1997 z28. whats it got? - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jul 30th, 07, 02:40 PM   #1 (permalink)
I recently purchased a 1997 z28 camaro 30th aniversary ed. i was wondering if anyone knew what type of gears it has in it? if it has posi-trac or limited slip? and what is the best way to get maximum performance with out breaking the bank?
jarratt is offline   Reply With Quote Quick reply to this message
Old Jul 30th, 07, 02:56 PM   #2 (permalink)
DjD
DjD's Avatar
Re: 1997 z28. whats it got?
It's got an LT1 engine cast iron block alum with reverse flow cooling and an opti spark up front instead of a dist. It's responds to all the typical mods, heads, cams, headers and of course the odbII is programable. Your rear gears if memory serves me would most likely be 3:23:1 and it should be a posi which is limited slip by the way. There were other gear options and the stick and auto got different gears stock I believe...
...Dennis
DjD is offline   Reply With Quote Quick reply to this message
Old Jul 30th, 07, 03:02 PM   #3 (permalink)
Welcome Back - Senior Tech
gears are 3.42's for 6 speeds and 3.23's for autos. Don't wanna break the bank then go with a good intake (slp makes a good one), headers, and a catback. I suggest magnaflow. They have a new one that sounds excellent! Deep, crisp tone and it purrs at idle. If that isn't good enough come back
the learning curve is....expensive
1969 Camaro
bearcat44 is offline   Reply With Quote Quick reply to this message
Old Jul 30th, 07, 04:42 PM   #4 (permalink)
as stated M6 got 3.42s
A4 cars were 2.73 with 3.23 optional, all Z28 should be posi regardless of ratio
for an M6 gears are all important, for an A4 a nice stall (gears if you like)
a CAI kit and headers/cat-back are essential
also I like to remind people to not overlook suspension
SFC's are must mods imho, any V8 4th gen (LT1 or LS1) has enough power to tweak the body
check out camaroz28.com
fast is offline   Reply With Quote Quick reply to this message
Old Aug 10th, 07, 11:53 PM   #5 (permalink)
If it's an A4 tranny the gears could either be 2:73's, 3:08's or 3:23's from the factory. If someone has changed gears in an A4 more than likely they are 3:73's. If it's an M6 they are 3:42's from the factory but again if someone has changed gears they are probably 4:10's. Performance again depends on tranny. A4 best bang for the buck would be a stall converter. Go to www.ls1tech.com alot of LT1 info on that site also.
Glacier Blue/Dover White 69 SB SS Restoclone.
99 Trans Am...my toy
Old Man is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
frustration with...
Yesterday 04:55 PM
Last post by X-77 keith
Today 03:23 AM
5 Replies, 113 Views
Steering Arm Problem 68...
Yesterday 02:18 PM
Last post by 130fe
Today 02:02 AM
1 Replies, 71 Views
69 Camaro with Dart 406"...
Yesterday 10:41 AM
Last post by friendlyviper
Yesterday 08:38 PM
6 Replies, 132 Views
What do these two black...
Sep 10th, 19 01:32 PM
Last post by 67sc
Yesterday 08:18 PM
12 Replies, 376 Views
Passenger door side view...
Sep 8th, 19 10:38 AM
Last post by 69Z28
Yesterday 07:10 PM
22 Replies, 530 Views
67 camaro smog pump...
Yesterday 06:08 PM
by Niblet
Last post by Niblet
Yesterday 06:08 PM
0 Replies, 58 Views
Wiring HEI distributor...
Jul 7th, 19 12:05 AM
Last post by graeme
Yesterday 05:59 PM
14 Replies, 581 Views
Adding...
Yesterday 05:57 AM
Last post by SOA-Nova
Yesterday 05:52 PM
3 Replies, 118 Views
Buying a 68-69 Camaro 350
Sep 8th, 19 10:41 PM
Last post by kookykrispy
Yesterday 05:37 PM
13 Replies, 435 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Yesterday 05:17 PM
5 Replies, 169 Views
