2001 Cammaro has no power going up hills - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Feb 18th, 07, 03:27 PM   #1 (permalink)
My 2001 automatic Camaro started acting up a few days ago. When starting up hills it has little power. I checked the transmission fluid and it was low. I added some to it and that helped some. When giving the car gas it seems like the engine is working properly it just doesn't seem to accelerate like it should. Any suggestions on what could be wrong?
syk_pky_dfugate1 is offline   Reply With Quote Quick reply to this message
Old Feb 18th, 07, 05:00 PM   #2 (permalink)
Re: 2001 Cammaro has no power going up hills
sky,
From your question, it sounds like you are not real familiar with car terms. I would suggest having somebody test drive the car and tell you what they think. It sounds like the transmission might be slipping pretty badly, which can result in an enegine failure as well. Take it to a trans shop and have them drive it. Does your car have a tachometer ? If so, what is it indicating when you have the problem ?
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline   Reply With Quote Quick reply to this message
Old Feb 18th, 07, 11:18 PM   #3 (permalink)
19HoosierDaddies67's Avatar
Send a message via MSN to 19HoosierDaddies67
Just another suggestion. It could be your catalytic converter. I had a company Dodge van that really bogged down going up hills, I could only go 35-40 mph, the rest of the time it ran well. I took it to the Dodge dealership and they replaced the Cat. Van ran great after that.
1967 Convertible Camaro
Member of Cool Runnin Camaros:
19HoosierDaddies67 is offline   Reply With Quote Quick reply to this message
Old Feb 21st, 07, 07:01 PM   #4 (permalink)
i was thinking a cat. converter also. being it is a 2001 it may still covered under an emissions warranty. the warranty is 8yrs\80,000mi. it would be covered it the car was setting a cat. efficiency code, but I can't say for sure if it covers plugged cats.
lukeciffer is offline   Reply With Quote Quick reply to this message
Old Feb 22nd, 07, 05:04 PM   #5 (permalink)
Z28 Mark's Avatar
Arrow Re: 2001 Cammaro has no power going up hills
You know about the letter from GM about the catalyst converters and the recall / extended warranty on a lot of the 4th gens… Check out this thread in this section:
https://www.camaros.net/forums/showthread.php?t=95998
Mark (AKA Z28 Mark)
1973 Z28 2001 Z28
Camaros Limited~Nor Cal
Z28 Mark is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
Power Top Switch 327!275hp!Convt! Convertibles 13 Jan 23rd, 07 06:10 AM
overlap, and stock idle L79Mike Performance 13 Jan 21st, 06 09:23 PM
Correct power steering pump and pulley for 69 Z28 jlighthart Engine 0 Nov 15th, 04 02:52 AM
2001 chevy silverado power steering pump jeff8428 Brakes, Suspension & Steering 3 Nov 4th, 03 06:09 PM
Power Steering / Belt Alignment Problem kgaffney Tech 2000 17 Jul 9th, 01 04:36 PM
» Recent Discussions
frustration with...
Yesterday 04:55 PM
Last post by X-77 keith
Today 03:23 AM
5 Replies, 115 Views
Steering Arm Problem 68...
Yesterday 02:18 PM
Last post by 130fe
Today 02:02 AM
1 Replies, 72 Views
69 Camaro with Dart 406"...
Yesterday 10:41 AM
Last post by friendlyviper
Yesterday 08:38 PM
6 Replies, 132 Views
What do these two black...
Sep 10th, 19 01:32 PM
Last post by 67sc
Yesterday 08:18 PM
12 Replies, 376 Views
Passenger door side view...
Sep 8th, 19 10:38 AM
Last post by 69Z28
Yesterday 07:10 PM
22 Replies, 531 Views
67 camaro smog pump...
Yesterday 06:08 PM
by Niblet
Last post by Niblet
Yesterday 06:08 PM
0 Replies, 58 Views
Wiring HEI distributor...
Jul 7th, 19 12:05 AM
Last post by graeme
Yesterday 05:59 PM
14 Replies, 581 Views
Adding...
Yesterday 05:57 AM
Last post by SOA-Nova
Yesterday 05:52 PM
3 Replies, 118 Views
Buying a 68-69 Camaro 350
Sep 8th, 19 10:41 PM
Last post by kookykrispy
Yesterday 05:37 PM
13 Replies, 436 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Yesterday 05:17 PM
5 Replies, 169 Views
