioning, the wire and set up that is.
ProspectorTim likes this.
X-77 keith
X-77 keith is online now   Reply With Quote Quick reply to this message
Old Sep 20th, 19, 11:08 AM   #6 (permalink)
Rehashing everything said so far. Timing offers same advantages and shares symptoms of problems as the carb does. Timing is easiest to check and change.
As Dyno John suggested verify the weights swing free (not rusted in place) and are still held in check by springs Have not rusted in two or fallen off). The weight platfom that the weights sit on should also move in response to changing vacuum from the motor. WD-40 is your friend.
The Anti-dieseling Solenoid was part of the car's emission equipment back in the smog era The carb was running so lean that it would run on (rotating in reverse of the normal rotation) from gas spilling into the intake with throttle plates only partly closed. That solenoid allows the throttle blades to fully close when you turn off the key.
While looking for a source of a bog look to the usual suspects. Too large a cfm cab for your application, or a modified carb (say a screw in the slot for the secondary throttle blades). Usually a bog is more carb than the car needs for the RPM. My favorite fix for this issue was steeper rear gears (you probably have a 2.73 or a 3.8 under there now, with a 3.73/4.56 making a noticeable improvement in acceleration).
And like John said octane has no bearing on power. It has no affect on how the car runs at all. It can save you if you get into detonation but unless you changed something that shouldn't be an issue. Octane is fixed when you build the motor;Though adding a supercharger or a turbo can change that to where you need more octain.
Big Dave
Larger Dave is online now   Reply With Quote Quick reply to this message
Old Sep 22nd, 19, 07:13 AM   #7 (permalink)
accelerator pump adjustment or replace
bills69 is offline   Reply With Quote Quick reply to this message
» Recent Discussions
67 RS Headlights Doors...
May 31st, 20 07:37 PM
Last post by 1967CamaroRSSS
Today 03:11 PM
4 Replies, 182 Views
Attention 1st gen Big...
Today 01:39 PM
by LYK2ROC
Last post by Matt 69
Today 02:56 PM
2 Replies, 47 Views
Coolant overflow dumping...
Jun 2nd, 20 08:43 PM
Last post by Lonnie P
Today 02:14 PM
17 Replies, 427 Views
Insurance Agreed Value
May 30th, 20 08:22 PM
Last post by SoCal805
Today 01:59 PM
26 Replies, 1,025 Views
picture link test
Yesterday 05:46 PM
by jimsl78
Last post by Garfields Maro
Today 01:57 PM
11 Replies, 185 Views
i have a points...
Yesterday 10:45 AM
Today 01:40 PM
7 Replies, 198 Views
First time Camaro owner
Today 08:40 AM
by ForFun
Last post by Everett#2390
Today 01:10 PM
4 Replies, 81 Views
Affordable options to...
May 2nd, 20 09:40 AM
Last post by crazyshopmonkey
Today 12:21 PM
8 Replies, 353 Views
YA coded N66 SS style...
Jun 2nd, 20 11:30 AM
Last post by RSSSfanatic
Today 11:59 AM
7 Replies, 229 Views
Gap between door and...
Jun 2nd, 20 07:44 AM
by bthomas
Today 10:38 AM
7 Replies, 287 Views
