02 SS with 21,000 mi. - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jun 24th, 07, 05:34 PM   #1 (permalink)
Should I flush and change the antifreeze since it has been in the car 5 1/2 years. I bought it new so I know it hasnt been changed. It still tests out at 40 below zero but I dont want any corrosion to start. Also the trans fliud ?
67sprtcp is offline   Reply With Quote Quick reply to this message
Old Jun 24th, 07, 07:01 PM   #2 (permalink)
Joe Harrison's Avatar
Re: 02 SS with 21,000 mi.
Yes you should. With it not being driven much it not really any different than driving it when it comes to your coolant. You don't want it to become acidic and cause corrosion problems in your engine. Being it's an LS1 you should take car of this as the any of the cast or iron parts that are in the cooling system help this along.
Your trans can get moisture in it, although very little and one of the things our oils and lubricating fluids do are retain moisture as part of the protection along with lubrication. For the minimum cost involved I would change it out also. I would also think about getting it out and running her to full temps and roll through the gears. keeping everything lubricated and seals in oil are good things. You may want to lube the chassis also until old grease comes out and then wipe off any excess. This will get moisture out of these areas also.
This is something I go by. If I change oil every 3 months or 6000 miles and don't put on that 6000 miles, I change it anyway. usually only an oil change if it has sat most of the time. The rest I keep up with typical maintenance intervals just as normal. It might be over kill but I think it's worth the extra effort. After all you still pull it and clean and detail even when they are not driven much. I see the rest as the same kind of maintenance.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline   Reply With Quote Quick reply to this message
Old Jun 26th, 07, 02:06 PM   #3 (permalink)
Thumbs up Re: 02 SS with 21,000 mi.
Thanks for the info. I will have it changed.
Location
Location
First Name
» Recent Discussions
Alternator Wisdom?
Today 01:49 PM
Last post by really_n0b0dy
Today 01:49 PM
0 Replies, 13 Views
Original 67 SS350 engine...
Sep 12th, 19 04:30 PM
by stryqer
Last post by Niblet
Today 01:31 PM
7 Replies, 330 Views
1991 camaro horn switch
Sep 14th, 19 04:27 PM
Last post by BRICO69
Today 01:23 PM
2 Replies, 98 Views
bucket seat lock latch...
Today 07:26 AM
Last post by allanjs
Today 12:56 PM
1 Replies, 45 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by big gear head
Today 12:49 PM
17 Replies, 16,309 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by HawkX66
Today 12:21 PM
25 Replies, 383 Views
How to upload pic of my...
Today 10:56 AM
Last post by dhutton
Today 12:03 PM
2 Replies, 49 Views
Rear Rub when turning
Today 08:55 AM
Last post by DjD
Today 09:24 AM
1 Replies, 66 Views
Overheating Concerns '67...
Sep 5th, 19 12:34 PM
Last post by 69-er
Today 09:06 AM
35 Replies, 832 Views
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 287 Views
