serios help please - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jul 2nd, 07, 08:05 PM   #1 (permalink)
stamatisg1977's Avatar
serios help please
my friends 2002 camaro z28's clutch pedal goes all the way to the floor. the reservoir was empty. i was told that this happens maybe once in the life of the car where the hydrolic throw out bearing fails. now we need to tow it to a repair shop. the car was worked from front to back with custom cam to full 3" exhaust and headers. it also has a racing clutch i believe it is spec 1 ? correct me if im wrong on that one. is it possible that the extra force to engage the clutch is too hard on the stock bearing? and what is the average price to replace?
thank you all
Steven
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline   Reply With Quote Quick reply to this message
Old Jul 2nd, 07, 08:27 PM   #2 (permalink)
Re: serios help please
It probably blew out a seal in the slave cylinder, and if it is the original slave and it has some serious mileage on it, it may have been due for replacement anyway.
Might want to pop over to www.ls1tech.com/forums and search "throwout" and "slave". There's quite a bit of reading on these components and mods to them to match other mods. If it's just the slave and he can have it replaced without removing the trans (required if the whole throwout assembly must be replaced), it's not too outrageous.
Eric
Eric Kammerer is offline   Reply With Quote Quick reply to this message
Old Jul 4th, 07, 04:19 PM   #3 (permalink)
The spec stage 3 is the street/strip. THe stage 4 is a strip clutch. I have heard problems the some of the spec cluctchs welding themselves together.
With it being an '02, it should already have the new throwout and hydralics, and the throwout should have come with the clutch. Another thing to check is did he do the drill mod? There is a restrictor in the line from the master down. It can cause problems. If the throwout failed, your would have fluid everywhere.
Dark Angel is offline   Reply With Quote Quick reply to this message
Old Jul 5th, 07, 03:19 PM   #4 (permalink)
my friend had this problem with a 2000 model, he had to buy the hydraulics new. I am not sure but I think the 01 and 02 model had upgraded hydraulics where you werent supposed to have to do the drill mod.
2005 2500hd, duramax,crew cab, 4x4,
2012 GMC Terrain awd
1981 Bandit Trans Am(LS1)
2007 Z06 Corvette
2004 R1 (stock)
2005 Grizzly
2005 Z71 Suburban
1969 Camaro SS 496 stroker, 4sp ( in body shop)
camarossrulz is offline   Reply With Quote Quick reply to this message
Old Jul 5th, 07, 10:50 PM   #5 (permalink)
My Clutch Slave Cyl gave out on my 97 SS with only 65K on the Clock ! ! it was fun taking that sucker off ! ! thats the one by the pedal itself .. not the easy one thats on the Tranny........ Good luck if thats what wrong with yours.
My symtoms on my clutch was .. if I pushed my clutch pedal in I would only have about 2 seconds to put it in gear and let go of the Clutch otherwise it would'nt go in or If it did go in .... it would want to take off on me even though I had the pedal to the floor.. And the pedal would stay hanging and I would have to tap the pedal with my foot and it would slowly make its way back to the top . !
paid 63 Dollars for the new part... She runs perfect now !
RobSS1113 is offline   Reply With Quote Quick reply to this message
Old Jul 6th, 07, 10:45 AM   #6 (permalink)
well the repair shop said that the bellhousing was full of fluid. so he thinks the t/o bearing is toast. he is also going to replace slave cylinder just to get ahead of maintenance. btw the car has only 20k miles on it.
Tremec TKO 600
Location
Location
First Name
» Recent Discussions
RPM stops at 3500 during...
Feb 28th, 16 09:07 PM
Last post by X-77 keith
Today 05:51 AM
7 Replies, 845 Views
Took home my 2nd Best in...
Yesterday 06:37 AM
Last post by pittpens24
Today 05:51 AM
9 Replies, 170 Views
Door glass won't adjust...
Sep 14th, 19 01:02 PM
by ssanto
Today 05:49 AM
4 Replies, 162 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by The Camaro Guy
Today 05:32 AM
15 Replies, 468 Views
Muncie shifting trouble
Yesterday 06:59 AM
Last post by R66
Today 05:31 AM
8 Replies, 170 Views
Adding...
Sep 15th, 19 05:57 AM
Last post by 350sshugger
Today 05:28 AM
9 Replies, 231 Views
Steering Arm Problem 68...
Sep 15th, 19 02:18 PM
Last post by R66
Today 05:18 AM
3 Replies, 161 Views
Kind of cool day for me
Aug 19th, 19 07:50 AM
Last post by rgwiz
Today 04:59 AM
24 Replies, 1,093 Views
carb tuning with...
Yesterday 08:47 AM
Last post by HawkX66
Today 04:49 AM
12 Replies, 159 Views
Coil Bracket
Today 03:34 AM
Last post by KevinW
Today 04:31 AM
2 Replies, 43 Views
