'93 camaro lt1 - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jul 12th, 07, 07:10 PM   #1 (permalink)
'93 camaro lt1
my 93 camaro will not start and i have basically ripped the engine apart! timing is good, changed the distributer because that was bad --got good spark but it will not start! any info will help!
glenalbee is offline   Reply With Quote Quick reply to this message
Old Jul 13th, 07, 07:14 AM   #2 (permalink)
Re: '93 camaro lt1
Just the basic rechecks... I assume it is cranking over quickly.
Ok you have compression.... recheck.
You say you have spark...batch fired but check each plug anyway.
Fuel... do you hear the pump run when the key turned on... if so then do you get fuel at the rail.... if so.... remove the injector rail and turn on key... should see mist spray from all injectors..
Ok you have fuel and spark... now what.
Distributor installed correctly.... only one way with the key BUT many a poor fellow has forced it on and literally warped it bolting it down... it should have snapped into place.
Then you have to go to the less obvious.... after first determining you have compression, fuel, and spark.
Good luck
Gary 9t4Z
69,70,91,91,94
9T4Z is offline   Reply With Quote Quick reply to this message
Old Jul 13th, 07, 07:21 AM   #3 (permalink)
Re: '93 camaro lt1
93 lt1 optisparks can be installed in many different positions, they changed it in 94 or 95. 93 had a splined shaft with a master splin but that spline can be pushed onto the drive gear spline fairly easily.
tumper is offline   Reply With Quote Quick reply to this message
Old Jul 13th, 07, 07:44 AM   #4 (permalink)
Re: '93 camaro lt1
So you could end up with spark, but could be way off! So thats a good place to start looking....
(my 94 could only go one way)
Gary 9t4Z
69,70,91,91,94
Old Jul 13th, 07, 12:18 PM   #5 (permalink)
Re: '93 camaro lt1
It is easy to get the master spline off even one tooth, GM finally figured this out and changed it a few years later and it was installed by aligning a dowel and it would only go in one of three places on the optispark. The easiest way I found to make sure it was right was to put the small driveshaft that goes into the optispark and in the driven gear in the timing cover by itself. If you put a mark on the end of it to reference the master spline you can look before you put it in the cover and know about where it should go, then move the driveshaft until it slide in easily into the cover and you will have found the right spot. Now turn the crank until that spline is pointing straight down or straight up, turn the optispark main spline to the same point and GENTLY do the same with the optispark as you did with driveshaft to make sure it is in the right spot. With everything aligned correctly it will all go back together very easily, if not you will be applying a little force and that is when you have screwd up and got it off. If you need more help PM me and I will be glad to help. I ran in to this when the lt1 first came out, figured out the trick, then about 6 months ago got one and messed up, then remembered the trick, so I have been in your shows on this one.
Location
Location
First Name
T56 Information - First Generation Camaro Swap Mkelcy Transmission & Driveline 223 Dec 19th, 16 06:35 AM
LT1 in 69 camaro fmfire672 Electrical & Wiring 8 May 19th, 08 09:26 PM
A big thanks to team camaro!!! 68 VT Bench Racing 13 Feb 28th, 06 04:41 AM
CAMARO IS BACK IN 2007!!!!!!!!!!!!!!!!!!!!!!!!! dawg Bench Racing 32 Apr 24th, 05 07:27 PM
» Recent Discussions
Original 67 SS350 engine...
Sep 12th, 19 04:30 PM
by stryqer
Last post by bob15
Today 03:28 PM
8 Replies, 335 Views
Alternator Wisdom?
Today 01:49 PM
Last post by really_n0b0dy
Today 01:49 PM
0 Replies, 14 Views
1991 camaro horn switch
Sep 14th, 19 04:27 PM
Last post by BRICO69
Today 01:23 PM
2 Replies, 100 Views
bucket seat lock latch...
Today 07:26 AM
Last post by allanjs
Today 12:56 PM
1 Replies, 46 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by big gear head
Today 12:49 PM
17 Replies, 16,315 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by HawkX66
Today 12:21 PM
25 Replies, 384 Views
How to upload pic of my...
Today 10:56 AM
Last post by dhutton
Today 12:03 PM
2 Replies, 51 Views
Rear Rub when turning
Today 08:55 AM
Last post by DjD
Today 09:24 AM
1 Replies, 68 Views
Overheating Concerns '67...
Sep 5th, 19 12:34 PM
Last post by 69-er
Today 09:06 AM
35 Replies, 834 Views
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 288 Views
