Need More Power!!! - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jun 9th, 07, 05:38 AM   #1 (permalink)
Need More Power!!!
Ok, Ive had my 94 Z for about 2 years now. Ive done Cat back exhaust (magnaflow high performance cat and flowmaster 40 series), Summit Street n Strip twin 58mm throttle body, rebuilt tranny and added a shift kit, and cold air intake....Ive run out of ideas...now Im not sure what I want to do next...what would give me the most "bang for the buck" at this point?
94TwitchZ28 is offline   Reply With Quote Quick reply to this message
Old Jun 14th, 07, 12:32 PM   #2 (permalink)
Re: Need More Power!!!
you can try underdrive pulleys, as well as a tuner chip and if you have the money a supercharger
FastEddie#1 is offline   Reply With Quote Quick reply to this message
Old Jun 14th, 07, 04:27 PM   #3 (permalink)
If you dont have to deal with emissions where you live then put a set of long tube headers on there. If you do what gears are you running? Since you have an Auto it looks like Im guessing you have 2:73s. Put a set of 3:73s or if you want to be a little more conservative 3:42s. They will both give you a seat of the pants difference over the 2:73s.
1968 Camaro with a 383 finally done and on the road!
LeeMan is offline   Reply With Quote Quick reply to this message
Old Jun 14th, 07, 09:18 PM   #4 (permalink)
I had the same car with headers, 3.73, hypertech, cold air. it ran awesome. the gear was the best thing I did. If you drive it everyday I would go with the 3.42. the cheapest way for more power would be gear, cam and nos.
2005 2500hd, duramax,crew cab, 4x4,
2012 GMC Terrain awd
1981 Bandit Trans Am(LS1)
2007 Z06 Corvette
2004 R1 (stock)
2005 Grizzly
2005 Z71 Suburban
1969 Camaro SS 496 stroker, 4sp ( in body shop)
camarossrulz is offline   Reply With Quote Quick reply to this message
Old Jun 17th, 07, 02:36 PM   #5 (permalink)
most A4-equipped Z28's had 3.23s (if your shifter shows the '1' you have them)
M6 cars had 3.42s
a 58mm tb is a waste until you hit much higher power #s
the biggest difference will not be gears in an A4 car (in an M6 sure)
it'll be a higher stall (2800-3000) they aren't cheap but the difference is just astounding (from a drag racing p.o.v. that is)
as far as bolt-ons after the CAI you should look into 1.6 rockers, headers (another huge gain), under-drive pulley set, and tuning (don't use one of those crappy hand-held things, hypertech is only good for shift point changes) then gears (my .02)
weight reduction, suspension (LCA's, relocation brackets, torque arm)
always do the basics first then if you decide to do heads/cam or a power-adder you're ahead of the game
12-sec daily driver LT1's are so easy to build and very inexpensive (LS1 little higher initial cost for car but almost too easy hehe)
good luck to ya and have fun
fast is offline   Reply With Quote Quick reply to this message
Old Jul 2nd, 07, 01:34 AM   #6 (permalink)
definitely looking to do gears, cam, and better heads...BUT...motor has 190K on it...original block, pistons, and heads...had rings, lifters, rod bearings replace at 150K...would it be alright to put better heads on the motor OR do I need to build up the lower end first?
Old Jul 2nd, 07, 06:25 AM   #7 (permalink)
Best bang for the buck performance mod is spray. I gained 1.5 sec in the 1/4 from 125 shot spray. You just need to put all the safety features on. I have had good luck with mine but some people blow there engines with far less.
96 Z-28 vert
67 Coupe 502BBC TH400
badzboy11 is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
67 Camaro Power steering gear box pdq67 Brakes, Suspension & Steering 5 Nov 8th, 14 08:14 AM
Power Top Switch 327!275hp!Convt! Convertibles 13 Jan 23rd, 07 06:10 AM
overlap, and stock idle L79Mike Performance 13 Jan 21st, 06 09:23 PM
Correct power steering pump and pulley for 69 Z28 jlighthart Engine 0 Nov 15th, 04 02:52 AM
Power Steering / Belt Alignment Problem kgaffney Tech 2000 17 Jul 9th, 01 04:36 PM
» Recent Discussions
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 271 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by Niblet
Today 08:24 AM
12 Replies, 16,235 Views
bucket seat lock latch...
Today 07:26 AM
Last post by aircavalryveteran
Today 07:26 AM
0 Replies, 21 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by bhodgdon400
Today 06:46 AM
21 Replies, 330 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:39 AM
18 Replies, 558 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Last post by The Camaro Guy
Today 05:44 AM
12 Replies, 337 Views
Hello from Chicago
Yesterday 08:14 AM
Last post by Andrew69
Today 05:32 AM
3 Replies, 75 Views
Fuel line routing issue...
Sep 9th, 19 05:36 AM
by HawkX66
Last post by HawkX66
Today 04:37 AM
15 Replies, 376 Views
Took home my 2nd Best in...
Sep 16th, 19 06:37 AM
Last post by pittpens24
Today 04:18 AM
12 Replies, 239 Views
Humpday Humor, 9/17 ......
Yesterday 03:14 PM
Last post by flat tire
Today 04:10 AM
5 Replies, 148 Views
