Engine losing power at highway speed - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old May 2nd, 20, 12:50 PM   #1 (permalink)
Apprentice
I've been having a bit of a fuel (I assume) issue for a while now but it's been getting worse lately. Previously, the car would start to lose power and sort of surge at about 80mph. This wasn't that big of an issue to me until it started doing it at about 60mph recently.
I thought that something may have been clogging the fuel lines, so I switched out the sending unit in the gas tank because it still had the original one from 1978, and it still acted funny at highway speed. My next attempt at a solution is to install an 5psi electric fuel pump, but still wanted to get thoughts on other things that may be causing the issue.
It's a 1978 Camaro with the 305ci engine. I installed a more aggressive cam, intake, and a 4 barrel quadrajet. Engine runs great until it gets to higher speed. Timing is correct and even had a shop confirm it recently.
Any thoughts?
MulletMachine is offline   Reply With Quote Quick reply to this message
Old May 2nd, 20, 01:38 PM   #2 (permalink)
X-77 keith's Avatar
Is your gas cap venting? Could possibly be that simple. Does it die completely? Or just stumble?
X-77 keith
X-77 keith is online now   Reply With Quote Quick reply to this message
Old May 2nd, 20, 03:28 PM   #3 (permalink)
Apprentice
Re: Engine losing power at highway speed
If it's as simple as the gas cap venting I'll be ecstatic, i'll take a look at it
It stumbles more than dies, but it has gotten to a point to where it shut off on me and refused to start back up
Essentially, when I'm gradually pushing down on the gas, it'll get to a point where it seems like it's only getting intermittent fuel to the motor (probably 1 second increments), and if I keep pressing on the gas, it'll get unresponsive until I back off the gas and drive it a bit more conservatively
Old May 2nd, 20, 03:31 PM   #4 (permalink)
Clogged catalytic converter?
Jon N
dyno jonn is offline   Reply With Quote Quick reply to this message
Old May 2nd, 20, 03:32 PM   #5 (permalink)
What happens at 60mph with the engine surging... and you push on the gas pedal to accelerate?. Does the surge go away?... or get worse?
If the surge goes away on acceleration... but surges on cruise/light throttle, try disconnecting the vacuum advance line to the distributor and plugging the vacuum line with something. Test drive the car again trying to duplicate the condition where the engine surges.
- If the surge goes away, your distributor's vacuum advance is providing too much advance.
Are you running an HEI distributor?... If so, stock or aftermarket?
oldschoolchevy is offline   Reply With Quote Quick reply to this message
Old May 2nd, 20, 03:39 PM   #6 (permalink)
Apprentice
I wouldn't assume so but you never know. I will say that it's got a whole in it and occasionally will spit out some black soot when I start it up
Old May 2nd, 20, 03:42 PM   #7 (permalink)
Apprentice
I should've worded it better. It's doing the opposite of surging. It's intermittently losing power (roughly 1 second intervals) when I try to get it up to speed. When I try to get on the gas more at that point, it'll basically nose over and lose power until I back off the gas.
I'm running an HEI distributor and I assume it's not the factory one, but I don't know for sure. The person that owned the car before me passed away before I even got it
Old May 3rd, 20, 05:42 AM   #8 (permalink)
You stated you checked the fuel lines for blockage and you're running a quadrajet. I suspect your carb has an internal filter (sintered bronze like Holley?). Did you check/replace it? Assuming you have some sort of inline filter too, try removing the filter in the carb and run the car to see if it makes any difference. Could you have stuck fuel floats and is the float level set correctly?
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline   Reply With Quote Quick reply to this message
Old May 3rd, 20, 06:07 AM   #9 (permalink)
carb float level ?
bills69 is offline   Reply With Quote Quick reply to this message
Old May 4th, 20, 11:41 AM   #10 (permalink)
Apprentice
May be the carb float level as y'all have suggested, I'm gonna take a look at it tomorrow and see if helps
Old May 5th, 20, 06:37 PM   #11 (permalink)
davidpozzi's Avatar
If it's a quadrajet, it has a tiny fuel filter in it. Change the filter but use caution with the threads of the fitting. It's large, and has super fine threads. It's easy to cross thread the fitting. It also has a thin clear plastic seal on the end of the steel fitting. Take care to not lose it.
davidpozzi is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Installing o2 sensor
Today 06:31 AM
Last post by 130fe
Today 07:05 AM
1 Replies, 11 Views
Need Gas Pedal and Cable...
Yesterday 08:41 PM
Last post by slazisme
Today 06:57 AM
2 Replies, 94 Views
Orig 2 brl intake and...
Today 06:55 AM
by dads67z
Last post by dads67z
Today 06:55 AM
0 Replies, 5 Views
17" or 18" on...
May 17th, 20 10:49 AM
by dcaver
Today 06:53 AM
39 Replies, 1,616 Views
Insurance Agreed Value
May 30th, 20 08:22 PM
Last post by ilikeike
Today 06:52 AM
14 Replies, 721 Views
1969 Camaro suspension...
Jun 2nd, 20 08:24 PM
Last post by Bruce1968
Today 06:47 AM
15 Replies, 313 Views
New Member Intro - 1968...
Yesterday 08:36 PM
by Persi
Last post by Everett#2390
Today 06:38 AM
1 Replies, 103 Views
console gauge oil...
Yesterday 04:53 AM
Today 06:34 AM
14 Replies, 221 Views
LS Swap Header Choice
Apr 23rd, 20 02:01 PM
Last post by Cunning69
Today 06:18 AM
46 Replies, 925 Views
Partial drag on...
Yesterday 07:42 AM
by wrekki
Last post by wrekki
Today 03:11 AM
12 Replies, 191 Views
