Camaro Vibration ?? - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
Like Tree2Likes
  • 1 Post By 3d cad
  • 1 Post By denholden
LinkBack Thread Tools
Old Jan 1st, 20, 02:01 AM   #1 (permalink)
Unhappy Camaro Vibration ??
Having some Vibration in my 70 Camaro 383 stroker/3550 Tremec 5sp. which starts around 3000RPM .. then goes away when I reach 4000RPM...?? (strange) its just annoying, when I give it throttle, otherwise car goes great when I'm cruising..
Ive been reading lots of opinions, but not with my problem..??
any ideas folks..?
Thanks in advance..
denholden is offline   Reply With Quote Quick reply to this message
Old Jan 1st, 20, 03:43 AM   #2 (permalink)
Re: Camaro Vibration ??
where does it seem to be? front, rear seat of your pants
it could be ANYTHING from a bad wheel bearing to a u joint
need more info
flat tire is offline   Reply With Quote Quick reply to this message
Old Jan 1st, 20, 07:46 AM   #3 (permalink)
3 to 4K in any gear or only in top gear? If in top gear, recreate the problem and quickly shift into neutral and see if it goes away when the rpmís drop. If so, the issue is with the engine. If not, itís with the trans or driveshaft, most probably the driveshaft.
Sent from my iPhone using Tapatalk
1970 Code 48 10 Z28 4 speed with Z87
Got it in 1978..first car i ever bought!
70lt1z28 is offline   Reply With Quote Quick reply to this message
Old Jan 1st, 20, 10:20 PM   #4 (permalink)
I will update soon with more info.... I looked under car and noticed DS had a sticker from 'Keisler engineering' Dynamic Balancing Certified..(Knoxfield TN) so I presume it is Balanced correctly.. do you think.?
Thanks for the replies guys.. cheers.
Old Jan 2nd, 20, 05:23 AM   #5 (permalink)
Is the car lowered? If it is I would suspect driveline angles. Tremec has an app for checking them if I remember right.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline   Reply With Quote Quick reply to this message
Old Jan 2nd, 20, 11:58 AM   #6 (permalink)
Here's a good info on drive line vibrations. Be sure to read the end
statement titled "Checking to see if you have got it correct".
https://www.hotrodhotline.com/md/htm..._harmonics.php
my 67' build thread:
allanjs is offline   Reply With Quote Quick reply to this message
Old Jan 2nd, 20, 02:32 PM   #7 (permalink)
Neat article Al. I never heard about preload before.
I did see a car, with the same symptoms I think, that was claimed to have a driveshaft that was slightly too long. It got weird under acceleration. He took a cut off wheel to the slip yoke. not exactly my kind of fix.
allanjs likes this.
3d cad is offline   Reply With Quote Quick reply to this message
Old Jan 2nd, 20, 03:15 PM   #8 (permalink)
Eliminate the obvious things first. Check your tires and make sure they are balanced. Then check u-joints. I suspect a U-joint or drive shaft as others have stated... and just because the driveline was certified as balanced doesn't mean it didn't throw a balancing weight since then.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline   Reply With Quote Quick reply to this message
Old Jan 2nd, 20, 08:50 PM   #9 (permalink)
Thanks for all the tech tips, I will keep up with developments and forward the results..
Camaro was originally lowered front and rear with 2" Hotchkis front springs and rear leaves were sagging.. I had to raise front with stock springs for Roadworthy(here) and raised rear with air shocks,,plus 2 new rear BFG tires .. car still looks level just higher..
This is all Ive done, but not sure if vibration was there originally..?? I had car imported fro USA.
Old Jan 3rd, 20, 06:00 AM   #10 (permalink)
While you're checking the simple stuff, make sure the u-bolt straps holding the u-joint caps to the pinion flanges aren't torqued too tight as this can cause the u-joint to bind. Should be torqued to about 17 lb-ft I think. Easiest way to do this is to tighten the nuts on the u-bolts until the lock washer just compresses and add 1/8 turn more.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline   Reply With Quote Quick reply to this message
Old Jan 3rd, 20, 06:45 AM   #11 (permalink)
If you raised the rear end two inches with air shocks you significantly changed your driveline angles. Time for some driveline angle measuring imho...
Old Jan 3rd, 20, 05:07 PM   #12 (permalink)
Ive checked drive line angles.. with tremec app..car level.. from front crank pulley/DS/bottom horizontal diff yoke. All passed with 'Driveline Operating angle' reading 00.2
A bit more testing coming up..
will update more soon..
Cheers all.
dhutton likes this.
Old Jan 6th, 20, 01:36 AM   #13 (permalink)
Just an update... weather has been bad haven't got car out yet, but did some checking underneath, checked D/S run-out but only diff end 0.010. And center 0.025.
Also noticed at Tranny, shaft uni had about 1+ inch clearance on passenger side hump, and heaps on Drivers side..? so I measured engine and found it a bit on an angle, like its twisted a bit..? is this normal.? or cause any issues with drive line vibration..?? Seems if engine/tranny mounts are all standard bolt up, this must be normal..? Can somebody check their own Camaro if they have a Tremec 5sp..?
Hope to get car out soon.
cheers talk soon.
Old Jan 7th, 20, 12:06 AM   #14 (permalink)
got car out today, after a plug lead repair.
I might still get tail-shaft checked to be safe... But I put the boot into it again, and really
any vibration that came up was minimal and doesnt last long, so it mught be just the engine power coming up... then smoothing out.. doesnt seem to vibrate in idle up to 4000rpm.
cheers all you guys. thanks for all the input, I will remember it all.
Location
Location
First Name
» Recent Discussions
Idling issue
Today 02:29 PM
by GCS
Last post by oldschoolchevy
Today 10:22 PM
2 Replies, 117 Views
Question about valve...
Yesterday 04:54 PM
Last post by gearhead18436572
Today 10:20 PM
4 Replies, 174 Views
67 RS Headlights Doors...
Today 07:37 PM
Last post by Mike Cohen
Today 10:06 PM
1 Replies, 55 Views
New emerging...
Mar 1st, 19 07:00 AM
by Gbauer
Last post by rogerh
Today 10:04 PM
10 Replies, 98 Views
Newbie seeking wisdom
Today 09:29 PM
by Cc0599
Last post by Cc0599
Today 09:40 PM
1 Replies, 21 Views
Off topic forum
Today 04:05 AM
by dhutton
Last post by slazisme
Today 08:17 PM
33 Replies, 533 Views
Looking for Some...
Today 12:21 PM
Last post by jimsl78
Today 07:58 PM
3 Replies, 126 Views
5 years of work to get...
May 27th, 20 01:39 PM
Last post by 97 CAIVIAROSS
Today 06:57 PM
8 Replies, 388 Views
Flushing Coolant...
Today 08:30 AM
Last post by DjD
Today 06:57 PM
5 Replies, 145 Views
Installing roof rail...
Today 12:06 PM
Last post by Sauron67MM
Today 06:36 PM
3 Replies, 128 Views
