3.4 V6 paired misfire? - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Apr 21st, 07, 08:03 AM   #1 (permalink)
I posted this on a V6 Camaro/Firebird board but I thought I'd throw it out here as well.
'94 Camaro 3.4
It has a misfire on #3 & #6. I can actually see the random misfire by connecting my timing light to those two plug wires. All other cyls are smooth as can be. Plugs and wires are okay.
I replaced the 3-6 coil with no results.
Replaced the ignition module, no change after that either.
Removed the harmonic balancer and inspected the relucter for damage, it was okay.
What else could cause the 3-6 coil to randomly misfire? Seems like the cam or crank sensors wouldn't just pick on this one coil or am I wrong to think that.
Thanks for any help.
Edit: I should also mention the car has been diagnosed at a Chevy dealer and a local Auto repair shop and neither could determine a problem with their scans.
Robert
TC member #18
rojo is offline   Reply With Quote Quick reply to this message
Old Apr 21st, 07, 11:25 AM   #2 (permalink)
Re: 3.4 V6 paired misfire?
possibly a dis module...maybe you could trade yours with a friend for a day to diagnose, cause they`re kinda expensive to replace, and find out it still doesnt work right...lol...
kustomwerker is offline   Reply With Quote Quick reply to this message
Old Apr 21st, 07, 11:47 AM   #3 (permalink)
I replaced the Ignition Module. Is this the same thing you are calling the dis module?
http://www.partsamerica.com/ProductD...pe=194&PTSet=A
Robert
TC member #18
Old Apr 21st, 07, 11:53 AM   #4 (permalink)
The quickest route to determining where the miss is coming from is to hook on to a lab scope and view the spark lines for each cylinder. If you have someone who actually knows what they are looking at when you do it they should be able to determine fairly quickly as to it being air or fuel related or coil/wire/plug related or so on and so forth.
NEVER argue with a stupid person. They bring you down to their level, and then beat you with experience.
bighaas79 is offline   Reply With Quote Quick reply to this message
Old Apr 23rd, 07, 03:29 PM   #5 (permalink)
if you can see the miss in a timing light, then its in the ignition, and not the air/fuel...yes, the module you replaced is what i`m calling the dis(distributorless ign module)sorry...i read right past that...i dont think the cam sensor will have any effect on the 3-6 skip you`re experiencing...you said the pick-up ring was good, so i dont think the crank sensor would do this either...usually whan a crank sensor is doing this, there is metal inbetween the grooves of the pick-up ring...the sensor will then pick up 1 long signal for a shared coil, and randomly miss between paired cyls...
Old Apr 24th, 07, 07:00 AM   #6 (permalink)
Thanks for the replies. I read somewhere on the net where the interrupter ring (I called it relucter by mistake above) could become magnetized on certain blades and could actually cause my problem. So I pulled the balancer once more to check and it was not magnetized. I'm going to replace the 24x crank sensor while I have the balancer off even though like you I don't really see how it could pick on just one coil. It's $29.00 so it might be worth it just to take it out of the equation.
Robert
TC member #18
Location
Location
First Name
94 3.4 differencial upgrade! airdoc Performance 1 Dec 4th, 06 06:01 PM
1995 3.4 camaro..HEAD GASKET HELP! cadgod_1 Engine 2 Oct 6th, 06 09:43 AM
94 camaro (3.4 v6 distr~LESS) HELP!!!!!!!!!!! akattypeturbo Troubleshooting 1 Jan 19th, 06 08:57 PM
Chevy 3.4 DOHC life expectancy? travis Bench Racing 9 Aug 4th, 05 12:45 PM
misfire on cylinder 5 WykedRyk Troubleshooting 11 Jul 16th, 02 02:37 PM
» Recent Discussions
Alternator Wisdom?
Today 01:49 PM
Last post by really_n0b0dy
Today 01:49 PM
0 Replies, 13 Views
Original 67 SS350 engine...
Sep 12th, 19 04:30 PM
by stryqer
Last post by Niblet
Today 01:31 PM
7 Replies, 330 Views
1991 camaro horn switch
Sep 14th, 19 04:27 PM
Last post by BRICO69
Today 01:23 PM
2 Replies, 98 Views
bucket seat lock latch...
Today 07:26 AM
Last post by allanjs
Today 12:56 PM
1 Replies, 45 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by big gear head
Today 12:49 PM
17 Replies, 16,309 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by HawkX66
Today 12:21 PM
25 Replies, 383 Views
How to upload pic of my...
Today 10:56 AM
Last post by dhutton
Today 12:03 PM
2 Replies, 49 Views
Rear Rub when turning
Today 08:55 AM
Last post by DjD
Today 09:24 AM
1 Replies, 66 Views
Overheating Concerns '67...
Sep 5th, 19 12:34 PM
Last post by 69-er
Today 09:06 AM
35 Replies, 832 Views
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 285 Views
