Rear diff. noise - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jul 27th, 07, 04:51 PM   #1 (permalink)
Rear diff. noise
I have an 02 SS and the rearend seems to be noisy. Anyone have the same problem ? It varys with speed.
67sprtcp is offline   Reply With Quote Quick reply to this message
Old Jul 30th, 07, 04:50 PM   #2 (permalink)
Re: Rear diff. noise
change the fluid and be sure to use a good posi lube (I like the GM stuff)
sometimes it's this simple and I hope it is for you
fast is offline   Reply With Quote Quick reply to this message
Old Jul 30th, 07, 06:15 PM   #3 (permalink)
Old Aug 13th, 07, 06:52 PM   #4 (permalink)
Mine was getting what sounded like a gear whine. When I changed tires and got rid of the hard F1 Eagles, the noise went away.
2000 SS vert, SLP#5301, triple black, A4, leather, 3.23, SLP lid, d/d, stb
USN Ret 1964-1988
#3 1951-2001
"Growing old is mandatory, growing up is optional"
planemech2 is offline   Reply With Quote Quick reply to this message
Old Aug 26th, 07, 11:54 AM   #5 (permalink)
What tires did you go with ?
Old Sep 8th, 07, 07:43 PM   #6 (permalink)
My '02 started making a little noise recently. I pulled it apart last night to find a bad axle. It's pitted badly where the bearing runs. No ill effects were obvious, but the low growling noise wasn't normal. The more I read, this tends to be a problem with these cars. Mine has 87000 miles, and I ended up changing all of the bearings in the rearend. Waiting on a used axle Monday.
zeebad1 is offline   Reply With Quote Quick reply to this message
Old Sep 10th, 07, 03:57 PM   #7 (permalink)
I had mine completely rebuilt by a chevy dealer with new everything. It was fine for awhile but over time its getting the gear whine louder and louder. Not really happy with the situation. I will drive it until it tears up again. The cars only has 22,000 miles.
Old Sep 21st, 07, 12:25 PM   #8 (permalink)
Getting rid of the F1's is the best thing I did for my car. I went with BFGoodrich KDW's. It's a phenomenal tire for the price. (It should be pointed out not to confuse the tire with the KDWS.)
Better tread wear, traction, and appearance from the F1's. Much cheaper as well.
Rhino is offline   Reply With Quote Quick reply to this message
Old Sep 22nd, 07, 01:23 PM   #9 (permalink)
I will check the those tires out when I get new ones ! Thanks. Does it ride better?
Old Sep 24th, 07, 06:38 AM   #10 (permalink)
The over all ride seems very similar, although the KDW has a slightly more rigid sidewall. I think it makes the tire a little more responsive.
Old Sep 28th, 07, 06:19 PM   #11 (permalink)
Thanks ! The price of the F-1S are way high .
Old Sep 29th, 07, 05:34 PM   #12 (permalink)
67sprtcp: I went with Sumitumo tires from Tirerack.com. $88 each. Handles a lot better as well as better grip on acceleration.
USN Ret 1964-1988
#3 1951-2001
Old Sep 30th, 07, 05:34 PM   #13 (permalink)
Thanks, that is a great price. I have been looking at bfg tires on the tire rack site.
Location
Location
First Name
» Recent Discussions
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by bhodgdon400
Today 09:03 AM
23 Replies, 338 Views
Rear Rub when turning
Today 08:55 AM
Last post by JakeSpoon
Today 08:55 AM
0 Replies, 10 Views
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 275 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by Niblet
Today 08:24 AM
12 Replies, 16,240 Views
bucket seat lock latch...
Today 07:26 AM
Last post by aircavalryveteran
Today 07:26 AM
0 Replies, 21 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:39 AM
18 Replies, 559 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Last post by The Camaro Guy
Today 05:44 AM
12 Replies, 337 Views
Hello from Chicago
Yesterday 08:14 AM
Last post by Andrew69
Today 05:32 AM
3 Replies, 77 Views
Fuel line routing issue...
Sep 9th, 19 05:36 AM
by HawkX66
Last post by HawkX66
Today 04:37 AM
15 Replies, 376 Views
Took home my 2nd Best in...
Sep 16th, 19 06:37 AM
Last post by pittpens24
Today 04:18 AM
12 Replies, 241 Views
