Mods - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old May 13th, 07, 07:09 AM   #1 (permalink)
Mods
Hi i'm a new memeber to the site. I have a '98 camaro SS with just over 90k in kilometers. I'd like to up the horespower on the car! As I'm no mechanic I'd appreciate some recomendations on any shops who specialize in camaro modifications. Ideally, I'd like to get an extra 200 - 250 horsepower, however my funds are limited. Any advice would be greatly appreciated!
98SS is offline   Reply With Quote Quick reply to this message
Old May 13th, 07, 08:03 AM   #2 (permalink)
Welcome Back - Senior Tech
Re: Mods
start with exhaust and intake. SLP's cold air intake is nice and I like the sound of the Borla cat-back. Then have the cam changed, and get new heads if your looking for another 200 horse. For the f-bodies that will put you around 550 at the flywheel... Don't know how long your rear end will last, let alone the internals of your engine.
the learning curve is....expensive
1969 Camaro
bearcat44 is offline   Reply With Quote Quick reply to this message
Old May 13th, 07, 06:19 PM   #3 (permalink)
Re: Mods
if you ever get the 200-250 HP your looking for on limited Funds .. Plz. .. Plz. let me know how you did it .
Thats alot of HP your asking for . 98 SS camaros are fast already .. especially if it has the 6spd in it .
RobSS1113 is offline   Reply With Quote Quick reply to this message
Old May 13th, 07, 07:03 PM   #4 (permalink)
Re: Mods
The learning curve is expensive indeed With your suggestions Bearcat, it seems a new rear end would have to go along with the added horsepower??? Any comments regarding the addition of a turbo? Is there room under the hood for one?
Old May 13th, 07, 10:07 PM   #5 (permalink)
Re: Mods
PTK makes a kit. It routes the turbo up between the radiator and the engine. It looks like a giant octopus of pipes surrounding your engine. It does work well though, if you can stomach the price. Another option, though looked down upon in the turbo world is a remote mount by someone like STS turbo. It basically replaces your muffler with a turbo. They do work, but don't seem to spool as quickly as the front mount setups. They also run really tight exhaust housings to get them to spool, which creates more drive pressure than a front mount would. Have you considered a blower? ATI and Vortech are two excellent options. LS1s seem to take a reasonable amount of boost before blowing up. Should put you in the 500rwhp range with a sane setup. You could probably go 550 or higher if you decide to push the envelope a little more.
67 RS/SS clone - 530rwhp
[email protected]
redcamaro is offline   Reply With Quote Quick reply to this message
Old May 14th, 07, 08:04 AM   #6 (permalink)
Re: Mods
Getting 200 additional ponies for cheap isnt going to happen. So now that you know that you can build up to that goal of yours part by part. Im not sure if you have put a new catback system on your SS but that would be a good start. From there you can start looking to make some upgrades to the engine. If you got about $2500 that should get you a good set of heads, cam, larger fule injectors, and a tune that will net it close to 100 ponies increase.
Save you money again and then when you have another $2500 you can invest in new intake, larger throttle body, and add a nitrous kit, and another tune. That should get you close to your 200 HP increase.
1968 Camaro with a 383 finally done and on the road!
LeeMan is offline   Reply With Quote Quick reply to this message
Old May 24th, 07, 02:43 PM   #7 (permalink)
Re: Mods
Easy bot ons for a 98ss are as following. No cats with Long Tube Headers. These aren't smog legal but add serious power to LS1's. But an SLP Y pipe with flowmaster exhaust. IF 6 speed get the centerforce clutch. Very nice! Then throw a moser rear with 4.11s. This shouldn't be more than 3k. Seriously your car will get mid to low 12s at the track with some good tires. A friend of mine has this on a 00 SS and in the eigth mile he runs 8.0 and 7.90s. Good Luck. If you really want to haul cam it and port the heads= HAUL *** in LS1
68 Camaro
Some mods...
68SSlemans is offline   Reply With Quote Quick reply to this message
Old Jun 17th, 07, 03:12 PM   #8 (permalink)
Re: Mods
if you're from Canada check out SLP and agostino racing
as far as mods an LS1 that can't run a 12-sec quarter with just bolt-ons (NO heads or cam or power-adder) should be taken away from it's owner
start with a 'lid' (the air cleaner cover box)
do all the bolt-on mods
if you have an automatic get a higher stall converter
if you have a manual get a good clutch and gears (rearend as mentioned for big power cars)
but I just caught the word 'budget' . . . LS1 heads and cams aren't cheap . . . nitrous is cheap, but not for everyone
start with the basics (don't overlook weight reduction and suspension)
get it tuned by a pro (no handheld crap)
do the internal engine mods when you have the funds
as far as 200+ hp, I'll caution you to stay realistic and shoot for 400 RWhp . .. . my suggestion is L92heads/L76intake package and a moderate cam with a professional tune, long-tube headers and a good cat-back (listen to many and choose what you like) . . . you can thank me later
good luck and have fun
fast is offline   Reply With Quote Quick reply to this message
Old Jun 17th, 07, 10:02 PM   #9 (permalink)
Re: Mods
Nitrous
'67 Camaro in the works...
Newbomb is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
Mods for a 2.8 aaronjohn20 Performance 5 Oct 1st, 07 09:23 PM
2.8 Mods aaronjohn20 Performance 2 Jun 7th, 06 02:38 PM
Double Hump Head Mods emperor91108 Performance 6 Nov 16th, 05 11:03 AM
325hp 305 with simple bolt-on Mods. 4U 2 NV Performance 11 Aug 14th, 02 03:25 AM
Cheap Mods? NucleaR Performance 15 Aug 15th, 01 10:22 AM
» Recent Discussions
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 274 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by Niblet
Today 08:24 AM
12 Replies, 16,239 Views
bucket seat lock latch...
Today 07:26 AM
Last post by aircavalryveteran
Today 07:26 AM
0 Replies, 21 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by bhodgdon400
Today 06:46 AM
21 Replies, 332 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:39 AM
18 Replies, 559 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Last post by The Camaro Guy
Today 05:44 AM
12 Replies, 337 Views
Hello from Chicago
Yesterday 08:14 AM
Last post by Andrew69
Today 05:32 AM
3 Replies, 76 Views
Fuel line routing issue...
Sep 9th, 19 05:36 AM
by HawkX66
Last post by HawkX66
Today 04:37 AM
15 Replies, 376 Views
Took home my 2nd Best in...
Sep 16th, 19 06:37 AM
Last post by pittpens24
Today 04:18 AM
12 Replies, 240 Views
Humpday Humor, 9/17 ......
Yesterday 03:14 PM
Last post by flat tire
Today 04:10 AM
5 Replies, 148 Views
