Engine code test? + smoke? - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Aug 20th, 07, 12:32 PM   #1 (permalink)
Sister has a 95 camaro 3.4 auto...I know most of the time u use a jumper wire on A+B i think i had the right ones but the light did not flash-so how is this done and where can i find a code list? I was told it was overheated real bad for 40 miles and wouldn't start when it got her home....4 months later i'm able to get to it-the car runs now-The thing is smoking real bad but the engine runs great, i don't know what the hell she did to it...the rad had like what looked like sh*t in there no joke-so i flushed it--don't beleave it was oil-oil had no anti-freeze in there and is to the proper level-also looks like the anti-freeze level has not gone down none and is running at the right temp also Smoke was white upon start up but then cleared up once it hit open loop and then smoke came back after 10 mins of running along with check engine light? Thanx Guys..
Americanz24 is offline   Reply With Quote Quick reply to this message
Old Aug 20th, 07, 12:59 PM   #2 (permalink)
Re: Engine code test? + smoke?
If it's white smoke... you're getting coolant in your exhaust. Blown head gasket, cracked head, or cracked block.
Unfortunately, I'm not aware of a way to pull codes from a '95 without the use of a scanner.
Rhino is offline   Reply With Quote Quick reply to this message
Old Aug 21st, 07, 02:09 PM   #3 (permalink)
Autozone will scan it for free. Doesn,t sound good.
LTFunCamaro is offline   Reply With Quote Quick reply to this message
Old Aug 27th, 07, 08:54 PM   #4 (permalink)
Thanx guys...the car has been taken off the road...was hoping since the check engine light was on that would be causing the smoke-i assumed the heads also
Location
Location
First Name
» Recent Discussions
Took home my 2nd Best in...
Yesterday 06:37 AM
Last post by BlueRibbon
Today 09:38 AM
10 Replies, 186 Views
Camaro specialties
Dec 19th, 10 06:14 AM
by perky
Last post by adjudimo
Today 09:35 AM
43 Replies, 14,044 Views
Overheating Concerns '67...
Sep 5th, 19 12:34 PM
Last post by allanjs
Today 09:20 AM
33 Replies, 755 Views
Coil Bracket
Today 03:34 AM
Last post by Z282NV
Today 09:16 AM
4 Replies, 87 Views
true car weight
Today 06:56 AM
Today 09:15 AM
5 Replies, 77 Views
Mid-pipes
Today 04:26 AM
Last post by bruce69camaro
Today 08:52 AM
4 Replies, 79 Views
Hello from Chicago
Today 08:14 AM
Last post by thedocs2
Today 08:14 AM
0 Replies, 22 Views
carb tuning with...
Yesterday 08:47 AM
Last post by bhodgdon400
Today 06:35 AM
15 Replies, 210 Views
Single leaf springs to...
Sep 15th, 19 07:33 AM
Today 06:35 AM
9 Replies, 242 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:30 AM
16 Replies, 496 Views
