Hesitation and its malcontents - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old May 25th, 07, 10:36 PM   #1 (permalink)
I've been flitting about the forums here, and I've got a few questions that perhaps someone more knowledgeable can help me with.
In cases where hesitation at take off or "chugging" while cruising at lower RPM occurs, I've read that several things have helped. Changing the plugs, checking and perhaps replacing the MAFS, as well as some fiddling with a TPS and accelerator position sensors in the throttle body. Is there any set of steps that will let me diagnose this stuff and parse out which is more likely? I can lay hands on a code reader if need be, but barring an error code (no check engine light in this instance makes it seem less than likely that a code reader is going to make it 100% easier), are there steps I can take?
Thanks for the time, stats are below for the engine about which I'm writing, although others have seen similar problems on different engines/setups.
97 z-28, 5.7L V8, automatic trans, recent fuel filter, air filter, serp belt and oil
R4g3fist is offline   Reply With Quote Quick reply to this message
Old May 26th, 07, 07:09 PM   #2 (permalink)
Re: Hesitation and its malcontents
if the o2 sensor isnt switching, you`ll get a surging or "chugging"...also a plugged cat can cause problems...a scanner can help in adjusting the tps sensor, and can show you if the o2 is switching...the o2 not switching wont nessecarily call a code if it`s just slow to react...also look at the egr valve for carbon build-up on the pintle...if its not sealing properly, it`ll make a ruff idle,or surging under light throttle, but wont be noticed under heavy accel...
kustomwerker is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Alternator Wisdom?
Today 01:49 PM
Last post by really_n0b0dy
Today 01:49 PM
0 Replies, 13 Views
Original 67 SS350 engine...
Sep 12th, 19 04:30 PM
by stryqer
Last post by Niblet
Today 01:31 PM
7 Replies, 330 Views
1991 camaro horn switch
Sep 14th, 19 04:27 PM
Last post by BRICO69
Today 01:23 PM
2 Replies, 98 Views
bucket seat lock latch...
Today 07:26 AM
Last post by allanjs
Today 12:56 PM
1 Replies, 45 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by big gear head
Today 12:49 PM
17 Replies, 16,309 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by HawkX66
Today 12:21 PM
25 Replies, 383 Views
How to upload pic of my...
Today 10:56 AM
Last post by dhutton
Today 12:03 PM
2 Replies, 49 Views
Rear Rub when turning
Today 08:55 AM
Last post by DjD
Today 09:24 AM
1 Replies, 66 Views
Overheating Concerns '67...
Sep 5th, 19 12:34 PM
Last post by 69-er
Today 09:06 AM
35 Replies, 832 Views
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 285 Views
