window problem - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jul 27th, 07, 01:45 PM   #1 (permalink)
window problem
has anybody had to replace a passengers side window on a 96 camaro
cbaker9638 is offline   Reply With Quote Quick reply to this message
Old Jul 27th, 07, 05:30 PM   #2 (permalink)
Re: window problem
yup...whats the problem???
kustomwerker is offline   Reply With Quote Quick reply to this message
Old Aug 3rd, 07, 03:28 AM   #3 (permalink)
Re: window problem
they usually get really slow then stop working. you will probably have to replace it, then they have a kit that directs power directly to the window motor that helps prevent them from going bad
2005 2500hd, duramax,crew cab, 4x4,
2012 GMC Terrain awd
1981 Bandit Trans Am(LS1)
2007 Z06 Corvette
2004 R1 (stock)
2005 Grizzly
2005 Z71 Suburban
1969 Camaro SS 496 stroker, 4sp ( in body shop)
camarossrulz is offline   Reply With Quote Quick reply to this message
Old Aug 4th, 07, 11:13 AM   #4 (permalink)
Z28 Mark's Avatar
Exclamation Re: window problem
Please tell me more about this "kit"... I have a 2001 window that need a motor replacment.
Mark (AKA Z28 Mark)
1973 Z28 2001 Z28
Camaros Limited~Nor Cal
Z28 Mark is offline   Reply With Quote Quick reply to this message
Old Aug 4th, 07, 07:10 PM   #5 (permalink)
Re: window problem
Window or Window Motor? There real easy to replace! I just put new windows motors in mine what a big difference they are much faster. When the motors are getting old and going bad they slow down and trip the curcuit breakers then You know You need motors. You can buy the motors at any part store. Just drill out rivets to remove motors and replace motors with bolts and nuts that come in the kit.
edd Gordon is offline   Reply With Quote Quick reply to this message
Old Aug 5th, 07, 06:34 PM   #6 (permalink)
Z28 Mark's Avatar
Arrow Re: window problem
I want to know more about the direct wiring kit… I’ve done the motor on the driver’s side before. I just want the info on this direct kit…
Mark (AKA Z28 Mark)
1973 Z28 2001 Z28
Old Jan 8th, 09, 01:18 PM   #7 (permalink)
Re: window problem
Hey guys...I know this is an old blog that I am responding to, but have been reading other owners with 4th generation cars who had problems with the auto window motors.
Someone please level with me. I just acquired a '99 SS with very little mileage. The previous owner had the car laying-up for most of it's life.
Is it in fact true that these motors do not last long? Is more a problem with over useage than the reality the motors are weak or deficient? Mine seem to work okay for the time being. I plan just not using the power window "excessively", if I can help it.
Surely the factory would have been on to this and maybe issued a recall notice to owners long before now.
thanks,
Doug
tblazer is offline   Reply With Quote Quick reply to this message
Old Jan 16th, 09, 07:37 PM   #8 (permalink)
Re: window problem
Funny...no...GM doesnt have many power lift motors, the Camaro's have long been famous 1970+ for the single side window look. I think that they re-use a parts bin window motor designed for a celebrity and try to apply it to a long door camaro and the lives are short.
I have owned a 95 Z28, 00 TA, 98SS, 96 Camaro and had to replace windows on all. I had an 02 Z28 with manaul crank that was the only F-body I did not have trouble with.
It is just part of owning a 4th gen.
The 1995 Z28 drivers window went out on me with 36,004 miles...dealer denied claim...so I figured it out.
NAPA window motors seemed to last longer than Autobones...no hard data to support, just my opinion.
1969 X66
1964 Corvette 327/300
1998 SS Vert
1987 Regal
hatdragracer is offline   Reply With Quote Quick reply to this message
Old Jan 22nd, 09, 09:36 AM   #9 (permalink)
Re: window problem
Corey,...try goine to the Camaro web-site, "shbox.com/page/windowmotor.htlm" for full instructions, with pics on how to change-out the motor.
Just passing along info I received from another forum member.
...good luck,
Old Mar 24th, 09, 09:14 PM   #10 (permalink)
Re: window problem
Hello tblazer!
I am trying to remove my passengers side power window motor, could you please tell me the complete address for the instructions you said... or it is not working anymore? _I could not get to that site "shbox.com/page/windowmotor.htlm"
thanks in advance!
emacias is offline   Reply With Quote Quick reply to this message
Old Apr 15th, 09, 08:15 AM   #11 (permalink)
Re: window problem
Edgar;...sorry just noticed your inquiry made a couple weeks ago to me seeking information about the website "shbox.com/page".
I tried (unsuccessfully) to access the site as I gave to you last time.
I was able to access the site by typing "shbox.com/page"; that gets you to the mainpage, then you can navigate (look for) the window blog.
Good luck,
tblazer
Old Apr 15th, 09, 05:32 PM   #12 (permalink)
Re: window problem
be careful sometimes its the regulator not the motor. the worn out regulator kills the motor. my 01 z28 had window problems and it was the regulator NOT the motor
twozs is offline   Reply With Quote Quick reply to this message
Old Jun 16th, 15, 07:14 PM   #13 (permalink)
Re: window problem
I have a 98 z28 Camaro. Has anybody had a problem with the driver side and passenger side power window intermittingly not working up and down. Please help!
drack is offline   Reply With Quote Quick reply to this message
Old Jul 8th, 15, 12:37 PM   #14 (permalink)
Re: window problem
My 02 Z28 started doing that with the passenger side window a couple of years ago. I just don't roll it down anymore. It's on it's 3rd motor and I've had the power cable changed out to the one that directs power to both motors through 2 separate cables. Thing still doesn't work worth a damn.
The drivers side has been fine except this past winter it started making noise when you roll it up.
Car currently has 62,xxx miles on it. It's my daily driver and still runs like a champ. I figure when the drivers side window fails I'll take it somewhere and have them fixed.
Sorry I'm not much help, but I figured I could commiserate with you. You're not alone with this. I've had 4 4th gens and the only one I didn't have a problem with was the 96 Z28 vert (bought it new) that I traded in on the 02. Probably wasn't old enough to start having problems. OTOH, it did have a problem (fixed under warranty) with the power window switch on the drivers door. It's always something...
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
PowerWindows is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Door glass won't adjust...
Sep 14th, 19 01:02 PM
by ssanto
Last post by pittpens24
Today 05:54 AM
5 Replies, 165 Views
RPM stops at 3500 during...
Feb 28th, 16 09:07 PM
Last post by X-77 keith
Today 05:51 AM
7 Replies, 849 Views
Took home my 2nd Best in...
Yesterday 06:37 AM
Today 05:51 AM
9 Replies, 170 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by The Camaro Guy
Today 05:32 AM
15 Replies, 468 Views
Muncie shifting trouble
Yesterday 06:59 AM
Last post by R66
Today 05:31 AM
8 Replies, 170 Views
Adding...
Sep 15th, 19 05:57 AM
Last post by 350sshugger
Today 05:28 AM
9 Replies, 232 Views
Steering Arm Problem 68...
Sep 15th, 19 02:18 PM
Last post by R66
Today 05:18 AM
3 Replies, 162 Views
Kind of cool day for me
Aug 19th, 19 07:50 AM
Last post by rgwiz
Today 04:59 AM
24 Replies, 1,095 Views
carb tuning with...
Yesterday 08:47 AM
Last post by HawkX66
Today 04:49 AM
12 Replies, 159 Views
Coil Bracket
Today 03:34 AM
Last post by KevinW
Today 04:31 AM
2 Replies, 43 Views
