electrical, radio etc 1972 RS - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Oct 22nd, 19, 12:07 PM   #1 (permalink)
Team
here is what I purchased with the car. unknown how long of an issue
the dome light and any under the dash do not work, no power, when door is open or light switch is activated. Rear defogger does not work, cig. lighter does not work,(no power on wires) amfm radio does not work. Door buzzer does work. all items are located in same area of dash, wonder is they are common on the wiring harness? all fuses are fine. anyone got any guesses
with the proximity to each other, I suspect a power issue common with all like a trunk line. fuse has power in fusebox. any experience would be appreciated.
mikess68 is offline   Reply With Quote Quick reply to this message
Old Oct 22nd, 19, 01:38 PM   #2 (permalink)
Re: electrical, radio etc 1972 RS
How are you finding out you have no power ?. Just from things not working or ?.
How did you figure out all of the fuses were good ?.
You need to get a meter to see what's going on. Visually checking a fuse will not show if the fuse element on a glass fuse is blown under an end cap or if there is an issue of the transfer of power from the fuse block clips to the fuse and then back out of the fuse to the other clip.
On dome lights, the orange is a constant 12V and the white wire if grounded will complete the circuit and have the bulb come on (and providing the bulb and related connections are good).
On the rear defogger, is it a factory installed, dealer installed,or an aftermarket ?. Some defoggers plugged into a specific male terminal in the middle of the fuse block and maybe it got pulled out ?.
On the radio, is it factory or aftermarket ?. If it is an aftermarket,can you supply the model number or any wiring info about it ?.
I know more questions than replies but we just need more input from your end .
SOA-Nova is online now   Reply With Quote Quick reply to this message
Old Oct 22nd, 19, 04:32 PM   #3 (permalink)
In adding to Nova's suggestions, it may be the firewall connectors are corroded, or not getting power through the connection.
As Nova suggested, measure power on each fuse end. Should have power on both sides.
Sometimes the clip needs squeezing after fuse is removed.
Everett#2390 is online now   Reply With Quote Quick reply to this message
Old Oct 23rd, 19, 11:37 AM   #4 (permalink)
fuses are hot on both sides, 12v voltage tester. lighter socket dead, factory rear defogger with factory switch on dash, dead, dome light wires, dead. radio has the dashboard light on, but power to radio not checked yet, will try this weekend. nothing changes when turned on or off(I know, but could not reach the power cord with the tester last time and was quite pissed at the other deads, so figured might be the same. thought about running a new hot wire If I can figure out best spot to intersect it for all the items listed.
(also car is a survivor, unrestored, one owner, and appears no one other than me has been under the dash) so pretty much factory ever thing.
Old Oct 23rd, 19, 11:39 AM   #5 (permalink)
p/s do you take the radio out through the glove box or take out the console?
Old Oct 23rd, 19, 03:22 PM   #6 (permalink)
The radio can be removed between the console and glovebox.
It can be dropped down to floor in front of console, then pulled out through the side.
Glovebox can be removed easier than the console, just be careful as cardboard is 50+ years old.
GM lighters are always hot with keys off.
Radio dial light comes on when radio is turned on, I think, regardless if light switch is ON.
Location
Location
First Name
» Recent Discussions
Vin Question
Yesterday 08:22 PM
Last post by 57s67RS/SS
Today 07:23 AM
2 Replies, 129 Views
Speedtech front install...
Today 07:11 AM
by jimsl78
Last post by jimsl78
Today 07:17 AM
1 Replies, 24 Views
New Member Intro - 1968...
Yesterday 08:36 PM
by Persi
Last post by crazyshopmonkey
Today 07:16 AM
2 Replies, 109 Views
17" or 18" on...
May 17th, 20 10:49 AM
by dcaver
Last post by ilikeike
Today 07:11 AM
40 Replies, 1,623 Views
Master gage holes...
May 21st, 20 07:01 AM
Last post by tp_smith
Today 07:09 AM
6 Replies, 329 Views
1969 Camaro suspension...
Jun 2nd, 20 08:24 PM
Today 07:08 AM
16 Replies, 325 Views
Installing o2 sensor
Today 06:31 AM
Last post by 130fe
Today 07:05 AM
1 Replies, 16 Views
Need Gas Pedal and Cable...
Yesterday 08:41 PM
Last post by slazisme
Today 06:57 AM
2 Replies, 95 Views
Orig 2 brl intake and...
Today 06:55 AM
by dads67z
Last post by dads67z
Today 06:55 AM
0 Replies, 20 Views
Insurance Agreed Value
May 30th, 20 08:22 PM
Today 06:52 AM
14 Replies, 723 Views
