Weird cooling problem - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jun 28th, 07, 03:02 PM   #1 (permalink)
I have a 95 camaro w/a 3.4L V6. Recently, I checked the coolant level in the radiator because the car was running hot. The level was really low and there was almost no coolant in the overflow reservior. I filled the radiator to full and added a bit to the reservior. Drove it 100 miles the next day and checked the radiator again. Again it was half empty and there was very little coolant in the reservior, even when hot. It looks like there is some coolant leaking from the front of the engine, but it's not coming from the waterpump, but the timing cover. No coolant in the oil and what's leaking out is about a 1/4 cup. Where is this coolant going? I'm absolutely stumped on this one
crucescamaro is offline   Reply With Quote Quick reply to this message
Old Jun 28th, 07, 07:55 PM   #2 (permalink)
Re: Weird cooling problem
its probally leaking from a hose or back of water pump.
hereitis67 is offline   Reply With Quote Quick reply to this message
Old Jun 29th, 07, 01:08 PM   #3 (permalink)
Most water pumps have a hole in them where the bearig is. The purpose of the hole is that when the bearing is starting to go bad it drips water. This is so that you see the leak before total failure and the fan goes through the radiator.
There are no problems only solutions
68 Camaro, RS/SS, ZZ502, Retrotek Fuel Injection, 4 Speed.
2010 RS/2SS Black, 6 speed trans
68Holdon is offline   Reply With Quote Quick reply to this message
Old Jul 9th, 07, 03:11 PM   #4 (permalink)
I've checked the water pump weep hole- it's bone dry. The leak looks like its coming from left side of the water pump, but not he pump itself. Timing cover maybe. Whatever and wherever this leak is, its burning up alot of coolant.
Old Jul 9th, 07, 04:55 PM   #5 (permalink)
i have a 93 and had a similar problem it turned out to be a very small leak near a bolt for the head gaskets
blaclabel250 is offline   Reply With Quote Quick reply to this message
Old Apr 30th, 08, 07:03 PM   #6 (permalink)
i have a 95 3.4 that has the same thing wrong with it but the only difference is that mine is not leaking no water anywhere at all so can i get some suggestions from yall. sorry to but in like this but i need to fix it cause i am moving to upstate ny soon and can t drive it up there like this. thanks in advance
ridinsolo2 is offline   Reply With Quote Quick reply to this message
Old Apr 30th, 08, 07:05 PM   #7 (permalink)
blaclabel how did you find where it was leaking at and where and which bolt was it exactly and how to get to it to check it out thanks
Old Apr 30th, 08, 07:51 PM   #8 (permalink)
An awful lot of chevy v6's get coolant leaks due to faulty intake manifold gaskets.
JimM is offline   Reply With Quote Quick reply to this message
Old May 2nd, 08, 05:58 PM   #9 (permalink)
pressure test your system if it is leaking you will find it
CamaroBrandon is offline   Reply With Quote Quick reply to this message
Old May 9th, 08, 05:08 PM   #10 (permalink)
That aint no lie.
Also it could be the gasket between the timing cover and block. I just had to do one last week.
NEVER argue with a stupid person. They bring you down to their level, and then beat you with experience.
bighaas79 is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
Help with Weird Headlight problem AussieCamaroOwner Electrical & Wiring 8 Mar 18th, 06 01:21 PM
Need Help w/"80" Camaro Shifter Problem!!! Robert05 Troubleshooting 2 Feb 6th, 06 10:54 AM
Cooling problem, maybe. PinMd Heating & Cooling 2 Jan 28th, 06 06:15 AM
68 Power Brake Problem BCOates Brakes, Suspension & Steering 0 Nov 21st, 05 06:06 PM
Help Diagnose Electrical Problem - Weird Stuff... SC Rob Electrical & Wiring 7 Mar 15th, 04 07:23 AM
» Recent Discussions
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 271 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by Niblet
Today 08:24 AM
12 Replies, 16,235 Views
bucket seat lock latch...
Today 07:26 AM
Last post by aircavalryveteran
Today 07:26 AM
0 Replies, 21 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by bhodgdon400
Today 06:46 AM
21 Replies, 330 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:39 AM
18 Replies, 558 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Last post by The Camaro Guy
Today 05:44 AM
12 Replies, 336 Views
Hello from Chicago
Yesterday 08:14 AM
Last post by Andrew69
Today 05:32 AM
3 Replies, 75 Views
Fuel line routing issue...
Sep 9th, 19 05:36 AM
by HawkX66
Last post by HawkX66
Today 04:37 AM
15 Replies, 376 Views
Took home my 2nd Best in...
Sep 16th, 19 06:37 AM
Last post by pittpens24
Today 04:18 AM
12 Replies, 239 Views
Humpday Humor, 9/17 ......
Yesterday 03:14 PM
Last post by flat tire
Today 04:10 AM
5 Replies, 148 Views
